Commit 68d8961f authored by hhakim's avatar hhakim
Minor fix in API doc of pyfaust/matfaust.
parent da1d4480
......@@ -652,6 +652,8 @@ classdef Faust
%> @brief Returns a new Faust whose class is single. It allows to convert all the factors to single precision.
%> @b Usage
%>     @b sF = single(F)
......@@ -3019,9 +3019,9 @@ class FaustMulMode:
## \brief The default method, it computes the product from the right to the left.
DEFAULT_L2R=0
## \brief This method implements the classic dynamic programming solution
## \brief This method implements the classic dynamic programming solution to the chain matrix problem.
## to the chain matrix problem (see https://en.wikipedia.org/wiki/Matrix_chain_multiplication#A_dynamic_programming_algorithm).
## See https://en.wikipedia.org/wiki/Matrix_chain_multiplication#A_dynamic_programming_algorithm.
## Note that the standard method is extended in order to take into account the complexity of multiplications including a sparse matrix (because that's not the same cost than multiplying dense matrices).
DYNPROG=5
## \brief This method computes the product of the matrix chain from the left to the right using the Torch C++ library (CPU backend).
......@@ -1289,7 +1289,7 @@ def butterfly(M, type="right"):
>>> from pyfaust import Faust, wht, dft
>>> from pyfaust.fact import butterfly
>>> H = wht(32).toarray() # it works with dft too!
>>> F = butterfly(H, dir='bbtree')
>>> F = butterfly(H, type='bbtree')
>>> (F-H).norm()/Faust(H).norm()
1.0272844187006565e-15
