Commit 3bfcccec authored by hhakim's avatar hhakim
Add unit tests Vect<FPP, GPU2>.
parent 7b9ae809
Pipeline #847111 passed
......@@ -7,12 +7,76 @@
using namespace std;
using namespace Faust;
typedef @TEST_FPP@ FPP;
void test_sum()
cout << "test Vect<double, GPU2>::sum" << endl;
Vect<FPP, GPU2> u(10);
u.setValues(2);
auto s = u.sum();
assert(s == 2 * 10);
cout << "OK" << endl;
void test_eltwise_mul()
cout << "test Vect<double, GPU2>::operator*=" << endl;
Vect<FPP, GPU2> v(10);
u.setValues(2);
v.setValues(3);
u *= v;
assert(u.sum() == 2 * 3 * 10);
void test_eltwise_div()
cout << "test Vect<double, GPU2>::operator/=" << endl;
u.setValues(6);
v.setValues(3);
u /= v;
assert(u.sum() == 6 / 3 * 10);
void test_set_vals()
cout << "test Vect<double, GPU2>::setValues(double)" << endl;
Vect<FPP, Cpu> cpu_u(10);
Vect<FPP, GPU2> gpu_u(10);
for(int i=0;i<10;i++)
cpu_u.set_coeff(i, 18);
gpu_u.setValues(18);
auto cpu_u_t = gpu_u.tocpu();
assert(cpu_u.equality(cpu_u_t, 1e-16));
void test_mean_relerr()
cout << "test Vect<double, GPU2>::mean_relative_error()" << endl;
Vect<FPP, Cpu> cu(12), cv(12);
cu.setRand();
cv.setRand();
Vect<FPP, GPU2> gu(cu);
Vect<FPP, GPU2> gv(cv);
auto cerr = cu.mean_relative_error(cv);
auto gerr = gu.mean_relative_error(gv);
assert(std::abs(gerr - cerr) < 1e-6);
int main()
Faust::Vect<double, GPU2> v;
//TODO: test Vect<double, GPU2>::sum
//TODO: test Vect<double, GPU2>::operator*= (elt-wise mul.)
//TODO: test Vect<double, GPU2>::operator/= (elt-wise div.)
//TODO: test Vect<double, GPU2>::setValues(double)
//TODO: test Vect<double, GPU2>::mean_relerr
enable_gpu_mod();
test_set_vals();
test_sum();
test_eltwise_mul();
test_eltwise_div();
test_mean_relerr();
