Commit 661bed1d authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
latex doc
parent 526b43f2
...@@ -91,17 +91,12 @@ ...@@ -91,17 +91,12 @@
\newpage \newpage
\include{chapIntroduction} \include{chapIntroduction}
\include{chapInstall} \include{chapInstall}
\include{chapFirstUse} \include{chapFirstUse}
\include{chapExample} \include{chapExample}
%\section{Examples}\label{sec:example}
%\section{Other functions}\label{sec:other}
\bibliographystyle{plain} \bibliographystyle{plain}
\bibliography{paperbiblio} \bibliography{paperbiblio}
\chapter{Installation}\label{sec:install} \chapter{Installation}\label{sec:install}
The FA$\mu$ST project is based on an C++ library available for both UNIX and Windows environments. CMake has been choose to build the project FA$\mu$ST because it is an open-source, cross-platform family of tools designed to build, test and package software (cf. website \url{https://cmake.org/}). The FA$\mu$ST project is based on an C++ library available for both UNIX and Windows environments. CMake has been choose to build the project FA$\mu$ST because it is an open-source, cross-platform family of tools designed to build, test and package software (cf. website \url{https://cmake.org/}).
...@@ -7,6 +6,30 @@ First section \ref{sec:UnixInstall} gives information about Unix installation an ...@@ -7,6 +6,30 @@ First section \ref{sec:UnixInstall} gives information about Unix installation an
\section{Unix platform}\label{sec:UnixInstall} \section{Unix platform}\label{sec:UnixInstall}
\subsection{Prerequisities for installation}\label{sec:UnixPrerequisitiesInstall}
\paragraph{}The use of the mex function in Matlab require that you have a third-party compiler installed on your system. The latest version of Matlab (2016a in our case) only supports up to GCC 4.7 (see \url{http://fr.mathworks.com/support/compilers/R2016a/index.html?sec=glnxa64} for more detail). Please adjust your version of GCC compiler in order to run the installation properly.
\paragraph{}The use of GPU process in FAUST project required the drivers for NVIDIA and CUDA install.
\paragraph{}In your environment PATH, please add following components :
\begin{itemize}
\item matlab (example: "export PATH=/usr/local/bin:\$PATH")
\item nvcc for GPU compiler (example: "export PATH=/usr/local/cuda-X.X/bin:\$PATH"
\end{itemize}
\paragraph{}Please export following variable:
\begin{itemize}
\item CC with gcc (example: "export CC='/usr/lib64/ccache/gcc'")
\item CXX with g++ (example: "export CXX=/usr/lib64/ccache/g++
\end{itemize}
\subsection{FAUST installation}\label{sec:UnixFaustInstall}
When prerequisities listed in precedent section \ref{sec:UnixPrerequisitiesInstall} are checked, the FA$\mu$ST installation can be done :
\begin{itemize} \begin{itemize}
\item Download the FA$\mu$ST package on the website : \url{http://faust.gforge.inria.fr/} \item Download the FA$\mu$ST package on the website : \url{http://faust.gforge.inria.fr/}
\item Open a command terminal \item Open a command terminal
...@@ -20,11 +43,32 @@ make install ...@@ -20,11 +43,32 @@ make install
\end{lstlisting} \end{lstlisting}
\end{itemize} \end{itemize}
\subsection{Optional PreRequisite - Advanced Installer}\label{sec:UnixOptionalInstall}
The project FAUST can be configured with optional parameters. They can be activated in the principal CMakeList.txt file, or directly by the cmake command line
$cmake\ ..\ -DBUILD\_OPTION=ON$
\begin{itemize}
\item BUILD\_TESTING : Enable the ctest option (default value is ON)
\item BUILD\_DOCUMENTATION : Generating the doxygen documentation (default value is OFF)
\item BUILD\_MULTITHREAD : Enable multithread with OpenMP Multithreading (default value is OFF)
\item BUILD\_VERBOSE : Enable verbose option when compile (-v) (default value is OFF)
\item BUILD\_DEBUG : Enable FAUST Debug mode (default value is OFF )
\item BUILD\_USE\_GPU : Using both CPU and GPU process ( default value is OFF)
\item BUILD\_MATLAB\_MEX\_FILES : Enable building Matlab MEX files (default value is ON)
\item BUILD\_OPENBLAS : Using openBLAS for matrix and vector computations (default value is OFF )
\item BUILD\_READ\_XML\_FILE : Using xml2 library to read xml files (default value is OFF)
\item BUILD\_READ\_MAT\_FILE : Using matio library to read mat files (default value is OFF)
\end{itemize}
Following the selected option, the cmake installer automatically check the dependent component (OpenBlas, eigen, matio, libxml2).
\section{Windows platform}\label{sec:WinInstall} \section{Windows platform}\label{sec:WinInstall}
\subsection{Prerequisities for installation}\label{sec:WinPrerequisitiesInstall} \subsection{Prerequisities for installation}\label{sec:WinPrerequisitiesInstall}
The installation of the FA$\mu$ST project depend on other components to be installed in order to run properly. The installation of the FA$\mu$ST project depends on other components to be installed in order to run properly.
\begin{enumerate} \begin{enumerate}
\item \textbf{Install MinGW} "Minimalist GNU for Windows" \url{http://www.mingw.org/} \item \textbf{Install MinGW} "Minimalist GNU for Windows" \url{http://www.mingw.org/}
\url{https://sourceforge.net/projects/mingw/files/latest/download?source=files} \url{https://sourceforge.net/projects/mingw/files/latest/download?source=files}
...@@ -73,3 +117,9 @@ make install ...@@ -73,3 +117,9 @@ make install
\subsection{Optional PreRequisite - Advanced Installer}\label{sec:WinOptionalInstall}
progress...
