Commit 64b10c50 authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
cmakelist modif
parent bf068ced
...@@ -79,10 +79,6 @@ message (STATUS "CMAKE_INSTALL_PREFIX=${CMAKE_INSTALL_PREFIX}") ...@@ -79,10 +79,6 @@ message (STATUS "CMAKE_INSTALL_PREFIX=${CMAKE_INSTALL_PREFIX}")
# default location of library is in the path # default location of library is in the path
set(FAUST_INSTALL_LIB "${CMAKE_INSTALL_PREFIX}" CACHE STRING "default install path for the library faust" FORCE ) set(FAUST_INSTALL_LIB "${CMAKE_INSTALL_PREFIX}" CACHE STRING "default install path for the library faust" FORCE )
# set(FAUST_INSTALL_BIN "$ENV{HOME}/Documents/faust/bin" CACHE STRING "default install path for the binary faust" FORCE ) # set(FAUST_INSTALL_BIN "$ENV{HOME}/Documents/faust/bin" CACHE STRING "default install path for the binary faust" FORCE )
# set(FAUST_INSTALL_BIN_TIME_COMP "$ENV{HOME}/Documents/faust/bin/runtime_comparison" CACHE STRING "default install path for the binary faust" FORCE )
# set(FAUST_INSTALL_DOC "$ENV{HOME}/Documents/faust/doc" CACHE STRING "default install path for the documentation faust" FORCE )
# set(FAUST_INSTALL_CMDLINE "$ENV{HOME}/Documents/faust/CmdLine" CACHE STRING "default install path for the cmd faust" FORCE )
# set(FAUST_INSTALL_TESTING_DATA "$ENV{HOME}/Documents/faust/testing/data" CACHE STRING "default install path for the test faust" FORCE )
set(FAUST_INSTALL_BIN "${PROJECT_BINARY_DIR}/output/bin" CACHE STRING "default install path for the binary faust" FORCE ) set(FAUST_INSTALL_BIN "${PROJECT_BINARY_DIR}/output/bin" CACHE STRING "default install path for the binary faust" FORCE )
set(FAUST_INSTALL_BIN_TIME_COMP "${PROJECT_BINARY_DIR}/output/bin/runtime_comparison" CACHE STRING "default install path for the binary faust" FORCE ) set(FAUST_INSTALL_BIN_TIME_COMP "${PROJECT_BINARY_DIR}/output/bin/runtime_comparison" CACHE STRING "default install path for the binary faust" FORCE )
set(FAUST_INSTALL_DOC "${PROJECT_BINARY_DIR}/output/doc" CACHE STRING "default install path for the documentation faust" FORCE ) set(FAUST_INSTALL_DOC "${PROJECT_BINARY_DIR}/output/doc" CACHE STRING "default install path for the documentation faust" FORCE )
