Commit 5f36e6f2 authored by hhakim's avatar hhakim
Add pyfaust.Faust methods: average, asarray and astype.
parent 9af7ad25
...@@ -11,6 +11,7 @@ import _FaustCorePy ...@@ -11,6 +11,7 @@ import _FaustCorePy
import pyfaust import pyfaust
import pyfaust.factparams import pyfaust.factparams
import warnings import warnings
import decimal
class Faust: class Faust:
"""<b>FAuST Python wrapper main class</b> for using multi-layer sparse transforms. """<b>FAuST Python wrapper main class</b> for using multi-layer sparse transforms.
...@@ -1580,6 +1581,20 @@ class Faust: ...@@ -1580,6 +1581,20 @@ class Faust:
if(format == "Matlab"): if(format == "Matlab"):
F.m_faust.save_mat_file(filepath) F.m_faust.save_mat_file(filepath)
def astype(F, dtype):
#TODO: full list of numpy args or **kw_unknown
if(dtype == F.dtype):
return F.clone(dev=F.device)
elif dtype == np.complex:
return F*np.complex(1,0)
else:
raise ValueError("complex -> float conversion not yet supported.")
def asarray(F):
print('Faust.asarray')
return F
@property @property
def dtype(F): def dtype(F):
...@@ -1774,6 +1789,77 @@ class Faust: ...@@ -1774,6 +1789,77 @@ class Faust:
else: else:
return Faust([F.factors(i) for i in range(F.numfactors())], dev=dev) return Faust([F.factors(i) for i in range(F.numfactors())], dev=dev)
def average(F, axis=None, weights=None, returned=False):
if axis == None:
axis = (0, 1)
if not (isinstance(axis, int) or isinstance(axis, tuple) and
isinstance(axis[0], int) and isinstance(axis[1], int)):
raise TypeError('axis must be int or tuple of ints')
if not isinstance(weights, np.ndarray) and weights == None:
def_rweights = ones((1, F.shape[0]))
def_cweights = ones((F.shape[1], 1))
if isinstance(axis, int):
if axis == 0:
weights = def_rweights
elif axis == 1:
weights = def_cweights
elif isinstance(axis, tuple):
return F.average(axis=0,
weights=def_rweights,
returned=returned).average(axis=1,
weights=def_cweights,
returned=returned)
if not isinstance(weights, np.ndarray):
weights = np.array(weights)
if weights.shape != F.shape and weights.ndim != 1:
raise TypeError("1D weights expected when shapes of a and weights"
" differ.")
if weights.shape == F.shape:
aF = Faust([(weights[:,0].T).reshape(1,F.shape[0])])*F[:,0]
for i in range(1,F.shape[1]):
aF = pyfaust.hstack((aF, Faust([(weights[:,i].T).reshape(1,
F.shape[0])])*F[:,i]))
sum_weights = 1/np.sum(weights, axis=axis)
aFw = aF[:,0]*Faust([sum_weights[0].reshape(1,1)])
for i in range(1, sum_weights.shape[0]):
aFw = pyfaust.hstack((aFw,
aF[:,i]*Faust([sum_weights[i].reshape(1,1)])))
if(returned):
return (aFw, sum_weights)
return aFw
if axis == 1 or isinstance(axis, tuple) and 1 in axis:
if weights.shape[0] == F.shape[1]:
aF = F*Faust(weights.reshape(weights.size, 1))
else:
raise ValueError("ValueError: Length of weights not compatible"
" with specified axis.")
sum_weights = np.sum(weights.reshape(weights.size, 1), axis=0)[0]
if axis == 0 or isinstance(axis, tuple) and 0 in axis:
weightsM = weights
if weights.ndim == 1:
weightsM = weights.reshape(1, weights.size)
if weightsM.shape[1] == F.shape[0]:
aF = Faust(weightsM)*F
else:
sum_weights = np.sum(weightsM.reshape(1, weights.size),
axis=1)[0]
if sum_weights != 0:
aF = aF * (1/sum_weights)
else:
raise decimal.DivisionByZero("Weights sum to zero, can't be normalized")
if(returned):
return (aF, sum_weights)
return aF
pyfaust.Faust.__div__ = pyfaust.Faust.__truediv__ pyfaust.Faust.__div__ = pyfaust.Faust.__truediv__
def version(): def version():
