Commit 4afc0d5b authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
doc latex
parent 64f67608
No preview for this file type
...@@ -307,11 +307,11 @@ If you have administrator privilege, follow instructions in Section \ref{sec:Adm ...@@ -307,11 +307,11 @@ If you have administrator privilege, follow instructions in Section \ref{sec:Adm
> mkdir build > mkdir build
> cd build > cd build
> cmake .. > cmake ..
> cmake --build . --config "Release"
\end{lstlisting} \end{lstlisting}
\item Re-Open a command terminal \textbf{with administrator privilege} \item Re-Open a command terminal \textbf{with administrator privilege}
\begin{lstlisting} \begin{lstlisting}
> cmake --build . --config "Release" --target "install" > cmake --build . --config "Release" --target "install"
\end{itemize} \end{itemize}
...@@ -61,11 +61,6 @@ message(STATUS "CTEST_CONFIGURE_OPTIONS_OK=${CTEST_CONFIGURE_OPTIONS_OK}") ...@@ -61,11 +61,6 @@ message(STATUS "CTEST_CONFIGURE_OPTIONS_OK=${CTEST_CONFIGURE_OPTIONS_OK}")
#message(STATUS " CTEST_CONFIGURE\(OPTIONS \"${CTEST_CONFIGURE_OPTIONS_OK}\"\) ") #message(STATUS " CTEST_CONFIGURE\(OPTIONS \"${CTEST_CONFIGURE_OPTIONS_OK}\"\) ")
CTEST_CONFIGURE(OPTIONS "${CTEST_CONFIGURE_OPTIONS_OK}") CTEST_CONFIGURE(OPTIONS "${CTEST_CONFIGURE_OPTIONS_OK}")
IF(WIN32)
ENDIF()
#CTEST_CONFIGURE(OPTIONS "-DBUILD_DEBUG:BOOL=OFF;-DDASH_TESTING:BOOL=ON;-DBUILD_COVERAGE:BOOL=ON;-DBUILD_DOCUMENTATION:BOOL=OFF;-DCMAKE_INSTALL_PREFIX=${CTEST_INSTALL_DIR};-DBUILD_USE_GPU:BOOL=ON;-DBUILD_OPENBLAS=ON") #CTEST_CONFIGURE(OPTIONS "-DBUILD_DEBUG:BOOL=OFF;-DDASH_TESTING:BOOL=ON;-DBUILD_COVERAGE:BOOL=ON;-DBUILD_DOCUMENTATION:BOOL=OFF;-DCMAKE_INSTALL_PREFIX=${CTEST_INSTALL_DIR};-DBUILD_USE_GPU:BOOL=ON;-DBUILD_OPENBLAS=ON")
#CTEST_BUILD() #CTEST_BUILD()
