Commit 7900acf5 authored by hhakim's avatar hhakim
Update MHTPParams: refactoring the ctor in .hpp (initializing all the...
Update MHTPParams: refactoring the ctor in .hpp (initializing all the attributes), adding a to_string member function.
parent 85c899cf
#ifndef __MHTP__ #ifndef __MHTP__
#define __MHTP__ #define __MHTP__
#include <string>
namespace Faust namespace Faust
* \brief This class represents the set of parameters used for the MHTP (Multilinear Hard Thresholding Pursuit) algorithm used optionally in PALM4MSA (2020 implementation only).
template<typename FPP> template<typename FPP>
struct MHTPParams struct MHTPParams
...@@ -11,8 +16,9 @@ namespace Faust ...@@ -11,8 +16,9 @@ namespace Faust
FPP step_size; FPP step_size;
int palm4msa_period; int palm4msa_period;
bool updating_lambda; bool updating_lambda;
MHTPParams();
MHTPParams() : used(false) {}; //TODO: move in faust_MHTP.hpp std::string to_string() const;
#include "faust_MHTP.hpp"
#endif #endif
namespace Faust
MHTPParams<FPP>::MHTPParams() : used(false),
constant_step_size(false),
step_size(1e-3),
palm4msa_period(1000),
updating_lambda(true),
sc(StoppingCriterion<FPP>(50)){};
std::string MHTPParams<FPP>::to_string() const
auto sc_str = sc.to_string();
std::string str = "MHTPParams (START):";
str += "\r\n";
str += "StoppingCriterion:";
str += "\r\n ===";
str += sc_str;
str += " === \r\n";
str += "constant_step_size: ";
str += std::to_string(constant_step_size);
str += "\r\n";
str += "step_size: ";
str += std::to_string(step_size);
str += "\r\n";
str += "palm4msa_period: ";
str += std::to_string(palm4msa_period);
str += "\r\n";
str += "updating_lambda: ";
str += std::to_string(updating_lambda);
str += "\r\n";
str += "MHTPParams END.";
return str;
