Commit 765bc77e authored by hhakim's avatar hhakim
Add MatGeneric<FPP,GPU2> abstract parent class for MatSparse/Dense<FPP,GPU2>...
Add MatGeneric<FPP,GPU2> abstract parent class for MatSparse/Dense<FPP,GPU2> and implement getNbRow/Col() in child classes.
parent ec4c4f4f
Showing with 108 additions and 70 deletions
Subproject commit e4f1060e5e2973fb2ac4b59520c158c03ec60116 Subproject commit f73ff0267aac9210fa6d235b550d27db036872cd
...@@ -61,7 +61,7 @@ namespace Faust ...@@ -61,7 +61,7 @@ namespace Faust
void insert(const Faust::MatGeneric<FPP,Cpu>* M, int32_t id); void insert(const Faust::MatGeneric<FPP,Cpu>* M, int32_t id);
/** TODO: this function should be deleted because it definitely slower than the version 2 */ /** TODO: this function should be deleted because it is definitely slower than the version 2 */
FPP power_iteration(int32_t max_iter, Real<FPP> threshold, int& flag); FPP power_iteration(int32_t max_iter, Real<FPP> threshold, int& flag);
/** This version differs from power_iteration in the way it computes F'Fv in this order F'(Fv) /** This version differs from power_iteration in the way it computes F'Fv in this order F'(Fv)
...@@ -18,6 +18,7 @@ bool Faust::FaustGPU<FPP>::are_cpu_mat_all_known(const std::vector<MatGeneric<FP ...@@ -18,6 +18,7 @@ bool Faust::FaustGPU<FPP>::are_cpu_mat_all_known(const std::vector<MatGeneric<FP
namespace Faust namespace Faust
//TODO: these functions have to move elsewhere more appropriate or simply disappear
template<> template<>
void set_one<double>(double* scal) void set_one<double>(double* scal)
...@@ -200,7 +200,7 @@ namespace Faust ...@@ -200,7 +200,7 @@ namespace Faust
Faust::RefManager FaustGPU<@FAUST_SCALAR_FOR_GM@>::ref_man([](void *fact) Faust::RefManager FaustGPU<@FAUST_SCALAR_FOR_GM@>::ref_man([](void *fact)
auto gp_funcs = GPUModHandler::get_singleton()->gp_funcs(); auto gp_funcs = GPUModHandler::get_singleton()->gp_funcs();
//normally cpu_gpu_map must contains a the key fac if ref_man knew it (see ctor) //normally cpu_gpu_map must contain the fact key if ref_man knew it (see ctor)
gp_funcs->free_mat(Faust::FaustGPU<@FAUST_SCALAR_FOR_GM@>::cpu_gpu_map[fact]); gp_funcs->free_mat(Faust::FaustGPU<@FAUST_SCALAR_FOR_GM@>::cpu_gpu_map[fact]);
Faust::FaustGPU<@FAUST_SCALAR_FOR_GM@>::cpu_gpu_map.erase(fact); Faust::FaustGPU<@FAUST_SCALAR_FOR_GM@>::cpu_gpu_map.erase(fact);
...@@ -2,18 +2,17 @@ ...@@ -2,18 +2,17 @@
#define __FAUST_MATDENSE_GPU2__ #define __FAUST_MATDENSE_GPU2__
#ifdef USE_GPU_MOD #ifdef USE_GPU_MOD
#include "faust_MatDense.h" #include "faust_MatDense.h"
#include "faust_MatGeneric_gpu.h"
#include "faust_gpu_mod_utils.h" #include "faust_gpu_mod_utils.h"
template<typename FPP,FDevice DEVICE>
class MatDense;
template <typename FPP> template <typename FPP>
void gemm(const MatDense<FPP, GPU2> &A, const MatDense<FPP, GPU2> &B, MatDense<FPP, GPU2> &C, const FPP& alpha, const FPP& beta, const char opA, const char opB); void gemm(const MatDense<FPP, GPU2> &A, const MatDense<FPP, GPU2> &B, MatDense<FPP, GPU2> &C, const FPP& alpha, const FPP& beta, const char opA, const char opB);
template<typename FPP> template<typename FPP>
class MatDense<FPP, GPU2> : MatDense<FPP, Cpu> class MatDense<FPP, GPU2> : public MatGeneric<FPP,GPU2>
friend void gemm<>(const MatDense<FPP, GPU2> &A, const MatDense<FPP, GPU2> &B, MatDense<FPP, GPU2> &C, const FPP& alpha, const FPP& beta, const char opA, const char opB); friend void gemm<>(const MatDense<FPP, GPU2> &A, const MatDense<FPP, GPU2> &B, MatDense<FPP, GPU2> &C, const FPP& alpha, const FPP& beta, const char opA, const char opB);
...@@ -86,11 +85,14 @@ namespace Faust ...@@ -86,11 +85,14 @@ namespace Faust
MatDense<FPP, Cpu> tocpu(const void* stream=nullptr) const; MatDense<FPP, Cpu> tocpu(const void* stream=nullptr) const;
void Display() const; void Display() const;
std::string to_string(const bool transpose=false, const bool displaying_small_mat_elts=false) const; std::string to_string(const bool transpose=false, const bool displaying_small_mat_elts=false) const;
int32_t getNbRow() const;
int32_t getNbCol() const;
private: private:
gm_DenseMat_t gpu_mat; gm_DenseMat_t gpu_mat;
#include "faust_MatDense_gpu_double.hpp" #include "faust_MatDense_gpu_double.hpp"
#endif #endif
#endif #endif
//TODO: move to CPP //TODO: move to CPP
template<>
int32_t Faust::MatDense<@FAUST_SCALAR_FOR_GM@, GPU2>::getNbRow() const
int32_t nrows;
auto dsm_funcs = GPUModHandler::get_singleton()->dsm_funcs(@FAUST_SCALAR_FOR_GM@(0));
dsm_funcs->info(gpu_mat, &nrows, nullptr);
return nrows;
template<>
int32_t Faust::MatDense<@FAUST_SCALAR_FOR_GM@, GPU2>::getNbCol() const
int32_t ncols;
dsm_funcs->info(gpu_mat, nullptr, &ncols);
return ncols;
Faust::MatDense<@FAUST_SCALAR_FOR_GM@,GPU2>::MatDense( Faust::MatDense<@FAUST_SCALAR_FOR_GM@,GPU2>::MatDense(
const faust_unsigned_int nbRow, const faust_unsigned_int nbRow,
...@@ -8,10 +26,8 @@ namespace Faust ...@@ -8,10 +26,8 @@ namespace Faust
const @FAUST_SCALAR_FOR_GM@* data/*=nullptr*/, const @FAUST_SCALAR_FOR_GM@* data/*=nullptr*/,
const bool no_alloc/*= false*/, const bool no_alloc/*= false*/,
const int32_t dev_id/*=-1*/, const int32_t dev_id/*=-1*/,
const void* stream/*=nullptr*/) const void* stream/*=nullptr*/) : MatGeneric<@FAUST_SCALAR_FOR_GM@,GPU2>()
this->dim1 = nbRow;
this->dim2 = nbCol;
auto dsm_funcs = GPUModHandler::get_singleton()->dsm_funcs(@FAUST_SCALAR_FOR_GM@(0)); auto dsm_funcs = GPUModHandler::get_singleton()->dsm_funcs(@FAUST_SCALAR_FOR_GM@(0));
// create the matrix in the device dev_id memory // create the matrix in the device dev_id memory
...@@ -45,18 +61,17 @@ namespace Faust ...@@ -45,18 +61,17 @@ namespace Faust
dsm_funcs->mul_gpu_dsm_ext(this->gpu_mat, other.gpu_mat, other.gpu_mat, OP_NOTRANSP, OP_NOTRANSP); dsm_funcs->mul_gpu_dsm_ext(this->gpu_mat, other.gpu_mat, other.gpu_mat, OP_NOTRANSP, OP_NOTRANSP);
//TODO: update dims (in transpose/adjoint case) //TODO: update dims (in transpose/adjoint case)
other.dim1 = dim1;
void Faust::MatDense<@FAUST_SCALAR_FOR_GM@,GPU2>::multiply(MatDense<@FAUST_SCALAR_FOR_GM@, Cpu> &other, const char op_this) void Faust::MatDense<@FAUST_SCALAR_FOR_GM@,GPU2>::multiply(MatDense<@FAUST_SCALAR_FOR_GM@, Cpu> &other, const char op_this)
// other = this * other // other = this * other
MatDense<@FAUST_SCALAR_FOR_GM@, GPU2> other_gpu_mat(other.dim1, other.dim2,other.getData()); MatDense<@FAUST_SCALAR_FOR_GM@, GPU2> other_gpu_mat(other.getNbRow(), other.getNbCol(), other.getData());
other.resize(this->getNbRow(), other.getNbCol());
dsm_funcs->mul_gpu_dsm_tocpu_ext(this->gpu_mat, other_gpu_mat.gpu_mat, other.getData(), OP_NOTRANSP, OP_NOTRANSP); dsm_funcs->mul_gpu_dsm_tocpu_ext(this->gpu_mat, other_gpu_mat.gpu_mat, other.getData(), OP_NOTRANSP, OP_NOTRANSP);
other.dim1 = dim1;
...@@ -64,7 +79,7 @@ namespace Faust ...@@ -64,7 +79,7 @@ namespace Faust
MatDense<@FAUST_SCALAR_FOR_GM@, GPU2> gpu_vec(vec.size(), 1, vec.getData()); MatDense<@FAUST_SCALAR_FOR_GM@, GPU2> gpu_vec(vec.size(), 1, vec.getData());
Faust::Vect<@FAUST_SCALAR_FOR_GM@, Cpu> out_v(dim2); Faust::Vect<@FAUST_SCALAR_FOR_GM@, Cpu> out_v(getNbCol());
dsm_funcs->mul_gpu_dsm_tocpu_ext(this->gpu_mat, gpu_vec.gpu_mat, out_v.getData(), OP_NOTRANSP, OP_NOTRANSP); dsm_funcs->mul_gpu_dsm_tocpu_ext(this->gpu_mat, gpu_vec.gpu_mat, out_v.getData(), OP_NOTRANSP, OP_NOTRANSP);
return out_v; return out_v;
...@@ -113,7 +128,7 @@ namespace Faust ...@@ -113,7 +128,7 @@ namespace Faust
Faust::MatDense<@FAUST_SCALAR_FOR_GM@, Cpu> Faust::MatDense<@FAUST_SCALAR_FOR_GM@,GPU2>::tocpu(const void* stream/*=nullptr*/) const Faust::MatDense<@FAUST_SCALAR_FOR_GM@, Cpu> Faust::MatDense<@FAUST_SCALAR_FOR_GM@,GPU2>::tocpu(const void* stream/*=nullptr*/) const
MatDense<@FAUST_SCALAR_FOR_GM@, Cpu> cpu_mat(dim1, dim2); MatDense<@FAUST_SCALAR_FOR_GM@, Cpu> cpu_mat(getNbRow(), getNbCol());
dsm_funcs->set_stream(gpu_mat, stream); dsm_funcs->set_stream(gpu_mat, stream);
dsm_funcs->tocpu(gpu_mat, cpu_mat.getData()); dsm_funcs->tocpu(gpu_mat, cpu_mat.getData());
...@@ -125,12 +140,12 @@ namespace Faust ...@@ -125,12 +140,12 @@ namespace Faust
void Faust::MatDense<@FAUST_SCALAR_FOR_GM@,GPU2>::resize(const faust_unsigned_int nbRow, const faust_unsigned_int nbCol) void Faust::MatDense<@FAUST_SCALAR_FOR_GM@,GPU2>::resize(const faust_unsigned_int nbRow, const faust_unsigned_int nbCol)
dsm_funcs->resize(gpu_mat, nbRow, nbCol); dsm_funcs->resize(gpu_mat, getNbRow(), getNbCol());
this->dim1 = nbRow; #ifndef NDEBUG
this->dim2 = nbCol;
int32_t new_nrows, new_ncols; int32_t new_nrows, new_ncols;
dsm_funcs->info(gpu_mat, &new_nrows, &new_ncols); dsm_funcs->info(gpu_mat, &new_nrows, &new_ncols);
assert(nbRow == new_nrows && new_ncols == nbCol); assert(getNbRow() == new_nrows && new_ncols == getNbCol());
#endif
...@@ -145,7 +160,7 @@ namespace Faust ...@@ -145,7 +160,7 @@ namespace Faust
dsm_funcs->setzeros(gpu_mat); dsm_funcs->setzeros(gpu_mat);
this->isZeros = true; this->is_zeros = true;
...@@ -177,7 +192,7 @@ namespace Faust ...@@ -177,7 +192,7 @@ namespace Faust
// use a stream (nullptr means default) // use a stream (nullptr means default)
dsm_funcs->set_stream(this->gpu_mat, stream); dsm_funcs->set_stream(this->gpu_mat, stream);
auto gpu_mat = dsm_funcs->clone(this->gpu_mat); auto gpu_mat = dsm_funcs->clone(this->gpu_mat);
auto clone_mat = new Faust::MatDense<@FAUST_SCALAR_FOR_GM@,GPU2>(dim1, dim2, nullptr, /*no_alloc*/true, dev_id); auto clone_mat = new Faust::MatDense<@FAUST_SCALAR_FOR_GM@,GPU2>(getNbRow(), getNbCol(), nullptr, /*no_alloc*/true, dev_id);
clone_mat->gpu_mat = gpu_mat; clone_mat->gpu_mat = gpu_mat;
// return to previous device // return to previous device
gp_funcs->set_dev(cur_dev_id); gp_funcs->set_dev(cur_dev_id);
...@@ -191,9 +206,6 @@ namespace Faust ...@@ -191,9 +206,6 @@ namespace Faust
dsm_funcs->transpose(this->gpu_mat); dsm_funcs->transpose(this->gpu_mat);
auto tmp = dim1;
dim1 = dim2;
dim2 = tmp;
...@@ -201,9 +213,6 @@ namespace Faust ...@@ -201,9 +213,6 @@ namespace Faust
dsm_funcs->adjoint(this->gpu_mat); dsm_funcs->adjoint(this->gpu_mat);
auto tmp = dim1;
dim1 = dim2;
dim2 = tmp;
...@@ -332,12 +341,11 @@ namespace Faust ...@@ -332,12 +341,11 @@ namespace Faust
dsm_funcs->mul_gpu_dsm_ext(this->gpu_mat, A.gpu_mat, this->gpu_mat, OP_NOTRANSP, OP_NOTRANSP); dsm_funcs->mul_gpu_dsm_ext(this->gpu_mat, A.gpu_mat, this->gpu_mat, OP_NOTRANSP, OP_NOTRANSP);
Faust::MatDense<@FAUST_SCALAR_FOR_GM@,GPU2> new_this(dim1, A.dim2, nullptr); Faust::MatDense<@FAUST_SCALAR_FOR_GM@,GPU2> new_this(getNbRow(), A.getNbCol(), nullptr);
dsm_funcs->mul_gpu_dsm_ext(this->gpu_mat, A.gpu_mat, new_this.gpu_mat, OP_NOTRANSP, OP_NOTRANSP); dsm_funcs->mul_gpu_dsm_ext(this->gpu_mat, A.gpu_mat, new_this.gpu_mat, OP_NOTRANSP, OP_NOTRANSP);
auto tmp = this->gpu_mat; auto tmp = this->gpu_mat;
this->gpu_mat = new_this.gpu_mat; this->gpu_mat = new_this.gpu_mat;
new_this.gpu_mat = tmp; new_this.gpu_mat = tmp;
this->dim2 = A.dim2;
...@@ -346,12 +354,11 @@ namespace Faust ...@@ -346,12 +354,11 @@ namespace Faust
// this = this * other // this = this * other
MatDense<@FAUST_SCALAR_FOR_GM@,GPU2> gpuA(A.getNbRow(), A.getNbCol(), A.getData()); MatDense<@FAUST_SCALAR_FOR_GM@,GPU2> gpuA(A.getNbRow(), A.getNbCol(), A.getData());
dsm_funcs->mul_gpu_dsm_ext(this->gpu_mat, gpuA.gpu_mat, new_this.gpu_mat, OP_NOTRANSP, OP_NOTRANSP); dsm_funcs->mul_gpu_dsm_ext(this->gpu_mat, gpuA.gpu_mat, new_this.gpu_mat, OP_NOTRANSP, OP_NOTRANSP);
...@@ -371,8 +378,9 @@ namespace Faust ...@@ -371,8 +378,9 @@ namespace Faust
auto spm_funcs = GPUModHandler::get_singleton()->spm_funcs(@FAUST_SCALAR_FOR_GM@(0)); auto spm_funcs = GPUModHandler::get_singleton()->spm_funcs(@FAUST_SCALAR_FOR_GM@(0));
if(isZeros) if(is_zeros)
resize(S.getNbRow(), getNbCol());
setZeros(); setZeros();
else else
...@@ -383,7 +391,6 @@ namespace Faust ...@@ -383,7 +391,6 @@ namespace Faust
dsm_funcs->free(this->gpu_mat); dsm_funcs->free(this->gpu_mat);
spm_funcs->free(gpu_S); spm_funcs->free(gpu_S);
this->gpu_mat = gpu_out; this->gpu_mat = gpu_out;
this->dim1 = S.getNbRow();
...@@ -392,9 +399,7 @@ namespace Faust ...@@ -392,9 +399,7 @@ namespace Faust
dim1 = A.getNbRow(); auto gpu_mat = dsm_funcs->togpu(getNbRow(), getNbCol(), const_cast<@FAUST_SCALAR_FOR_GM@*>(A.getData()));
dim2 = A.getNbCol();
auto gpu_mat = dsm_funcs->togpu(dim1, dim2, const_cast<@FAUST_SCALAR_FOR_GM@*>(A.getData()));
this->gpu_mat = gpu_mat; this->gpu_mat = gpu_mat;
...@@ -413,8 +418,6 @@ namespace Faust ...@@ -413,8 +418,6 @@ namespace Faust
auto gpu_mat = dsm_funcs->clone(A.gpu_mat); auto gpu_mat = dsm_funcs->clone(A.gpu_mat);
this->dim1 = A.dim1;
template <> template <>
...@@ -456,4 +459,6 @@ namespace Faust ...@@ -456,4 +459,6 @@ namespace Faust
std::cout << this->to_string(); std::cout << this->to_string();
#ifndef __FAUST_MATGENERIC_GPU__
#define __FAUST_MATGENERIC_GPU__
namespace Faust
//TODO: this class is temporary, ideally MatSparse<FPP,GPU2> and MatDense<FPP,GPU2> should extend the MatGeneric<FPP, Device> class
//TODO: keep this class until MatSparse<FPP,GPU2> and MatDense<FPP,GPU2> fully implement the MatGeneric<FPP, Device> methods
// The interest of this class is mostly to make Transform capable of storing generic matrix
class MatGeneric<FPP, GPU2>
protected:
bool is_identity;
bool is_zeros;
public:
virtual int32_t getNbRow() const=0;
virtual int32_t getNbCol() const=0;
MatGeneric();
virtual ~MatGeneric();
#include "faust_MatGeneric_gpu.hpp"
#endif
namespace Faust
MatGeneric<FPP,GPU2>::~MatGeneric()
MatGeneric<FPP,GPU2>::MatGeneric() : is_zeros(false), is_identity(false)
...@@ -3,15 +3,12 @@ ...@@ -3,15 +3,12 @@
#include "faust_constant.h" #include "faust_constant.h"
class MatSparse;
class MatSparse<FPP, GPU2> class MatSparse<FPP, GPU2> : public MatGeneric<FPP,GPU2>
public: public:
...@@ -66,8 +63,8 @@ namespace Faust ...@@ -66,8 +63,8 @@ namespace Faust
void setZeros(); void setZeros();
MatSparse<FPP, GPU2>* clone(const int32_t dev_id=-1, const void* stream=nullptr); MatSparse<FPP, GPU2>* clone(const int32_t dev_id=-1, const void* stream=nullptr);
void move(const int32_t dev_id=-1, const void* stream=nullptr); void move(const int32_t dev_id=-1, const void* stream=nullptr);
int32_t getNbRow(); int32_t getNbRow() const;
int32_t getNbCol(); int32_t getNbCol() const;
int32_t getNonZeros(); int32_t getNonZeros();
int32_t getDevice() const; int32_t getDevice() const;
...@@ -75,8 +72,6 @@ namespace Faust ...@@ -75,8 +72,6 @@ namespace Faust
~MatSparse(); ~MatSparse();
private: private:
int32_t nbRow;
int32_t nbCol;
gm_SparseMat_t gpu_mat; gm_SparseMat_t gpu_mat;
//TODO: move to cpp.in //TODO: move to cpp.in
template<>
int32_t Faust::MatSparse<@FAUST_SCALAR_FOR_GM@, GPU2>::getNbRow() const
auto spm_funcs = GPUModHandler::get_singleton()->spm_funcs((@FAUST_SCALAR_FOR_GM@)(0));
int32_t nbRow;
spm_funcs->info(gpu_mat, &nbRow, nullptr, nullptr); //TODO gpu_mod: add get_nnz, get_nrows, get_ncols
return nbRow;
template<>
int32_t Faust::MatSparse<@FAUST_SCALAR_FOR_GM@, GPU2>::getNbCol() const
int32_t nbCol;
spm_funcs->info(gpu_mat, nullptr, &nbCol, nullptr); //TODO gpu_mod: add get_nnz, get_nrows, get_ncols
return nbCol;
...@@ -12,7 +29,7 @@ namespace Faust ...@@ -12,7 +29,7 @@ namespace Faust
const int32_t* rowptr, /*= nullptr,*/ const int32_t* rowptr, /*= nullptr,*/
const int32_t* colinds, /*= nullptr,*/ const int32_t* colinds, /*= nullptr,*/
const int32_t dev_id,/*=-1,*/ const int32_t dev_id,/*=-1,*/
const void* stream)/*=nullptr)*/ : nbRow(nbRow), nbCol(nbCol) const void* stream)/*=nullptr)*/
if(values != nullptr) if(values != nullptr)
...@@ -24,7 +41,6 @@ namespace Faust ...@@ -24,7 +41,6 @@ namespace Faust
gp_funcs->set_dev(dev_id); gp_funcs->set_dev(dev_id);
gpu_mat = spm_funcs->togpu_stream(nbRow, nbCol, nnz, rowptr, colinds, values, stream); gpu_mat = spm_funcs->togpu_stream(nbRow, nbCol, nnz, rowptr, colinds, values, stream);
spm_funcs->info(gpu_mat, &this->nbRow, &this->nbCol, /*nnz*/ nullptr); //normally useless (bcause dims are already initialized), but init from GPU again just in case of inconsistency that would show up in tests
else gpu_mat = nullptr; else gpu_mat = nullptr;
...@@ -62,8 +78,6 @@ namespace Faust ...@@ -62,8 +78,6 @@ namespace Faust
auto spm_funcs = GPUModHandler::get_singleton()->spm_funcs((@FAUST_SCALAR_FOR_GM@)(0)); auto spm_funcs = GPUModHandler::get_singleton()->spm_funcs((@FAUST_SCALAR_FOR_GM@)(0));
spm_funcs->copy(mat.gpu_mat, gpu_mat); spm_funcs->copy(mat.gpu_mat, gpu_mat);
nbRow = mat.nbRow;
nbCol = mat.nbCol;
...@@ -114,8 +128,6 @@ namespace Faust ...@@ -114,8 +128,6 @@ namespace Faust
spm_funcs->free(this->gpu_mat); spm_funcs->free(this->gpu_mat);
this->gpu_mat = gmat.gpu_mat; this->gpu_mat = gmat.gpu_mat;
this->nbRow = gmat.nbRow;
this->nbCol = gmat.nbCol;
gmat.gpu_mat = nullptr; // to avoid freeing the new gpu_mat when leaving this scope gmat.gpu_mat = nullptr; // to avoid freeing the new gpu_mat when leaving this scope
...@@ -171,8 +183,6 @@ namespace Faust ...@@ -171,8 +183,6 @@ namespace Faust
void Faust::MatSparse<@FAUST_SCALAR_FOR_GM@, GPU2>::resize(int32_t nnz, int32_t nrows, int32_t ncols) void Faust::MatSparse<@FAUST_SCALAR_FOR_GM@, GPU2>::resize(int32_t nnz, int32_t nrows, int32_t ncols)
nbRow = nrows;
nbCol = ncols;
spm_funcs->resize(gpu_mat, nnz, nrows, ncols); spm_funcs->resize(gpu_mat, nnz, nrows, ncols);
...@@ -204,7 +214,7 @@ namespace Faust ...@@ -204,7 +214,7 @@ namespace Faust
spm_funcs->set_stream(this->gpu_mat, stream); spm_funcs->set_stream(this->gpu_mat, stream);
auto gpu_mat = spm_funcs->clone(this->gpu_mat); auto gpu_mat = spm_funcs->clone(this->gpu_mat);
auto clone_mat = new Faust::MatSparse<@FAUST_SCALAR_FOR_GM@,GPU2>(nbRow, nbCol, /*nnz*/ 0, /*values*/ nullptr, /*rowptr */ nullptr, /*colinds*/ nullptr, dev_id, stream); auto clone_mat = new Faust::MatSparse<@FAUST_SCALAR_FOR_GM@,GPU2>(getNbRow(), getNbCol(), /*nnz*/ 0, /*values*/ nullptr, /*rowptr */ nullptr, /*colinds*/ nullptr, dev_id, stream);
...@@ -223,17 +233,6 @@ namespace Faust ...@@ -223,17 +233,6 @@ namespace Faust
spm_funcs->set_stream(gpu_mat, nullptr); spm_funcs->set_stream(gpu_mat, nullptr);
template<>
return nbRow;
template<>
return nbCol;
int32_t Faust::MatSparse<@FAUST_SCALAR_FOR_GM@, GPU2>::getNonZeros() int32_t Faust::MatSparse<@FAUST_SCALAR_FOR_GM@, GPU2>::getNonZeros()
...@@ -216,6 +216,7 @@ namespace Faust ...@@ -216,6 +216,7 @@ namespace Faust
faust_unsigned_int dim2; faust_unsigned_int dim2;
bool is_ortho; bool is_ortho;
bool is_identity; bool is_identity;
//TODO: add is_zeros
