Commit 57db852f authored by hhakim's avatar hhakim
Fix type genericity break.
parent 1272b490
...@@ -20,7 +20,7 @@ void fft_factors(unsigned int n, std::vector<MatGeneric<complex<FPP>,Cpu>*>& v) ...@@ -20,7 +20,7 @@ void fft_factors(unsigned int n, std::vector<MatGeneric<complex<FPP>,Cpu>*>& v)
int* fac_col_ind = new int[dim_size*2]; int* fac_col_ind = new int[dim_size*2];
complex<FPP> wL; complex<FPP> wL;
const FPP pi = std::acos(-1); const FPP pi = std::acos(-1);
const std::complex<double> cplx_i(0, 1); //TODO: rename to i (np for loop vars because they have their own scope) const std::complex<FPP> cplx_i(0, 1); //TODO: rename to i (np for loop vars because they have their own scope)
for(unsigned int i = 0; i < dim_size; i++) for(unsigned int i = 0; i < dim_size; i++)
index[i] = i; index[i] = i;
memcpy(new_index, index, sizeof(unsigned int)*dim_size); memcpy(new_index, index, sizeof(unsigned int)*dim_size);
