GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
faust group
faust
79a5eb6a
79a5eb6a
9 years ago
Adrien Leman
Committed by
hhakim
2 years ago
Downloads
Patches
test AL
2cce60e0
2
2 changed files
CMake/findExternalLibs.cmake
+14
-5
14 additions, 5 deletions
CMake/findMATIOLib.cmake
+0
-1
0 additions, 1 deletion
14 additions
6 deletions
14
5
79a5eb6a
@@ -31,8 +31,8 @@ message(STATUS "******* Check externals library ***********")
# Default path library (where the library is automatically install)
add_library_path
LIBRARY_PATH_LIST_TMP_DEFAULT
"/opt/OpenBLAS"
PROJECT_SOURCE_DIR
/externals/unix/OpenBLAS"
"/usr/local" #pour matio
"/usr/local/lib" #pour matio
"/usr/local"
#pour matio
"/usr/local/lib"
#pour matio
PROJECT_SOURCE_DIR
/externals/unix/matio/src/.libs"
#pour matio
@@ -40,7 +40,7 @@ add_include_path(INCLUDE_PATH_LIST_TMP_DEFAULT "/opt/OpenBLAS"
PROJECT_SOURCE_DIR
"/usr/include/eigen3"
PROJECT_SOURCE_DIR
/externals/unix/eigen"
"/usr/local"
#pour matio
PROJECT_SOURCE_DIR
/externals/unix/matio/src"
#pour matio
@@ -71,8 +71,8 @@ endif(FAUST_USE_MATIO)
#add_library_path(LIBRARY_PATH_LIST_TMP3 "$ENV{CUDADIR}" "$ENV{HDF5_ROOT_DIR}" "/usr/lib/x86_64-linux-gnu/")
#add_include_path(INCLUDE_PATH_LIST_TMP3 "$ENV{CUDADIR}" "/usr/include/libxml2")
add_library_path
"$ENV{CUDADIR}"
"/usr"
"/usr/local"
"/opt"
"/opt/local"
add_include_path
"$ENV{CUDADIR}"
"/usr"
"/usr/local"
"/opt"
"/opt/local"
add_library_path
"$ENV{CUDADIR}"
"/usr"
"/opt"
"/opt/local"
add_include_path
"$ENV{CUDADIR}"
"/usr"
"/opt"
"/opt/local"
set
LIBRARY_PATH_LIST
# CACHE PATH "List of library paths used as PATH parameter in find_library")
@@ -100,3 +100,12 @@ if (FAUST_USE_GPU)
endif
FAUST_USE_GPU
check_external_includes
"matio.h"
MATIO_INC_DIR 0
check_external_libraries
matio MATIO_LIB_FILE 0
message
STATUS
"matio lib is here :
MATIO_LIB_FILE
message
STATUS
"matio include is here :
MATIO_INC_DIR
This diff is collapsed.
79a5eb6a
@@ -41,7 +41,6 @@ else ( (MATIO_LIB_FILE) AND (MATIO_INC_DIR) )
if
MATIO_LIB_FILE
AND
MATIO_INC_DIR
message
STATUS
MATIO_LIB_FILE
message
STATUS
"--testAL----------------------------------------------"
message
STATUS
MATIO_INC_DIR
else
message
STATUS
"ERROR !!! matio is not installed !!!!!"
Loading
Save comment
