GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
faust group
faust
695ef4f8
695ef4f8
9 years ago
Adrien Leman
Committed by
hhakim
2 years ago
Downloads
Patches
debug lib externale
0445b609
2
2 changed files
CMake/findExternalLibs.cmake
+3
-3
3 additions, 3 deletions
CMake/findMatlab.cmake
+1
-1
1 addition, 1 deletion
4 additions
4 deletions
3
3
695ef4f8
@@ -31,8 +31,8 @@ message(STATUS "******* Check externals library ***********")
# Default path library (where the library is automatically install)
add_library_path
LIBRARY_PATH_LIST_TMP_DEFAULT
"/opt/OpenBLAS"
add_library_path
"/opt/OpenBLAS"
PROJECT_SOURCE_DIR
/externals/unix/OpenBLAS"
PROJECT_SOURCE_DIR
"/usr/local"
#pour matio et xml2
"/usr/local" #pour matio et xml2
"/usr/local/lib"
#pour matio et xml2
"/usr/local/lib" #pour matio et xml2
"/usr/local/lib64"
#pour matio et xml2
"/usr/local/lib64"
#pour matio et xml2
PROJECT_SOURCE_DIR
/externals/unix/matio/src/.libs"
#pour matio
PROJECT_SOURCE_DIR
#pour matio
PROJECT_SOURCE_DIR
/externals/unix/libxml2/.libs"
# pour libxml
PROJECT_SOURCE_DIR
# pour libxml
@@ -42,7 +42,7 @@ add_include_path(INCLUDE_PATH_LIST_TMP_DEFAULT "/opt/OpenBLAS"
PROJECT_SOURCE_DIR
PROJECT_SOURCE_DIR
"/usr/include/eigen3"
PROJECT_SOURCE_DIR
/externals/unix/eigen"
PROJECT_SOURCE_DIR
"/usr/local"
#pour matio et xml2
"/usr/include/libxml2"
PROJECT_SOURCE_DIR
/externals/unix/matio/src"
#pour matio
PROJECT_SOURCE_DIR
#pour matio
PROJECT_SOURCE_DIR
/externals/unix/libxml2/include"
# pour libxml
PROJECT_SOURCE_DIR
# pour libxml
This diff is collapsed.
695ef4f8
@@ -50,7 +50,7 @@ endif()
if
MATLAB_DIR_TMP
MATCHES
"matlab"
if
MATLAB_DIR_TMP
MATCHES
"matlab"
if
UNIX
if
UNIX
# string(REGEX REPLACE "([a-zA-Z0-9_/:]+)/bin/matlab" "\\1" MATLAB_ROOT "${MATLAB_DIR_TMP}")
string
REGEX REPLACE
"([a-zA-Z0-9_/:.]+)/bin/matlab"
1"
MATLAB_ROOT
MATLAB_DIR_TMP
# sous mac on a un point ds le path .app
string
REGEX REPLACE
"([a-zA-Z0-9_/:.
]+)/bin/matlab"
1"
MATLAB_ROOT
MATLAB_DIR_TMP
elseif
WIN32
elseif
WIN32
string
REGEX REPLACE
"([a-zA-Z0-9_
bin
matlab.exe"
1"
MATLAB_ROOT
MATLAB_DIR_TMP
string
REGEX REPLACE
"([a-zA-Z0-9_
bin
matlab.exe"
1"
MATLAB_ROOT
MATLAB_DIR_TMP
else
else
Loading
Save comment
