GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
faust group
faust
64a24646
64a24646
8 years ago
Adrien Leman
Committed by
hhakim
2 years ago
Downloads
Patches
modif ctest for windows
48a69f35
2
2 changed files
misc/CTest_nightly/faustTest.cmake
+1
-1
1 addition, 1 deletion
misc/CTest_nightly/run_nightly_windows.bat
+4
-1
4 additions, 1 deletion
5 additions
2 deletions
64a24646
@@ -7,7 +7,7 @@ CMAKE_MINIMUM_REQUIRED(VERSION 2.8.4)
IF
WIN32
#SET(CTEST_CMAKE_GENERATOR "Visual Studio 9 2008")
SET
"MinGW Makefiles"
SET (CTEST_CMAKE_GENERATOR "MinGW Makefiles")
SET
CTEST_SOURCE_DIRECTORY
"faust_test"
SET
CTEST_BINARY_DIRECTORY
"faust_test_build"
SET
CTEST_INSTALL_DIR
"faust_output"
This diff is collapsed.
4
64a24646
@@ -33,7 +33,10 @@ REM # export version of gcc
set
CC
C
:\mingw
-w
64
\mingw64\bin\gcc.exe
set
CXX
C
:\mingw
-w
64
\mingw64\bin\g
.exe
set
matlab
"C:\Program Files\MATLAB\R2015b\bin\matlab.exe"
REM The compiler used is MinGW for windows
set
"MinGW Makefiles"
REM set matlab="C:\Program Files\MATLAB\R2015b\bin\matlab.exe"
REM # /usr/local/bin/matlab in the PATH
REM #export PATH=/usr/local/bin:$PATH
REM # cuda in the PATH
Loading
Save comment
