Commit 8277d673 authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
modif create install directory during cmake
parent 1a7c7cd8
...@@ -379,7 +379,7 @@ if (BUILD_MATLAB_MEX_FILES) ...@@ -379,7 +379,7 @@ if (BUILD_MATLAB_MEX_FILES)
#file(MAKE_DIRECTORY ${FAUST_DEMO_HADAMARD_OUTPUT_INSTALL_DIR}) #file(MAKE_DIRECTORY ${FAUST_DEMO_HADAMARD_OUTPUT_INSTALL_DIR})
#file(MAKE_DIRECTORY ${FAUST_DEMO_TIMECOMP_INSTALL_DIR}) #file(MAKE_DIRECTORY ${FAUST_DEMO_TIMECOMP_INSTALL_DIR})
#file(MAKE_DIRECTORY ${FAUST_DEMO_FIG_INSTALL_DIR}) #file(MAKE_DIRECTORY ${FAUST_DEMO_FIG_INSTALL_DIR})
file(MAKE_DIRECTORY ${FAUST_DEMO_QUICKSTART_INSTALL_DIR}) #file(MAKE_DIRECTORY ${FAUST_DEMO_QUICKSTART_INSTALL_DIR})
endif(BUILD_MATLAB_MEX_FILES) endif(BUILD_MATLAB_MEX_FILES)
...@@ -7,7 +7,7 @@ It provides a user friendly new class of matrix \textbf{Faust} efficient for the ...@@ -7,7 +7,7 @@ It provides a user friendly new class of matrix \textbf{Faust} efficient for the
\section{Configure Matlab path}\label{sec:firstUseMatlabPath} \section{Configure Matlab path}\label{sec:firstUseMatlabPath}
In order to use matlab wrapper, follow the instructions : In order to use matlab wrapper, follow the instructions :
\begin{itemize} \begin{itemize}
\item \textbf{Install} FA$\mu$ST tool (see preceding chapter) \item \textbf{Install} FA$\mu$ST tool (see Chapter \ref{sec:InstallUnix} in case of Unix install or Chapter \ref{sec:WinInstall} in case of Windows install)
\item \textbf{Launch} Matlab. \item \textbf{Launch} Matlab.
\item \textbf{Set the working directory} of the Matlab Command Window to :\\ \item \textbf{Set the working directory} of the Matlab Command Window to :\\
\texttt{/<HOMEDIR>/Documents/MATLAB/Faust} \texttt{/<HOMEDIR>/Documents/MATLAB/Faust}
