Commit 40e1dcff authored by hhakim's avatar hhakim
Update macosx vm setup script for libomp config.
parent 067dfcc8
...@@ -29,6 +29,7 @@ sudo ln -sf /opt/local/lib/libmatio.a /usr/local/lib/ ...@@ -29,6 +29,7 @@ sudo ln -sf /opt/local/lib/libmatio.a /usr/local/lib/
yes | port install libomp-devel libomp yes | port install libomp-devel libomp
### 4. Install and configure clang compiler environment (and OpenMP) ### 4. Install and configure clang compiler environment (and OpenMP)
port -f activate libomp port -f activate libomp
sudo cp /opt/local/lib/libomp/libomp.dylib /opt/local/lib/libomp/libomp_macports.dylib # needed for ci package jobs
yes | port install clang-8.0 yes | port install clang-8.0
echo 'export OpenMP_INC_DIR=/opt/local/include/libomp' >> /Users/ci/.bash_profile echo 'export OpenMP_INC_DIR=/opt/local/include/libomp' >> /Users/ci/.bash_profile
echo 'export OpenMP_gomp_LIBRARY=/opt/local/lib/libomp/libgomp.dylib' >> /Users/ci/.bash_profile echo 'export OpenMP_gomp_LIBRARY=/opt/local/lib/libomp/libgomp.dylib' >> /Users/ci/.bash_profile
...@@ -58,7 +59,7 @@ echo "Please manually install matlab by copying directly the directory from /Vol ...@@ -58,7 +59,7 @@ echo "Please manually install matlab by copying directly the directory from /Vol
echo "First, a DATA storage volume must be created and attached to the VM instance (use command: diskutil mount)." echo "First, a DATA storage volume must be created and attached to the VM instance (use command: diskutil mount)."
echo "Finally add matlab to the PATH (in .bash_profile)." echo "Finally add matlab to the PATH (in .bash_profile)."
echo "It is also useful to symlink the matlab binary in /usr/bin/ for the root user env. to be OK for installing/testing the pkg (postinstall script needs to find matlab)." echo "It is also useful to symlink the matlab binary in /usr/bin/ for the root user env. to be OK for installing/testing the pkg (postinstall script needs to find matlab)."
echo "Other need about matlab OpenMP: you need to copy the library as for example: ciosx:~ ci$ cp /Volumes/Untitled/MATLAB_R2018b.app/sys/os/maci64/libiomp5.dylib /opt/local/lib/libomp/" echo "Other need about matlab OpenMP: you need to copy the library as for example: ciosx:~ ci$ cp /Volumes/Untitled/MATLAB_R2018b.app/sys/os/maci64/libiomp5.dylib /opt/local/lib/libomp/libiomp5_matlab.dylib"
echo "ABOUT SUDO: add this line in /etc/sudoers: ci ALL=(ALL:ALL) NOPASSWD: ALL (this way the runner won't need to type the password for running commands as root)" echo "ABOUT SUDO: add this line in /etc/sudoers: ci ALL=(ALL:ALL) NOPASSWD: ALL (this way the runner won't need to type the password for running commands as root)"
#echo "WARNING: the matlab installer link is likely to fail" #echo "WARNING: the matlab installer link is likely to fail"
#wget "https://esd.mathworks.com/R2018b/R2018b/installers/web/matlab_R2018b_maci64.dmg.zip?__gda__=1608282997_72bccb4cda14022857f8691914aea21a&dl_id=aYudAe6N&ext=.zip" || echo "the link failed, please update." #wget "https://esd.mathworks.com/R2018b/R2018b/installers/web/matlab_R2018b_maci64.dmg.zip?__gda__=1608282997_72bccb4cda14022857f8691914aea21a&dl_id=aYudAe6N&ext=.zip" || echo "the link failed, please update."
