Commit 3b4dbdd8 authored by hhakim's avatar hhakim
Disable pytorch-Faust class experimental code by default (new cmake option to...
Disable pytorch-Faust class experimental code by default (new cmake option to enable/disable it un pyfaust).
It avoids blocking some tests with experimental build on VMs where pytorch is not installed.
parent 7ce649e2
Loading
