Commit 756540a9 authored by hhakim's avatar hhakim
Start impl. of MatButterfly as a MatGeneric child class.
parent 3ed52bbf
#ifndef FAUST_MATBUTTERFLY_H
#define FAUST_MATBUTTERFLY_H
#ifdef USE_PYTHONIC
#include "numpy/_numpyconfig.h"
#include "ButFactor_matmul.hpp"
#include <pythonic/include/numpy/array.hpp>
#include <pythonic/numpy/array.hpp>
#include "pythonic/include/utils/array_helper.hpp"
#include "pythonic/include/types/ndarray.hpp"
using namespace pythonic;
// Helper to create a float 1D array from a pointer
template <typename T>
types::ndarray<T, types::pshape<long>> arrayFromBuf1D(T* fPtr, long size)
auto shape = types::pshape<long>(size);
return types::ndarray<T, types::pshape<long>>(fPtr,shape,types::ownership::external);
#endif
#include "faust_constant.h"
#include <Eigen/Core>
#include <memory> // shared_ptr
namespace Faust
template<typename FPP, FDevice DEVICE> class MatButterfly;
template<typename FPP>
class MatButterfly<FPP,Cpu> : public MatGeneric<FPP,Cpu>
using VecMap = Eigen::Map<Eigen::Matrix<FPP, Eigen::Dynamic, 1>>;
using DiagMat = Eigen::DiagonalMatrix<FPP, Eigen::Dynamic>;
DiagMat D1;
DiagMat D2;
DiagMat D2T; // D2 for the transpose case
std::vector<int> subdiag_ids;
#ifdef USE_PYTHONIC
long *subdiag_ids_ptr;
#endif
int level;
public:
MatButterfly<FPP,Cpu>(const MatSparse<FPP, Cpu> &factor, int level);
void init_transpose();
void Display() const;
void multiply(const FPP* x, FPP* y, size_t size, bool transpose = false);
void multiply(const FPP* A, int A_ncols, FPP* C, size_t size, bool transpose = false);
const DiagMat& getD1() {return D1;}; //TODO/ move to .hpp
const DiagMat& getD2() {return D2;};
const std::vector<int>& get_subdiag_ids() {return subdiag_ids;}
MatGeneric<FPP,Cpu>* Clone(const bool isOptimize=false) const;
void multiply(Vect<FPP,Cpu> & vec, char opThis='N') const;
void multiply(MatDense<FPP,Cpu> & M, char opThis) const;
void multiply(MatSparse<FPP, Cpu>& M, char opThis) const;
void multiplyRight(MatSparse<FPP, Cpu> const& M) ;
void transpose();
void conjugate(const bool eval=true);
void adjoint();
faust_unsigned_int getNonZeros()const;
size_t getNBytes() const;
MatType getType() const;
void operator*=(const FPP alpha);
matvar_t* toMatIOVar(bool transpose, bool conjugate, const char *var_name=nullptr) const;
Real<FPP> normL1(const bool transpose) const;
Real<FPP> norm() const;
Real<FPP> normL1(faust_unsigned_int& col_id, const bool transpose) const;
Vect<FPP,Cpu> get_col(faust_unsigned_int id) const;
MatGeneric<FPP,Cpu>* get_cols(faust_unsigned_int col_id_start, faust_unsigned_int num_cols) const;
MatGeneric<FPP,Cpu>* get_rows(faust_unsigned_int row_id_start, faust_unsigned_int num_rows) const;
MatGeneric<FPP,Cpu>* get_cols(const faust_unsigned_int* col_ids, faust_unsigned_int num_cols) const;
MatGeneric<FPP,Cpu>* get_rows(const faust_unsigned_int* row_ids, faust_unsigned_int num_rows) const;
std::list<std::pair<int,int>> nonzeros_indices() const;
void setZeros();
bool containsNaN()const;
const FPP& operator()(faust_unsigned_int i, faust_unsigned_int j)const ;
#include "faust_MatButterfly.hpp"
#endif
namespace Faust
MatButterfly<FPP, Cpu>::MatButterfly(const MatSparse<FPP, Cpu> &factor, int level)
// build a d1, d2 pair from the butterfly factor
auto size = factor.getNbRow();
D1.resize(size);
D2.resize(size);
D2T.resize(0); // not used defaultly
FPP *d1_ptr, *d2_ptr;
d1_ptr = D1.diagonal().data();
d2_ptr = D2.diagonal().data();
auto d_offset = size >> (level+1);
auto data = factor.getValuePtr();
auto rowptr = factor.getRowPtr();
for(int i=0;i < size; i++)
if((i / d_offset) & 1)
// d2 coeff is the first elt of row i
d2_ptr[i] = data[rowptr[i]];
d1_ptr[i] = data[rowptr[i]+1]; // diag elt is just after
else
// d2 coeff is the last elt of row i
d2_ptr[i] = data[rowptr[i+1]-1];
d1_ptr[i] = data[rowptr[i+1]-2]; // diag elt is just before
std::vector<int> seq(size);
iota(seq.begin(), seq.end(), 0);
subdiag_ids.resize(size);
for(int i = 0;i < size; i += d_offset * 2)
copy(seq.begin()+i+d_offset, seq.begin()+i+2*d_offset, subdiag_ids.begin()+i);
copy(seq.begin()+i, seq.begin()+i+d_offset, subdiag_ids.begin()+i+d_offset);
#ifdef USE_PYTHONIC
subdiag_ids_ptr = new long[size];
copy(subdiag_ids.begin(), subdiag_ids.end(),subdiag_ids_ptr);
#endif
this->level = level;
void MatButterfly<FPP, Cpu>::Display() const
//TODO: adjust consistently with MatGeneric Display (using to_string)
std::cout << "MatButterfly on CPU: ";
std::cout << "D1: ";
std::cout << D1.diagonal() << std::endl;
std::cout << "D2: ";
std::cout << D2.diagonal() << std::endl;
if(D2T.size() > 0)
std::cout << "D2T: ";
std::cout << D2T.diagonal() << std::endl;
cout << "subdiag_ids: ";
for(int i=0;i < subdiag_ids.size();i++)
cout << subdiag_ids[i] << " ";
cout << std::endl;
void MatButterfly<FPP, Cpu>::init_transpose()
//TODO: simplify in case of symmetric matrix (it happens for the FFT)
auto size = D2.rows();
if(D2T.size() != 0)
// already done
return;
FPP *d1_ptr, *d2_ptr, *d2t_ptr;
D2T.resize(size);
d2t_ptr = D2T.diagonal().data();
// D1 doesn't change
// swap every pair of D2 contiguous blocks to form D2T
// swap two next blocks of size d_offset into d2t_ptr
copy(d2_ptr + i, d2_ptr + i + d_offset, d2t_ptr + i + d_offset);
copy(d2_ptr + i + d_offset, d2_ptr + i + 2 * d_offset, d2t_ptr + i);
MatGeneric<FPP,Cpu>* MatButterfly<FPP, Cpu>::Clone(const bool isOptimize) const
//TODO
return nullptr;
void MatButterfly<FPP, Cpu>::multiply(Vect<FPP,Cpu> & x, char opThis) const
Vect<FPP, Cpu> z(x.size());
multiply(x.getData(), z.getData(), x.size(), opThis != 'N'); //TODO: conjugate
return z;
void MatButterfly<FPP, Cpu>::multiply(MatDense<FPP,Cpu> & M, char opThis) const
//TODO
void MatButterfly<FPP, Cpu>::multiply(MatSparse<FPP, Cpu>& M, char opThis) const
//TODO
void MatButterfly<FPP, Cpu>::multiplyRight(MatSparse<FPP, Cpu> const& M)
//TODO
void MatButterfly<FPP, Cpu>::multiply(const FPP* x, FPP* y, size_t size, bool transpose/* = false*/)
DiagMat &D2 = this->D2;
const FPP *d1_ptr, *d2_ptr;
if(transpose)
init_transpose(); // no cost if already initialized
d2_ptr = D2T.diagonal().data();
D2 = D2T;
else
#ifdef USE_PYTHONIC
auto xArray = arrayFromBuf1D(x, size);
auto d1Array = arrayFromBuf1D(d1_ptr, size);
auto d2Array = arrayFromBuf1D(d2_ptr, size);
auto x_ids = arrayFromBuf1D(subdiag_ids_ptr, size);
// auto yArray = __pythran_ButFactor_matmul::__matmul__()(d1Array, d2Array, xArray, x_ids);
auto yArray = arrayFromBuf1D(y, size);
yArray = pythonic::operator_::add(pythonic::operator_::mul(d1Array, xArray), pythonic::operator_::mul(d2Array, xArray[x_ids]));
memcpy(y, yArray.buffer, sizeof(FPP)*size);
#endif
#define BMAT_MULTIPLY_VEC_OMP_LOOP
#ifdef BMAT_MULTIPLY_VEC_OMP_LOOP
#pragma omp parallel for
y[i] = d1_ptr[i] * x[i] + d2_ptr[i] * x[subdiag_ids[i]];
#else
// this is slower
VecMap x_vec(const_cast<FPP*>(x), size); // const_cast is harmless
VecMap y_vec(y, size); // const_cast is harmless
y_vec = D1 * x_vec + D2 * x_vec(subdiag_ids);
#endif
void MatButterfly<FPP, Cpu>::multiply(const FPP* X, int X_ncols, FPP* Y, size_t Y_nrows, bool transpose/* = false*/)
using MatMap = Eigen::Map<Eigen::Matrix<FPP, Eigen::Dynamic, Eigen::Dynamic>>;
MatMap X_mat(const_cast<FPP*>(X) /* harmless, no modification*/, Y_nrows, X_ncols);
MatMap Y_mat(Y, Y_nrows, X_ncols);
// --------- TODO refactor this block with overload of multiply
if(transpose)
D2 = D2T;
else
#if defined(BUTTERFLY_MUL_MAT_OMP_LOOP) || ! EIGEN_VERSION_AT_LEAST(3, 4, 0)
// this is slower
for(int i=0;i < Y_nrows; i++)
Y_mat.row(i) = d1_ptr[i] * X_mat.row(i) + d2_ptr[i] * X_mat.row(subdiag_ids[i]);
#else
Y_mat = D1 * X_mat + D2 * X_mat(subdiag_ids, Eigen::placeholders::all);
#endif
void MatButterfly<FPP, Cpu>::transpose()
//TODO
void MatButterfly<FPP, Cpu>::conjugate(const bool eval)
//TODO
void MatButterfly<FPP, Cpu>::adjoint()
//TODO
faust_unsigned_int MatButterfly<FPP, Cpu>::getNonZeros()const
//TODO
size_t MatButterfly<FPP, Cpu>::getNBytes() const
//TODO
MatType MatButterfly<FPP, Cpu>::getType() const
//TODO
void MatButterfly<FPP, Cpu>::operator*=(const FPP alpha)
//TODO
matvar_t* MatButterfly<FPP, Cpu>::toMatIOVar(bool transpose, bool conjugate, const char *var_name) const
//TODO
Real<FPP> MatButterfly<FPP, Cpu>::normL1(const bool transpose) const
//TODO
Real<FPP> MatButterfly<FPP, Cpu>::norm() const
//TODO
Real<FPP> MatButterfly<FPP, Cpu>::normL1(faust_unsigned_int& col_id, const bool transpose) const
//TODO
Vect<FPP,Cpu> MatButterfly<FPP, Cpu>::get_col(faust_unsigned_int id) const
//TODO
MatGeneric<FPP,Cpu>* MatButterfly<FPP, Cpu>::get_cols(faust_unsigned_int col_id_start, faust_unsigned_int num_cols) const
//TODO
MatGeneric<FPP,Cpu>* MatButterfly<FPP, Cpu>::get_rows(faust_unsigned_int row_id_start, faust_unsigned_int num_rows) const
//TODO
MatGeneric<FPP,Cpu>* MatButterfly<FPP, Cpu>::get_cols(const faust_unsigned_int* col_ids, faust_unsigned_int num_cols) const
//TODO
MatGeneric<FPP,Cpu>* MatButterfly<FPP, Cpu>::get_rows(const faust_unsigned_int* row_ids, faust_unsigned_int num_rows) const
//TODO
std::list<std::pair<int,int>> MatButterfly<FPP, Cpu>::nonzeros_indices() const
//TODO
void MatButterfly<FPP, Cpu>::setZeros()
//TODO
bool MatButterfly<FPP, Cpu>::containsNaN() const
//TODO
const FPP& MatButterfly<FPP, Cpu>::operator()(faust_unsigned_int i, faust_unsigned_int j) const
//TODO
...@@ -3,24 +3,7 @@ ...@@ -3,24 +3,7 @@
#define IGNORE_TRANSFORM_HELPER_VARIADIC_TPL #define IGNORE_TRANSFORM_HELPER_VARIADIC_TPL
#include "faust_TransformHelper.h" #include "faust_TransformHelper.h"
#ifdef USE_PYTHONIC #include "faust_MatButterfly.h"
#endif
#include <memory> // shared_ptr #include <memory> // shared_ptr
