Commit 71857df5 authored by hhakim's avatar hhakim
Update matfaust.lazylinop multiplication by scalar to be less costly.
parent 3cde8cdf
...@@ -165,7 +165,7 @@ classdef LazyLinearOp < handle % needed to use references on objects ...@@ -165,7 +165,7 @@ classdef LazyLinearOp < handle % needed to use references on objects
%> @param op: an object compatible with self for this binary operation. %> @param op: an object compatible with self for this binary operation.
function LM = mtimes(L, A) function LM = mtimes(L, A)
import matfaust.lazylinop.LazyLinearOp import matfaust.lazylinop.*
if LazyLinearOp.isLazyLinearOp(A) if LazyLinearOp.isLazyLinearOp(A)
if isscalar(L) if isscalar(L)
LM = mtimes(A, L); LM = mtimes(A, L);
...@@ -176,24 +176,19 @@ classdef LazyLinearOp < handle % needed to use references on objects ...@@ -176,24 +176,19 @@ classdef LazyLinearOp < handle % needed to use references on objects
end end
end end
check_meth(L, 'mtimes'); check_meth(L, 'mtimes');
op_is_scalar = all(size(A) == [1, 1]); A_is_scalar = all(size(A) == [1, 1]);
if ~ op_is_scalar && ~ all(size(L, 2) == size(A, 1)) if ~ A_is_scalar && ~ all(size(L, 2) == size(A, 1))
error('Dimensions must agree') error('Dimensions must agree')
end end
if op_is_scalar
new_size = size(L);
else
new_size = [size(L, 1), size(A, 2)];
function l = mul_index_lambda(L, A, S) function LMI = mul_index_lambda(L, A, S)
% L and A must be LazyLinearOp % L and A must be LazyLinearOp
import matfaust.lazylinop.LazyLinearOp import matfaust.lazylinop.LazyLinearOp
Sr.type = '()'; Sr.type = '()';
Sr.subs = {S.subs{1}, ':'}; Sr.subs = {S.subs{1}, ':'};
Sc.type = '()'; Sc.type = '()';
Sc.subs = {':', S.subs{2}}; Sc.subs = {':', S.subs{2}};
L.lambdas{L.I}(Sr) * A.lambdas{L.I}(Sc); LMI = L.lambdas{L.I}(Sr) * A.lambdas{L.I}(Sc);
end end
if ~ LazyLinearOp.isLazyLinearOp(A) && ismatrix(A) && isnumeric(A) && any(size(A) ~= [1, 1]) if ~ LazyLinearOp.isLazyLinearOp(A) && ismatrix(A) && isnumeric(A) && any(size(A) ~= [1, 1])
...@@ -201,17 +196,19 @@ classdef LazyLinearOp < handle % needed to use references on objects ...@@ -201,17 +196,19 @@ classdef LazyLinearOp < handle % needed to use references on objects
LM = L.lambdas{L.MUL}(A); LM = L.lambdas{L.MUL}(A);
else else
if isscalar(A) if isscalar(A)
LM_size = size(L); matmat = @(M) M * A;
LM = L * LazyLinearOperator([L.size(2), L.size(2)], 'matmat', matmat, 'rmatmat', matmat);
return;
else else
if ~ LazyLinearOp.isLazyLinearOp(A) if ~ LazyLinearOp.isLazyLinearOp(A)
A = LazyLinearOp.create_from_op(A); A = LazyLinearOp.create_from_op(A);
end end
LM_size = [size(L, 1), size(A, 2)] LM_size = [size(L, 1), size(A, 2)];
end end
lambdas = {@(o) L * (A * o), ... %MUL lambdas = {@(o) L * (A * o), ... %MUL
@() A.' * L.', ... % T @() A.' * L.', ... % T
@() A' * L', ... % H @() A' * L', ... % H
@(S) mul_index_lambda(L, A, S)% I @(S) mul_index_lambda(L, A, S)% I
LM = LazyLinearOp(lambdas, LM_size); LM = LazyLinearOp(lambdas, LM_size);
...@@ -590,11 +590,11 @@ class LazyLinearOp(LinearOperator): ...@@ -590,11 +590,11 @@ class LazyLinearOp(LinearOperator):
<b>See also:</b> pyfaust.lazylinop.LazyLinearOp.__matmul__) <b>See also:</b> pyfaust.lazylinop.LazyLinearOp.__matmul__)
self._checkattr('__mul__') self._checkattr('__mul__')
from scipy.sparse import eye
if np.isscalar(other): if np.isscalar(other):
S = eye(self.shape[1], format='csr') * other Dshape = (self.shape[1], self.shape[1])
lop = LazyLinearOp.create_from_op(S) matmat = lambda M: M * other
new_op = self @ lop D = LazyLinearOperator(Dshape, matmat=matmat, rmatmat=matmat)
new_op = self @ D
else: else:
new_op = self @ other new_op = self @ other
return new_op return new_op
