Commit 5d985225 authored by hhakim's avatar hhakim
Add a link to LazyLinearOp jupyter notebook on the main page of doxygen doc.
parent 189afc94
Pipeline #834134 skipped
...@@ -14,6 +14,7 @@ You might also be interested in this introduction to pyfaust through Jupyter Not ...@@ -14,6 +14,7 @@ You might also be interested in this introduction to pyfaust through Jupyter Not
- [Using the poly module](./pyfaust_poly.html) - [Using the poly module](./pyfaust_poly.html)
- [Using the PALM4MSA-MHTP algorithm](./MHTP_algorithms.html) - [Using the PALM4MSA-MHTP algorithm](./MHTP_algorithms.html)
- [Faust Optimizations](./Faust_optimizations.html) - [Faust Optimizations](./Faust_optimizations.html)
- [Using LazyLinearOp-s](./lazylinop.html)
Download all the notebooks (.ipynb) [here](./pyfaust_notebooks.zip). Download all the notebooks (.ipynb) [here](./pyfaust_notebooks.zip).
