Commit 71849edf authored by hhakim's avatar hhakim
Update win installer script since CUDA9.2 support has been removed.
parent 9caa4a4e
...@@ -107,7 +107,6 @@ Section "" ; no component so name not needed ...@@ -107,7 +107,6 @@ Section "" ; no component so name not needed
; install gpu mod lib ; install gpu mod lib
CreateDirectory $INSTDIR\lib CreateDirectory $INSTDIR\lib
SetOutPath $INSTDIR\lib SetOutPath $INSTDIR\lib
File @PROJECT_BINARY_DIR@\..\gpu_mod\build-cu9.2\gm-cu9.2.dll
File @PROJECT_BINARY_DIR@\..\gpu_mod\build-cu11.4\gm-cu11.4.dll File @PROJECT_BINARY_DIR@\..\gpu_mod\build-cu11.4\gm-cu11.4.dll
; install python wrapper ; install python wrapper
...@@ -158,7 +157,6 @@ Section "" ; no component so name not needed ...@@ -158,7 +157,6 @@ Section "" ; no component so name not needed
SetOutPath $2\pyfaust SetOutPath $2\pyfaust
File /r @PROJECT_BINARY_DIR@\wrapper\python\pyfaust\*py File /r @PROJECT_BINARY_DIR@\wrapper\python\pyfaust\*py
SetOutPath $2\pyfaust\lib SetOutPath $2\pyfaust\lib
; CreateShortCut pyfaust @PROJECT_BINARY_DIR@\wrapper\python\pyfaust ; tested and it can't be like a linux symlink ; CreateShortCut pyfaust @PROJECT_BINARY_DIR@\wrapper\python\pyfaust ; tested and it can't be like a linux symlink
SetOutPath $2 SetOutPath $2
