Commit 72880940 authored by hhakim's avatar hhakim
Optimize Faust::TransformeHelperPoly::multiply(Vect) (F@x in python).
Decrease the number of copies.
======== Mini benchmark
 hinria  …  build  wrapper  python  for i in {1..10}; do python3
test_poly_cpp.py | grep speedup;done
speedup 90.75602805478192
speedup 89.09036938690689
speedup 82.56148989913501
speedup 90.64531438391626
speedup 91.66248597807245
speedup 90.10036697594744
speedup 75.61254492055296
speedup 89.96955925554978
speedup 95.22901711420815
speedup 90.92116442476765
speedup 123.0277183801693
speedup 103.32878272246883
speedup 127.7827667275423
speedup 124.11150187961708
speedup 113.07702426409236
speedup 87.57467702373462
speedup 127.40517991813421
speedup 99.10773177189199
speedup 127.26056623369436
speedup 129.75727501516909
https://gitlab.inria.fr/faustgrp/faust/-/snippets/704
parent 32d965ae
...@@ -19,8 +19,10 @@ namespace Faust ...@@ -19,8 +19,10 @@ namespace Faust
const FPP lambda_, const bool optimizedCopy, const bool cloning_fact, const FPP lambda_, const bool optimizedCopy, const bool cloning_fact,
const bool internal_call) : TransformHelper<FPP,Cpu>(facts, lambda_, optimizedCopy, cloning_fact, internal_call) {} const bool internal_call) : TransformHelper<FPP,Cpu>(facts, lambda_, optimizedCopy, cloning_fact, internal_call) {}
Vect<FPP,Cpu> multiply(const Vect<FPP,Cpu> x, const bool transpose=false, const bool conjugate=false); Vect<FPP,Cpu> multiply(const Vect<FPP,Cpu> &x, const bool transpose=false, const bool conjugate=false);
MatDense<FPP, Cpu> multiply(MatDense<FPP,Cpu> X, const bool transpose=false, const bool conjugate=false); Vect<FPP,Cpu> multiply(const FPP* x, const bool transpose=false, const bool conjugate=false);
void multiply(const FPP* x, FPP* y, const bool transpose=false, const bool conjugate=false);
MatDense<FPP, Cpu> multiply(const MatDense<FPP,Cpu> &X, const bool transpose=false, const bool conjugate=false);
Vect<FPP, Cpu> poly(MatDense<FPP,Cpu> & basisX, Vect<FPP, Cpu> coeffs); Vect<FPP, Cpu> poly(MatDense<FPP,Cpu> & basisX, Vect<FPP, Cpu> coeffs);
MatDense<FPP, Cpu> poly(int n, MatDense<FPP,Cpu> & basisX, Vect<FPP, Cpu> coeffs); MatDense<FPP, Cpu> poly(int n, MatDense<FPP,Cpu> & basisX, Vect<FPP, Cpu> coeffs);
void poly(int d, int n, const FPP* basisX, const FPP* coeffs, FPP* out); void poly(int d, int n, const FPP* basisX, const FPP* coeffs, FPP* out);
#ifndef __FAUST_TRANSFORM_HELPER_POLY__
#define __FAUST_TRANSFORM_HELPER_POLY__
#include "faust_TransformHelper.h"
namespace Faust
* \brief This class aims to represent a Chebyshev polynomial basis as a "Faust".
* It overrides some operations to optimize the performance by taking into account the factors specific structure.
template<typename FPP>
class TransformHelperPoly : public TransformHelper<FPP,Cpu>
public:
MatSparse<FPP, Cpu> L; //TODO: must be private (and basisChebyshev a friend of this class)
MatSparse<FPP, Cpu> twoL; //TODO: must be private
TransformHelperPoly(const std::vector<MatGeneric<FPP,Cpu> *>& facts,
TransformHelper<FPP, Cpu>* polyFaust(const FPP* coeffs);
TransformHelper<FPP, Cpu>* basisChebyshev(MatSparse<FPP,Cpu>* L, int32_t K);
void poly(int d, int K, int n, const FPP* basisX, const FPP* coeffs, FPP* out);
#include "faust_TransformHelperPoly.hpp"
#endif
...@@ -2,11 +2,25 @@ ...@@ -2,11 +2,25 @@
#include "faust_linear_algebra.h" #include "faust_linear_algebra.h"
namespace Faust namespace Faust
Vect<FPP,Cpu> TransformHelperPoly<FPP>::multiply(const Vect<FPP,Cpu> &x, const bool transpose/*=false*/, const bool conjugate/*=false*/)
return std::move(this->multiply(x.getData(), transpose, conjugate));
template<typename FPP> template<typename FPP>
Vect<FPP,Cpu> TransformHelperPoly<FPP>::multiply(const Vect<FPP,Cpu> x, const bool transpose/*=false*/, const bool conjugate/*=false*/) Vect<FPP,Cpu> TransformHelperPoly<FPP>::multiply(const FPP* x, const bool transpose/*=false*/, const bool conjugate/*=false*/)
int d = L.getNbRow();
int K = this->size();
Vect<FPP, Cpu> v0(d*(K+1));
multiply(x, v0.getData(), transpose, conjugate);
return std::move(v0);
void TransformHelperPoly<FPP>::multiply(const FPP* x, FPP* y, const bool transpose/*=false*/, const bool conjugate/*=false*/)
// std::cout << "TransformHelperPoly<FPP>::multiply(Vect)" << std::endl; // std::cout << "TransformHelperPoly<FPP>::multiply(Vect)" << std::endl;
* Recurrence relation (k=1 to K): * Recurrence relation (k=1 to K):
...@@ -22,25 +36,22 @@ namespace Faust ...@@ -22,25 +36,22 @@ namespace Faust
* Fx = [v_{0, K} ; v_{1, K} ; v_{2, K}] * Fx = [v_{0, K} ; v_{1, K} ; v_{2, K}]
int d = L.getNbRow(); int d = L.getNbRow();
Vect<FPP,Cpu> v1(d), v2, tmp; Vect<FPP,Cpu> v2, tmp;
int K = this->size(); int K = this->size();
// seeing how basisChebyshev method is instantiating this class // seeing how basisChebyshev method is instantiating this class
// K can't be strictly lower than two // K can't be strictly lower than two
memcpy(v1.getData(), x.getData(), sizeof(FPP)*d); v2 = L*Vect<FPP,Cpu>(d, x);//L*x
v2 = L*x; memcpy(y, x, sizeof(FPP)*d);
for(int i=2;i<=K;i++) memcpy(y+d, v2.getData(), sizeof(FPP)*d);
for(int i=3;i<=K+1;i++)
memcpy(v0.getData()+d*(i-2), v1.getData(), sizeof(FPP)*d); int offset = d*(i-3);
tmp = v1;
v1 = v2;
// gemv(L, v2, tmp, FPP(1), FPP(-1)); // gemv(L, v2, tmp, FPP(1), FPP(-1));
v2 = twoL*v2; // v2 = twoL*v2;
v2 -= tmp; v2.multiplyLeft(twoL);
v2 -= y+offset;
memcpy(y+d*(i-1), v2.getData(), sizeof(FPP)*d);
memcpy(v0.getData()+d*(K-1), v1.getData(), sizeof(FPP)*d);
memcpy(v0.getData()+d*K, v2.getData(), sizeof(FPP)*d);
return v0;
// Slower method but kept commented here until further tests // Slower method but kept commented here until further tests
...@@ -80,7 +91,7 @@ namespace Faust ...@@ -80,7 +91,7 @@ namespace Faust
MatDense<FPP, Cpu> TransformHelperPoly<FPP>::multiply(MatDense<FPP,Cpu> X, const bool transpose/*=false*/, const bool conjugate/*=false*/) MatDense<FPP, Cpu> TransformHelperPoly<FPP>::multiply(const MatDense<FPP,Cpu> &X, const bool transpose/*=false*/, const bool conjugate/*=false*/)
// std::cout << "TransformHelperPoly<FPP>::multiply(MatDense)" << std::endl; // std::cout << "TransformHelperPoly<FPP>::multiply(MatDense)" << std::endl;
...@@ -227,7 +238,9 @@ namespace Faust ...@@ -227,7 +238,9 @@ namespace Faust
Vect<FPP,Cpu> _coeffs(K_plus_1, coeffs); Vect<FPP,Cpu> _coeffs(K_plus_1, coeffs);
MatDense<FPP,Cpu> basisXi(d, K_plus_1); MatDense<FPP,Cpu> basisXi(d, K_plus_1);
// reshape a d_K_plus_1 vector into a d*K_plus_1 matrix
memcpy(basisXi.getData(), basisX+d_K_plus_1*i, sizeof(FPP)*d_K_plus_1); memcpy(basisXi.getData(), basisX+d_K_plus_1*i, sizeof(FPP)*d_K_plus_1);
// compute the linear combination
_coeffs.multiplyLeft(basisXi); _coeffs.multiplyLeft(basisXi);
memcpy(out+i*d, _coeffs.getData(), sizeof(FPP)*d); memcpy(out+i*d, _coeffs.getData(), sizeof(FPP)*d);
#include <cstdlib>
namespace Faust
* v_{0,k} := [v_{0,k-1} ; v_{1, k-1} ] // concatenation
* v_{1,k} := v_{2,k-1}
* v_{2,k} := 2Lv_{2,k-1} - v_{1,k-1}
* First terms:
* v_{0,1} = []
* v_{1,1} = x
* v_{2,1} = Lx
v2 = L*x;
tmp = v1;
v1 = v2;
v2 = twoL*v2;
v2 -= tmp;
return v0;
// template<typename FPP>
// MatDense<FPP, Cpu> TransformHelperPoly<FPP>::multiply(MatDense<FPP,Cpu> X, const bool transpose/*=false*/, const bool conjugate/*=false*/)
//// std::cout << "TransformHelperPoly<FPP>::multiply(MatDense)" << std::endl;
// int d = L.getNbRow();
// int n = X.getNbCol();
// int K = this->size();
// MatDense<FPP, Cpu> V0(d*(K+1), n);
// MatDense<FPP,Cpu> V1(d, n), V2 = X, tmp;
// memcpy(V1.getData(), X.getData(), sizeof(FPP)*d*n);
// L.multiply(V2, 'N');
// for(int i=2;i<=K;i++)
// memcpy(V0.getData()+d*n*(i-2), V1.getData(), sizeof(FPP)*d*n);
// tmp = V1;
// V1 = V2;
// twoL.multiply(V2, 'N');
// V2 -= tmp;
//// gemm(twoL, V2, tmp, (FPP)1.0, (FPP)-1.0, 'N', 'N');
//// V2 = tmp;
// memcpy(V0.getData()+d*n*(K-1), V1.getData(), sizeof(FPP)*d*n);
// memcpy(V0.getData()+d*n*K, V2.getData(), sizeof(FPP)*d*n);
// // put bocks in proper order
// MatDense<FPP,Cpu> V0_ord(d*(K+1), n);
// #pragma omp parallel for
// for(int i=0;i<(K+1);i++)
// auto i_offset = i*n*d;
// for(int j=0;j<n;j++)
// memcpy(V0_ord.getData()+(K+1)*d*j+d*i, V0.getData()+j*d+i_offset, sizeof(FPP)*d);
// return V0_ord;
auto scale = (K+1)*d;
for(int i=0;i<n;i++)
Vect<FPP,Cpu> x(d, X.getData()+i*d);
auto y = multiply(x);
memcpy(V0_ord.getData()+scale*i, y.getData(), sizeof(FPP)*scale);
return V0_ord;
Vect<FPP, Cpu> TransformHelperPoly<FPP>::poly(MatDense<FPP,Cpu> & basisX, Vect<FPP, Cpu> coeffs)
coeffs.multiplyLeft(basisX);
return coeffs;
MatDense<FPP, Cpu> TransformHelperPoly<FPP>::poly(int n, MatDense<FPP,Cpu> & basisX, Vect<FPP, Cpu> coeffs)
MatDense<FPP,Cpu> Y(d, n);
this->poly(d, n, basisX.getData(), coeffs.getData(), Y.getData());
return Y;
void TransformHelperPoly<FPP>::poly(int d, int n, const FPP* basisX, const FPP* coeffs, FPP* out)
Faust::poly(d, K, n, basisX, coeffs, out);
TransformHelper<FPP, Cpu>* TransformHelperPoly<FPP>::polyFaust(const FPP* coeffs)
// Id = sp.eye(L.shape[1], format="csr")
// scoeffs = sp.hstack(tuple(Id*coeffs[i] for i in range(0, K+1)),
// format="csr")
MatSparse<FPP,Cpu> Id, Id1;
MatSparse<FPP,Cpu> coeffDiags;
auto d = L.getNbRow();
Id.resize(d, d, d);
Id.setEyes();
auto Id0 = Id;
Id0 *= coeffs[0];
// K >= 2
for(int i=1;i < K+1; i++)
Id1 = Id;
Id1 *= coeffs[i];
coeffDiags.hstack(Id0, Id1);
Id0 = coeffDiags;
std::vector<MatGeneric<FPP,Cpu>*> facts(K+1);
facts.resize(K+1);
facts[0] = new MatSparse<FPP,Cpu>(Id0);
for(int i=1;i<=K;i++)
facts[i] = this->get_gen_fact_nonconst(i-1);
return new TransformHelper<FPP,Cpu>(facts, (FPP) 1.0,
/* optimizedCopy */ false,
/* cloning_fact */ false,
/* internal_call */ true);
TransformHelper<FPP,Cpu>* basisChebyshev(MatSparse<FPP,Cpu>* L, int32_t K)
// assuming L is symmetric
MatSparse<FPP,Cpu> *T1, *T2;
auto d = L->getNbRow();
MatSparse<FPP,Cpu> Id, twoL, minus_Id, rR, R, zero;
std::vector<MatGeneric<FPP,Cpu>*> facts(K);
if(K == 0)
return TransformHelper<FPP,Cpu>::eyeFaust(d,d);
facts.resize(K); //normally it'd be K+1 but T0 is ignored
// build the chebyshev polynomials by factor
// K > 1 ignore the first one (for T0 0-degree), which is the identity
// Identity
Id.resize(d, d, d);
Id.setEyes();
// T1
T1 = new MatSparse<FPP,Cpu>();
T1->vstack(Id, *L);
facts[K-1] = T1;
if(K == 1)
return new TransformHelper<FPP,Cpu>(facts, (FPP)1.0,
// rR block
twoL = *L;
twoL *= FPP(2);
minus_Id.resize(d,d,d);
minus_Id.setEyes();
minus_Id *= FPP(-1);
rR.hstack(minus_Id, twoL);
// T2
Id.resize(2*d, 2*d, 2*d);
Id.setEyes();
T2 = new MatSparse<FPP,Cpu>();
T2->vstack(Id, rR);
facts[K-2] = T2;
// T3 to TK
#pragma omp parallel for private(Id, zero, R)
for(int i=3;i<K+1;i++)
Id.resize(i*d, i*d, i*d);
Id.setEyes();
zero.resize(0, d, (i-2)*d);
R.hstack(zero, rR);
auto Ti = new MatSparse<FPP,Cpu>();
Ti->vstack(Id, R);
facts[K-i] = Ti;
auto basisP = new TransformHelperPoly<FPP>(facts, (FPP)1.0,
basisP->L = *L;
basisP->twoL = *L;
basisP->twoL *= 2;
return basisP;
auto K_plus_1 = K+1;
auto d_K_plus_1 = d*K_plus_1;
