Commit 80a4b818 authored by hhakim's avatar hhakim
Fix a bug in cmake ctest cmd for launching quickstart demo.
Bug introduced by 79096679 (by moving the script elsewhere).
parent 62ca9818
...@@ -250,7 +250,7 @@ if (BUILD_WRAPPER_PYTHON) ...@@ -250,7 +250,7 @@ if (BUILD_WRAPPER_PYTHON)
if(PYTHON_MODULE_SCIPY) if(PYTHON_MODULE_SCIPY)
add_test(NAME PYTHON${PY_VER}_FAUST_TIME COMMAND ${PYTHON_EXE} ${FAUST_SRC_TEST_SRC_PYTHON_DIR}/test_pyFaust_time.py ${FAUST_PYTHON_BIN_DIR} ${FAUST_BIN_TEST_FIG_DIR}) add_test(NAME PYTHON${PY_VER}_FAUST_TIME COMMAND ${PYTHON_EXE} ${FAUST_SRC_TEST_SRC_PYTHON_DIR}/test_pyFaust_time.py ${FAUST_PYTHON_BIN_DIR} ${FAUST_BIN_TEST_FIG_DIR})
add_test(NAME PYTHON${PY_VER}_FAUST_DEMO_INSTALL COMMAND ${PYTHON_EXE} -c "from pyfaust.demo import quickstart; quickstart.run()") add_test(NAME PYTHON${PY_VER}_FAUST_DEMO_INSTALL COMMAND ${PYTHON_EXE} -c "import sys; sys.path += ['${FAUST_PYTHON_BIN_DIR}'];from pyfaust.demo import quickstart; quickstart.run()")
add_test(NAME PYTHON${PY_VER}_FAUST_UNIT_TESTS COMMAND ${PYTHON_EXE} ${FAUST_SRC_TEST_SRC_PYTHON_DIR}/test_FaustPy.py ${FAUST_PYTHON_BIN_DIR}) # second arg. is the FaustPy's dir. to add to PYTHONPATH add_test(NAME PYTHON${PY_VER}_FAUST_UNIT_TESTS COMMAND ${PYTHON_EXE} ${FAUST_SRC_TEST_SRC_PYTHON_DIR}/test_FaustPy.py ${FAUST_PYTHON_BIN_DIR}) # second arg. is the FaustPy's dir. to add to PYTHONPATH
endif(PYTHON_MODULE_SCIPY) endif(PYTHON_MODULE_SCIPY)
endif() endif()
