Commit 6a026052 authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
debug findmatlab
parent af622671
......@@ -68,24 +68,22 @@ elseif(WIN32)
#message(STATUS "contents2tmp=${contents2tmp}")
#message(STATUS "contents2=${contents2}")
set(MATLAB_EXE_DIR_TMP "${contents1}")
set(MATLAB_EXE_DIR_FILE_PATH "${contents1}")
#set(MATLAB_EXE_DIR_TMP2 "${contents2}")
message(STATUS "MATLAB_EXE_DIR=${MATLAB_EXE_DIR_TMP}")
#message(STATUS "MATLAB_EXE_DIR=${MATLAB_EXE_DIR_TMP}")
#message(STATUS "MATLAB_EXE_DIR_TMP2=${MATLAB_EXE_DIR_TMP2}")
if ($ENV{MATLAB_EXE_DIR}} MATCHES matlab)
set(MATLAB_DIR_TMP $ENV{MATLAB_EXE_DIR})
message(STATUS "MATLAB_DIR_TMP=$ENV{MATLAB_EXE_DIR} defined from environment variable")
elseif (${MATLAB_EXE_DIR} MATCHES matlab)
#message(STATUS "MATLAB_DIR_TMP = ${MATLAB_EXE_DIR_TMP}")
set(MATLAB_DIR_TMP ${MATLAB_EXE_DIR})
message(STATUS "MATLAB_DIR_TMP=${MATLAB_EXE_DIR} defined from local input variable")
elseif (${MATLAB_EXE_DIR_TMP} MATCHES matlab)
set(MATLAB_DIR_TMP ${MATLAB_EXE_DIR_TMP})
elseif (${MATLAB_EXE_DIR_FILE_PATH} MATCHES matlab)
set(MATLAB_DIR_TMP ${MATLAB_EXE_DIR_FILE_PATH})
else()
message(STATUS "MATLAB_DIR_TMP = $ENV{MATLAB_EXE_DIR}")
message(STATUS "MATLAB_DIR_TMP is not available. It corresponds to the path of matlab.exe }")
#message(STATUS "MATLAB_DIR_TMP = $ENV{MATLAB_EXE_DIR}")
message(STATUS "MATLAB_EXE_DIR is not available. It corresponds to the path of matlab.exe }")
message(FATAL_ERROR "Unknown path of matlab.exe. Please add environment variable MATLAB_EXE_DIR ")
endif()
......@@ -106,8 +104,8 @@ if( ${MATLAB_DIR_TMP} MATCHES "matlab")
#message(STATUS "MATLAB_ROOT TMP2: ${MATLAB_ROOT}")
if( ${MATLAB_ROOT} MATCHES "matlab") # Dans ce cas, le remplacment ne s'est pas fait.. on essaie avec la double separation "//"
string(REGEX REPLACE "([a-zA-Z0-9_/:.]+)/bin//matlab" "\\1" MATLAB_ROOT "${MATLAB_DIR_TMP}") # ds le cas ou on a /bin// matlab
message(STATUS "MATLAB_DIR_TMP3 ${MATLAB_DIR_TMP}")
message(STATUS "MATLAB_ROOT TMP3: ${MATLAB_ROOT}")
message(STATUS "MATLAB_DIR_TMP=${MATLAB_DIR_TMP}")
message(STATUS "MATLAB_ROOT TMP=${MATLAB_ROOT}")
endif()
elseif(WIN32)
......@@ -4,7 +4,7 @@ set(SRC_FILES "")
file(GLOB CPP_FILES "${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.cpp" "${FAUST_ALGORITHM_FACTORIZATION_SRC_DIR}/*.cpp")
message(STATUS "algorithm cpp files ${CPP_FILES}")
#message(STATUS "algorithm cpp files ${CPP_FILES}")
#${FAUST_EXCEPTION_SRC_DIR}
include_directories(${FAUST_SRC_LINEAR_OPERATOR_DIR} ${FAUST_LINEAR_OPERATOR_CPU_SRC_DIR} ${EIGEN_INC_DIR})
......@@ -29,7 +29,7 @@ if (BUILD_USE_GPU)
# elseif(WIN32 AND FAUST_USE_MKL)
# set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /openmp")
# endif()
message(STATUS "CMAKE_CXX_FLAGS=${CMAKE_CXX_FLAGS}")
#message(STATUS "CMAKE_CXX_FLAGS=${CMAKE_CXX_FLAGS}")
#add_definitions(-D__COMPILE_GPU__ -D__COMPILE_SPMAT__)
add_library(${FAUST_ALGORITHM_CU_TARGET} OBJECT ${CPP_FILES})
endif()
