Commit 7d386c57 authored by hhakim's avatar hhakim
Add a script for showing truncated SVD accuracy versus the RCG.
It's a way somehow to show out the interest of a particuler FAµST.
parent a0acaa1e
# this script aims to show how SVD could be useful to get a better RCG than
# the full matrix while not totally losing the accuracy
# The SVD case here can be seen as a particular situation for a FAµST
from sys import argv
from matplotlib import pyplot as plt
from numpy.linalg import norm
from numpy.random import rand
from threading import Thread
from scipy.linalg import svd
class TruncSvd(Thread):
def __init__(self, offset, M, U, S, V, r, errs, rcgs):
Thread.__init__(self)
self.offset = offset
self.M = M
self.U = U
self.V = V
self.S = S
self.r = r
self.errs = errs
self.rcgs = rcgs
def run(s):
S = np.zeros([s.U.shape[1], s.V.shape[0]])
for i in range(0, s.S.shape[0]):
S[i, i] = s.S[i]
# assert((abs(M - s.U.dot(S).dot(s.V))/abs(s.M) < .01).all())
while(s.r <= min(s.M.shape[0], s.M.shape[1])):
s.Mr = (s.U[:, 0:s.r].dot(S[0:s.r, 0:s.r])).dot(s.V[0:s.r, :])
s.errs[0, s.r-1] = norm(s.M-s.Mr, 'fro')/norm(s.M, 'fro')
s.rcgs[0, s.r-1] = s.M.shape[0] * s.M.shape[1]
s.rcgs[0, s.r-1] /= (s.r*(s.M.shape[0]+s.M.shape[1]))
s.r += s.offset
if __name__ == '__main__':
if(len(argv) < 3):
print("USAGE: ", argv[0], "<num_lines> <num_cols>")
exit(1)
m = int(argv[1])
n = int(argv[2])
nthreads = 8
errs = np.zeros([1, min(m, n)])
rcgs = np.zeros([1, min(m, n)])
M = rand(m, n)
U, S, V = svd(M)
ths = list()
for i in range(1, nthreads+1):
th = TruncSvd(nthreads, M, U, S, V, i, errs, rcgs)
ths.append(th)
th.start()
for th in ths:
th.join()
plt.scatter(rcgs[0, :], errs[0, :], s=1)
# plt.gca().set_xscale('log', basex=.5)
plt.gca().invert_xaxis()
plt.xlabel('Relative Complexity Gain (RCG)')
plt.ylabel('Relative Error')
plt.title('Relative Error over RCG of Truncated SVDs for a dense matrix M ('
+ str(m) + 'x' + str(n)+')')
# f = open("svd_err_vs_rcg_output_"+str(nthreads), "w")
# for i in range(0,errs.shape[1]):
# f.write(str(errs[0,i])+" "+str(rcgs[0,i])+"\n")
# f.close()
# plt.plot(rcgs, errs)
plt.show()
