GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.3.
Show more breadcrumbs
faust group
faust
6d5153a0
6d5153a0
2 years ago
hhakim
Downloads
Patches
Add a Faust::bsrgemm GPU2 unit test.
c1e9b12e
misc/test/src/C++/test_matbsr_gpu_mod.cpp.in
+49
49 additions, 0 deletions
49 additions
49
6d5153a0
@@ -359,9 +359,58 @@ void test_transform_rand_bsr()
delete F;
delete F;
void test_bsrgemm()
std::cout << "test_bsrgemm" << std::endl;
char A_ops[3] = {'N', 'T', 'H'};
for(int i=0; i < sizeof(A_ops); i++)
auto A_op = A_ops[i];
auto B_op = A_op;
// gen a cpu random dense matrix
MatDense<FPP, Cpu> *cpu_dmat = MatDense<FPP, Cpu>::randMat(10, 15);
//cpu_dmat->multiply(*cpu_dmat, 'T');
//cpu_dmat->setOnes();
// convert it to gpu
MatDense<FPP, GPU2> gpu_dmat(*cpu_dmat);
MatDense<FPP, GPU2> gpu_outmat;
MatDense<FPP, GPU2> cpu_outmat(*cpu_dmat);
// idem for bsr mats
auto cpu_bmat = MatBSR<FPP, Cpu>::randMat(15, 10, 5, 5, 2);
auto cpu_bmat_dmat = cpu_bmat->to_dense();
MatBSR<FPP, GPU2> gpu_bmat(*cpu_bmat);
if(B_op == 'T')
cpu_dmat->transpose();
else if(B_op == 'H')
cpu_dmat->adjoint();
// multiply on cpu
cpu_bmat->multiply(*cpu_dmat, A_op);
// if(A_op == 'T') gpu_bmat.transpose();
std::cout << "brsgemm(bsr, dense, '"<< A_op<<"', '"<< A_op<<"')" << std::endl;
bsrgemm(gpu_bmat, gpu_dmat, gpu_outmat, FPP(1.0), FPP(0), A_op, B_op);
MatDense<FPP, Cpu> diff_mat;
gpu_outmat.tocpu(diff_mat);
diff_mat -= *cpu_dmat;
assert(diff_mat.norm() < 1e-3);
std::cout << "OK" << std::endl;
delete cpu_bmat;
delete cpu_dmat;
int main()
int main()
Faust::enable_gpu_mod();
test_bsrgemm();
test_gpu_ctor_and_tocpu();
test_gpu_mul_dense();
test_gpu_mul_vec();
test_gpu_mul_vec();
This diff is collapsed.
Loading
Save comment
