Commit 549a75fd authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
delete windows sh
parent 7181ab19
####################### run_nightly ##############################
# This shell-bash SCRIPT performs :
# - svn checkout
# - compile the selected target of faust project
# - run some examples relating to these targets.
# faust_test directory contains the sources of the faust project.
# faust_test_build directory contains the build of faust project.
# faust_output directory contains the build of faust project.
# WARNING : Please adjust your environment variables, corresponding
# to your computer configurations (library path)
# svn checkout --username XXX https://scm.gforge.inria.fr/authscm/XXX/svn/faust/trunk/devcpp/test/CTest_nightly
# Directory of the local path of the nightly project
export PATH_DIR_RUN_NIGHTLY='C:\Users\ci\FAUST\CTest_nightly'
# Directory of the library used in the FAUST PROJECT
#export EIGENDIR='/usr/include/eigen3'
#export OPENBLASDIR='/opt/OpenBLAS'
#export MATIODIR='/usr/local'
#export CUDADIR='/usr/local/cuda-7.5'
# export version of gcc
#export CC='/usr/lib64/ccache/gcc'
#export CXX='/usr/lib64/ccache/g++'
export CC='C:\Program Files\mingw-w64\x86_64-4.9.2-posix-seh-rt_v4-rev4\mingw64\bin\gcc'
export CXX='C:\Program Files\mingw-w64\x86_64-4.9.2-posix-seh-rt_v4-rev4\mingw64\bin\g++'
# /usr/local/bin/matlab in the PATH
#export PATH=/usr/local/bin:$PATH
# cuda in the PATH
#export PATH=/usr/local/cuda-7.5/bin:/usr/lib64/ccache/:$PATH
if [ ! -d "$PATH_DIR_RUN_NIGHTLY" ];
then
echo "ERROR : $PATH_DIR_RUN_NIGHTLY directory is not defined or do no exist !!!!!! Please select a valid PATH_DIR_RUN_NIGHTLY "
exit 1
fi
#export HDF5_ROOT_DIR=/home/aleman/Library/hdf5-1.8.16/src/.libs
# CTEST OPTION
export CTEST_CONFIGURE_OPTIONS="\
-DBUILD_OPENBLAS=OFF;\
-DBUILD_READ_MAT_FILE=OFF;\
-DBUILD_READ_XML_FILE=OFF;\
-DBUILD_MATLAB_MEX_FILES=ON;\
-DBUILD_USE_GPU:BOOL=OFF;\
-DFAUST_USE_PROFILING=OFF;\
-DBUILD_VERBOSE=OFF;\
-DBUILD_DOCUMENTATION:BOOL=OFF"
#-DDASH_TESTING:BOOL=ON;\
#-DBUILD_DEBUG:BOOL=OFF;\
#-DBUILD_COVERAGE:BOOL=ON;\
cd $PATH_DIR_RUN_NIGHTLY
rm -rf faust_test
rm -rf faust_test_build
rm -rf faust_output
mkdir faust_test
mkdir faust_test_build
mkdir faust_output
# launch ctest file
ctest -VV -C Release -S faustTest.cmake
#ctest -VV -C Release -S faustTestContinuous.cmake
