Commit 556ece73 authored by hhakim's avatar hhakim
Fix include directories for faust_linear_operator target (needing GPU_MOD).
parent 46613a51
...@@ -4,7 +4,10 @@ file(GLOB CPP_FILES "*.cpp" "${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.cpp" "${FAU ...@@ -4,7 +4,10 @@ file(GLOB CPP_FILES "*.cpp" "${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.cpp" "${FAU
file(GLOB HPP_FILES "${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.hpp" "${FAUST_LINEAR_OPERATOR_CPU_SRC_DIR}/*.hpp") file(GLOB HPP_FILES "${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR}/*.hpp" "${FAUST_LINEAR_OPERATOR_CPU_SRC_DIR}/*.hpp")
if(USE_GPU_MOD)
include_directories(${GPU_MOD_INCLUDE_DIR} ${GPU_MOD_INCLUDE_DIR}/../build)
include_directories(${FAUST_SRC_LINEAR_OPERATOR_GPU2_DIR})
endif()
include_directories(${FAUST_SRC_LINEAR_OPERATOR_DIR} ${FAUST_LINEAR_OPERATOR_CPU_SRC_DIR} ${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR} ${FAUST_ALGORITHM_FACTORIZATION_SRC_DIR} ${FAUST_UTILS_SRC_DIR} ${EIGEN_INC_DIR}) include_directories(${FAUST_SRC_LINEAR_OPERATOR_DIR} ${FAUST_LINEAR_OPERATOR_CPU_SRC_DIR} ${FAUST_ALGORITHM_CONSTRAINT_SRC_DIR} ${FAUST_ALGORITHM_FACTORIZATION_SRC_DIR} ${FAUST_UTILS_SRC_DIR} ${EIGEN_INC_DIR})
if(BUILD_OPENBLAS) if(BUILD_OPENBLAS)
#ifndef __FAUST_MATDENSE_GPU2__ #ifndef __FAUST_MATDENSE_GPU2__
#define __FAUST_MATDENSE_GPU2__ #define __FAUST_MATDENSE_GPU2__
#ifdef USE_GPU_MOD #ifdef USE_GPU_MOD
#include <cstdint>
#include "faust_MatDense.h" #include "faust_MatDense.h"
#include "faust_MatGeneric_gpu.h" #include "faust_MatGeneric_gpu.h"
#include "faust_Vect_gpu.h" #include "faust_Vect_gpu.h"
