Commit 85df235e authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
debug xcode
parent 3447d636
...@@ -430,7 +430,7 @@ if (BUILD_USE_GPU) ...@@ -430,7 +430,7 @@ if (BUILD_USE_GPU)
set(FAUST_LINEAR_OPERATOR_GPU_TARGET faust_linear_operator_gpu CACHE INTERNAL "") set(FAUST_LINEAR_OPERATOR_GPU_TARGET faust_linear_operator_gpu CACHE INTERNAL "")
#set(FAUST_MATRIX_CU_TARGET faust_gpu_matrix CACHE INTERNAL "") #set(FAUST_MATRIX_CU_TARGET faust_gpu_matrix CACHE INTERNAL "")
#set(FAUST_FAUSTCORE_CU_TARGET faust_gpu_core CACHE INTERNAL "") #set(FAUST_FAUSTCORE_CU_TARGET faust_gpu_core CACHE INTERNAL "")
set(FAUST_ALGORITHM_CU_TARGET faust_algorithm_gpu CACHE INTERNAL "") #set(FAUST_ALGORITHM_CU_TARGET faust_algorithm_gpu CACHE INTERNAL "")
endif(BUILD_USE_GPU) endif(BUILD_USE_GPU)
...@@ -567,7 +567,7 @@ include(CMake/findExternalLibs.cmake) ...@@ -567,7 +567,7 @@ include(CMake/findExternalLibs.cmake)
########### add_subdirectory ############### ########### add_subdirectory ###############
add_subdirectory(${FAUST_SRC_LINEAR_OPERATOR_DIR} ${FAUST_BIN_LINEAR_OPERATOR_DIR}) add_subdirectory(${FAUST_SRC_LINEAR_OPERATOR_DIR} ${FAUST_BIN_LINEAR_OPERATOR_DIR})
add_subdirectory(${FAUST_ALGORITHM_SRC_DIR} ${FAUST_ALGORITHM_BIN_DIR}) #add_subdirectory(${FAUST_ALGORITHM_SRC_DIR} ${FAUST_ALGORITHM_BIN_DIR})
add_subdirectory(${FAUST_SRC_TEST_DIR} ${FAUST_BIN_TEST_BIN_DIR}) add_subdirectory(${FAUST_SRC_TEST_DIR} ${FAUST_BIN_TEST_BIN_DIR})
if (BUILD_DOCUMENTATION) if (BUILD_DOCUMENTATION)
add_subdirectory(${FAUST_DOC_SRC_DIR} ${FAUST_DOC_BIN_DIR}) add_subdirectory(${FAUST_DOC_SRC_DIR} ${FAUST_DOC_BIN_DIR})
...@@ -588,33 +588,41 @@ endif() ...@@ -588,33 +588,41 @@ endif()
##### Add subdirectory ALGORITHM CPU et GPU version dans le main CmakeLists pour add library avec les cpp et pas que des lib objet
##### --> bug avec ide xcode ################################################################
#set(SRC_FILES "")
file(GLOB CPP_FILES "${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.cpp" "${FAUST_ALGORITHM_FACTORIZATION_SRC_DIR}/*.cpp")
#message(STATUS "algorithm cpp files ${CPP_FILES}")
### include directory
include_directories(${FAUST_SRC_LINEAR_OPERATOR_DIR} ${FAUST_LINEAR_OPERATOR_CPU_SRC_DIR} ${EIGEN_INC_DIR})
if (BUILD_USE_GPU)
include_directories(${FAUST_SRC_LINEAR_OPERATOR_GPU_DIR} ${CUDA_INC_DIR} ${CUDA_RUNTIME_API_INC_DIR} ${CUSPARSE_INC_DIR} ${CUBLAS_V2_INC_DIR})
endif()
if(BUILD_OPENBLAS)
include_directories(${OPENBLAS_INC_DIR})
endif()
###### TARGET GENERATION ###### ###### TARGET GENERATION ######
if (BUILD_USE_GPU) if (BUILD_USE_GPU)
if (BUILD_MATLAB_MEX_FILES) if (BUILD_MATLAB_MEX_FILES)
add_library(${FAUST_TARGET} STATIC $<TARGET_OBJECTS:${FAUST_LINEAR_OPERATOR_TARGET}> $<TARGET_OBJECTS:${FAUST_ALGORITHM_CU_TARGET}> $<TARGET_OBJECTS:${FAUST_MEXTOOLS_TARGET}> ) add_library(${FAUST_TARGET} STATIC ${CPP_FILES} $<TARGET_OBJECTS:${FAUST_LINEAR_OPERATOR_TARGET}> $<TARGET_OBJECTS:${FAUST_MEXTOOLS_TARGET}> )
else (BUILD_MATLAB_MEX_FILES) else (BUILD_MATLAB_MEX_FILES)
add_library(${FAUST_TARGET} STATIC $<TARGET_OBJECTS:${FAUST_LINEAR_OPERATOR_TARGET}> $<TARGET_OBJECTS:${FAUST_ALGORITHM_CU_TARGET}>) add_library(${FAUST_TARGET} STATIC ${CPP_FILES} $<TARGET_OBJECTS:${FAUST_LINEAR_OPERATOR_TARGET}>)
endif(BUILD_MATLAB_MEX_FILES) endif(BUILD_MATLAB_MEX_FILES)
else (BUILD_USE_GPU) else (BUILD_USE_GPU)
if(APPLE AND ( CMAKE_GENERATOR STREQUAL "Xcode") )
message (STATUS "------------------------------------------ ")
message (STATUS "APPLE AND Xcode ${FAUST_ALGORITHM_TARGET} ${FAUST_ALGORITHM_BIN_DIR}")
else ()
add_library(${FAUST_TARGET} STATIC $<TARGET_OBJECTS:${FAUST_LINEAR_OPERATOR_TARGET}> $<TARGET_OBJECTS:${FAUST_ALGORITHM_TARGET}> $<TARGET_OBJECTS:${FAUST_MEXTOOLS_TARGET}> )
endif()
add_library(${FAUST_TARGET} STATIC $<TARGET_OBJECTS:${FAUST_LINEAR_OPERATOR_TARGET}> $<TARGET_OBJECTS:${FAUST_ALGORITHM_TARGET}>) add_library(${FAUST_TARGET} STATIC ${CPP_FILES} $<TARGET_OBJECTS:${FAUST_LINEAR_OPERATOR_TARGET}>)
endif (BUILD_USE_GPU) endif (BUILD_USE_GPU)
if (UNIX) if (UNIX)
if(APPLE) if(APPLE)
#INCLUDE("${PROJECT_SOURCE_DIR}/CMake/define_variables.cmake") ##INCLUDE("${PROJECT_SOURCE_DIR}/CMake/define_variables.cmake")
set(SRC_FILES "") #set(SRC_FILES "")
#file(GLOB CPP_FILES "*.cpp") ##file(GLOB CPP_FILES "*.cpp")
file(GLOB CPP_FILES "${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.cpp" "${FAUST_ALGORITHM_FACTORIZATION_SRC_DIR}/*.cpp") #file(GLOB CPP_FILES "${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.cpp" "${FAUST_ALGORITHM_FACTORIZATION_SRC_DIR}/*.cpp")
##message(STATUS "algorithm cpp files ${CPP_FILES}")
#### include directory
#${FAUST_EXCEPTION_SRC_DIR} #include_directories(${FAUST_SRC_LINEAR_OPERATOR_DIR} ${FAUST_LINEAR_OPERATOR_CPU_SRC_DIR} ${EIGEN_INC_DIR})
include_directories(${FAUST_SRC_LINEAR_OPERATOR_DIR} ${FAUST_LINEAR_OPERATOR_CPU_SRC_DIR} ${EIGEN_INC_DIR}) #if (BUILD_USE_GPU)
if(BUILD_OPENBLAS) # include_directories(${FAUST_SRC_LINEAR_OPERATOR_GPU_DIR} ${CUDA_INC_DIR} ${CUDA_RUNTIME_API_INC_DIR} ${CUSPARSE_INC_DIR} ${CUBLAS_V2_INC_DIR})
include_directories(${OPENBLAS_INC_DIR}) #endif()
endif() #if(BUILD_OPENBLAS)
# include_directories(${OPENBLAS_INC_DIR})
if(APPLE AND ( CMAKE_GENERATOR STREQUAL "Xcode") ) #endif()
# on compile les sources directement dans le cmaklist principal pour Xcode
#add_library(${FAUST_ALGORITHM_TARGET} ${CPP_FILES})
else () #if(APPLE AND ( CMAKE_GENERATOR STREQUAL "Xcode") )
add_library(${FAUST_ALGORITHM_TARGET} OBJECT ${CPP_FILES}) # # on compile les sources directement dans le cmaklist principal pour Xcode
endif() # #add_library(${FAUST_ALGORITHM_TARGET} ${CPP_FILES})
#target_link_libraries(${FAUST_PALM4MSA_TARGET} ${FAUST_MATRIX_TARGET} ${FAUST_EXCEPTION_TARGET}) #else ()
# add_library(${FAUST_ALGORITHM_TARGET} OBJECT ${CPP_FILES})
#endif()
### Dans le cas ou on fusionne les dossiers ##target_link_libraries(${FAUST_PALM4MSA_TARGET} ${FAUST_MATRIX_TARGET} ${FAUST_EXCEPTION_TARGET})
if (BUILD_USE_GPU) ##target_link_libraries(${FAUST_PALM4MSA_CU_TARGET} ${FAUST_MATRIX_CU_TARGET} ${FAUST_EXCEPTION_TARGET})
# include_directories(${FAUST_SRC_LINEAR_OPERATOR_DIR} ${FAUST_ALGORITHM_CU_SRC_DIR} ${FAUST_MATRIX_CU_SRC_DIR} ${EIGEN_INC_DIR} ${CUDA_INC_DIR} ${CUDA_RUNTIME_API_INC_DIR} ${CUSPARSE_INC_DIR} ${CUBLAS_V2_INC_DIR})
#${EIGEN_INC_DIR}
#-D__COMPILE_TIMERS__
# if(UNIX) # AND FAUST_USE_MKL
# set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fopenmp")
# elseif(WIN32 AND FAUST_USE_MKL)
# set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /openmp")
# endif()
#message(STATUS "CMAKE_CXX_FLAGS=${CMAKE_CXX_FLAGS}")
#add_definitions(-D__COMPILE_GPU__ -D__COMPILE_SPMAT__)
add_library(${FAUST_ALGORITHM_CU_TARGET} OBJECT ${CPP_FILES})
endif()
