Commit 3d3d8d8d authored by hhakim's avatar hhakim
Add member functions to MatDense: eq_cols, eq_rows, sum_col, sum_row,...
Add member functions to MatDense: eq_cols, eq_rows, sum_col, sum_row, best_low_rank, row_nonzero_inds, col_nonzero_inds, submatrix.
NOTE: it needs eigen >= 3.4 to compile (slicing support is needed by submatrix()).
parent 8a6d658d
Loading
