GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
faust group
faust
62d274d1
62d274d1
1 year ago
hhakim
Downloads
Patches
Ignore temporarily cython warning about IF-ELSE (issue #326).
e1b84251
Pipeline
#897577
failed
1 year ago
Stage: test
.gitlab-ci.yml
+1
-1
1 addition, 1 deletion
.gitlab-ci.yml
1 addition
1 deletion
.gitlab-ci.yml
62d274d1
@@ -78,7 +78,7 @@ ctest_python:
export LD_PRELOAD=/usr/lib64/libomp.so
variables
BUILD_WRAPPER_PYTHON
ON"
SLOW_TESTS
OFF"
DONT_PYPLOT_FAUST_TIME
ON"
NOCPPTESTS
ON"
NOPY2
ON"
BUILD_MULTITHREAD
ON"
BUILD_FLOAT_PYX
ON"
NJOBS
4
#, GIT_STRATEGY: none}
variables
ON"
SLOW_TESTS
OFF"
ON"
NOCPPTESTS
ON"
NOPY2
ON"
BUILD_MULTITHREAD
ON"
BUILD_FLOAT_PYX
ON"
NJOBS
4
script
script
ctest -O ctest.log -S ./CDashConfScript.cmake -j4 --output-junit junit_output.xml
|| echo "forcing job to continue"
ctest -O ctest.log -S ./CDashConfScript.cmake -j4 --output-junit junit_output.xml || echo "forcing job to continue"
if [[ ! -r build_FaustLinuxPython/junit_output.xml ]]; then exit 1;fi
misc/continuous_integration/jobs/junit_html_report.sh python_pyfaust_test_output
# fail the ci job if any ctest test (or unit test) have failed
This diff is collapsed.
Loading
Save comment
