Commit 67a4ff35 authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
test xcode
parent 9046cba0
...@@ -601,7 +601,9 @@ else (BUILD_USE_GPU) ...@@ -601,7 +601,9 @@ else (BUILD_USE_GPU)
if(APPLE AND ( CMAKE_GENERATOR STREQUAL "Xcode") ) if(APPLE AND ( CMAKE_GENERATOR STREQUAL "Xcode") )
message (STATUS "------------------------------------------ ") message (STATUS "------------------------------------------ ")
message (STATUS "APPLE AND Xcode ${FAUST_ALGORITHM_TARGET} ${FAUST_ALGORITHM_BIN_DIR}") message (STATUS "APPLE AND Xcode ${FAUST_ALGORITHM_TARGET} ${FAUST_ALGORITHM_BIN_DIR}")
include_directories(${FAUST_SRC_LINEAR_OPERATOR_DIR} ${FAUST_LINEAR_OPERATOR_CPU_SRC_DIR} ${EIGEN_INC_DIR})
add_library(${FAUST_TARGET} STATIC ${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.cpp" "${FAUST_ALGORITHM_FACTORIZATION_SRC_DIR}/*.cpp ${FAUST_LINEAR_OPERATOR_TARGET} ${FAUST_MEXTOOLS_TARGET} ) add_library(${FAUST_TARGET} STATIC ${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.cpp" "${FAUST_ALGORITHM_FACTORIZATION_SRC_DIR}/*.cpp ${FAUST_LINEAR_OPERATOR_TARGET} ${FAUST_MEXTOOLS_TARGET} )
else () else ()
add_library(${FAUST_TARGET} STATIC $<TARGET_OBJECTS:${FAUST_LINEAR_OPERATOR_TARGET}> $<TARGET_OBJECTS:${FAUST_ALGORITHM_TARGET}> $<TARGET_OBJECTS:${FAUST_MEXTOOLS_TARGET}> ) add_library(${FAUST_TARGET} STATIC $<TARGET_OBJECTS:${FAUST_LINEAR_OPERATOR_TARGET}> $<TARGET_OBJECTS:${FAUST_ALGORITHM_TARGET}> $<TARGET_OBJECTS:${FAUST_MEXTOOLS_TARGET}> )
