Commit 70895bde authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
new main cmakelist
parent e78c64d2
...@@ -183,7 +183,7 @@ option(BUILD_TESTING "Build Tests" ON) ...@@ -183,7 +183,7 @@ option(BUILD_TESTING "Build Tests" ON)
#Allows generating the doc: #Allows generating the doc:
option(BUILD_DOCUMENTATION "Generating the doxygen documentation." OFF) option(BUILD_DOCUMENTATION "Generating the doxygen documentation." OFF)
# Allows multithreading: # Allows multithreading:
option(BUILD_MULTITHREAD "Enable multithread with OpenMP Multithreading." ON) option(BUILD_MULTITHREAD "Enable multithread with OpenMP Multithreading." OFF)
# Allows verbose: # Allows verbose:
option(BUILD_VERBOSE "Enable verbose option when compile (-v)." OFF) option(BUILD_VERBOSE "Enable verbose option when compile (-v)." OFF)
# Allows MPTK Debug: # Allows MPTK Debug:
...@@ -412,14 +412,19 @@ file(MAKE_DIRECTORY ${FAUST_BIN_TEST_OUTPUT_DIR}) ...@@ -412,14 +412,19 @@ file(MAKE_DIRECTORY ${FAUST_BIN_TEST_OUTPUT_DIR})
file(MAKE_DIRECTORY ${FAUST_BIN_TEST_FIG_DIR}) file(MAKE_DIRECTORY ${FAUST_BIN_TEST_FIG_DIR})
file(MAKE_DIRECTORY ${FAUST_BIN_TEST_TMP_DIR}) file(MAKE_DIRECTORY ${FAUST_BIN_TEST_TMP_DIR})
if (BUILD_MATLAB_MEX_FILES)
file(MAKE_DIRECTORY ${FAUST_DEMO_BSL_OUTPUT_BIN_DIR})
install(DIRECTORY ${FAUST_DEMO_BSL_OUTPUT_BIN_DIR} DESTINATION ${FAUST_DEMO_BSL_OUTPUT_INSTALL_DIR}) # [FILE_PERMISSIONS permissions...]
file(MAKE_DIRECTORY ${FAUST_DEMO_HADAMARD_OUTPUT_BIN_DIR}) # [DIRECTORY_PERMISSIONS permissions...]
install(DIRECTORY ${FAUST_DEMO_HADAMARD_OUTPUT_BIN_DIR} DESTINATION ${FAUST_DEMO_HADAMARD_OUTPUT_INSTALL_DIR})
file(MAKE_DIRECTORY ${FAUST_DEMO_FIG_BIN_DIR}) #if (BUILD_MATLAB_MEX_FILES)
install(DIRECTORY ${FAUST_DEMO_FIG_BIN_DIR} DESTINATION ${FAUST_DEMO_INSTALL_DIR}) # file(MAKE_DIRECTORY ${FAUST_DEMO_BSL_OUTPUT_BIN_DIR})
endif (BUILD_MATLAB_MEX_FILES) #install(DIRECTORY ${FAUST_DEMO_BSL_OUTPUT_BIN_DIR} DESTINATION ${FAUST_DEMO_BSL_OUTPUT_INSTALL_DIR} FILE_PERMISSIONS OWNER_READ OWNER_WRITE OWNER_EXECUTE GROUP_READ GROUP_WRITE GROUP_EXECUTE WORLD_READ WORLD_WRITE WORLD_EXECUTE SETUID SETGID DIRECTORY_PERMISSIONS OWNER_READ OWNER_WRITE OWNER_EXECUTE GROUP_READ GROUP_WRITE GROUP_EXECUTE WORLD_READ WORLD_WRITE WORLD_EXECUTE SETUID SETGID)
# file(MAKE_DIRECTORY ${FAUST_DEMO_HADAMARD_OUTPUT_BIN_DIR})
#install(DIRECTORY ${FAUST_DEMO_HADAMARD_OUTPUT_BIN_DIR} DESTINATION ${FAUST_DEMO_HADAMARD_OUTPUT_INSTALL_DIR} FILE_PERMISSIONS OWNER_READ OWNER_WRITE OWNER_EXECUTE GROUP_READ GROUP_WRITE GROUP_EXECUTE WORLD_READ WORLD_WRITE WORLD_EXECUTE SETUID SETGID DIRECTORY_PERMISSIONS OWNER_READ OWNER_WRITE OWNER_EXECUTE GROUP_READ GROUP_WRITE GROUP_EXECUTE WORLD_READ WORLD_WRITE WORLD_EXECUTE SETUID SETGID)
# file(MAKE_DIRECTORY ${FAUST_DEMO_FIG_BIN_DIR})
#install(DIRECTORY ${FAUST_DEMO_FIG_BIN_DIR} DESTINATION ${FAUST_DEMO_INSTALL_DIR} FILE_PERMISSIONS OWNER_READ OWNER_WRITE OWNER_EXECUTE GROUP_READ GROUP_WRITE GROUP_EXECUTE WORLD_READ WORLD_WRITE WORLD_EXECUTE SETUID SETGID DIRECTORY_PERMISSIONS OWNER_READ OWNER_WRITE OWNER_EXECUTE GROUP_READ GROUP_WRITE GROUP_EXECUTE WORLD_READ WORLD_WRITE WORLD_EXECUTE SETUID SETGID)
#endif (BUILD_MATLAB_MEX_FILES)
...@@ -700,7 +705,7 @@ SET(CPACK_RESOURCE_FILE_WELCOME "${PROJECT_SOURCE_DIR}/README.txt") ...@@ -700,7 +705,7 @@ SET(CPACK_RESOURCE_FILE_WELCOME "${PROJECT_SOURCE_DIR}/README.txt")
# SOURCE DISTRIBUTION: # SOURCE DISTRIBUTION:
set(CPACK_SOURCE_PACKAGE_FILE_NAME "FAUST-Source-${FAUST_VERSION_MAJOR}.${FAUST_VERSION_MINOR}.${FAUST_VERSION_PATCH}") set(CPACK_SOURCE_PACKAGE_FILE_NAME "FAUST-Source-${FAUST_VERSION_MAJOR}.${FAUST_VERSION_MINOR}.${FAUST_VERSION_PATCH}")
set(CPACK_SOURCE_IGNORE_FILES "/build/;/.bzr/;/CMakeFiles/;/_CPack_Packages/;/.svn/;/.git/;/headerCPP.txt;/headerMatlab.txt;/gen_doc/LaTeX/images/") set(CPACK_SOURCE_IGNORE_FILES "/build/;/.bzr/;/CMakeFiles/;/_CPack_Packages/;/.svn/;/.git/;/headerCPP.txt;/headerMatlab.txt;/gen_doc/LaTeX/images/;/./misc/data/txt/")
if(WIN32 AND NOT UNIX) if(WIN32 AND NOT UNIX)
set(CPACK_SOURCE_IGNORE_FILES "${CPACK_SOURCE_IGNORE_FILES};/externals/unix/;/externals/win/eigen*/;/externals/win/OpenBLAS-v0.2.14-Win64-int64/;/externals/win/eigen-eigen-07105f7124f9/;") set(CPACK_SOURCE_IGNORE_FILES "${CPACK_SOURCE_IGNORE_FILES};/externals/unix/;/externals/win/eigen*/;/externals/win/OpenBLAS-v0.2.14-Win64-int64/;/externals/win/eigen-eigen-07105f7124f9/;")
