Commit 3a41ff0d authored by hhakim's avatar hhakim
Add unit tests for Matlab wrapper Faust class.
parent 48678a84
...@@ -4,11 +4,13 @@ classdef FaustTest < matlab.unittest.TestCase ...@@ -4,11 +4,13 @@ classdef FaustTest < matlab.unittest.TestCase
properties properties
test_faust test_faust
faust_paths faust_paths
end factors
num_factors
properties (Constant = true) properties (Constant = true)
MAX_NUM_FACTORS = 64 MAX_NUM_FACTORS = 32
MAX_DIM_SIZE = 1024 MAX_DIM_SIZE = 512
end end
methods(TestClassSetup) methods(TestClassSetup)
...@@ -34,6 +36,8 @@ classdef FaustTest < matlab.unittest.TestCase ...@@ -34,6 +36,8 @@ classdef FaustTest < matlab.unittest.TestCase
factors{i} = sprand(d1, d2, density); factors{i} = sprand(d1, d2, density);
end end
this.test_faust = Faust(factors,1.0,0) this.test_faust = Faust(factors,1.0,0)
this.factors = factors
this.num_factors = num_factors
end end
end end
...@@ -78,6 +82,106 @@ classdef FaustTest < matlab.unittest.TestCase ...@@ -78,6 +82,106 @@ classdef FaustTest < matlab.unittest.TestCase
delete(filepath_ref) delete(filepath_ref)
delete(filepath_test) delete(filepath_test)
end end
function testSize(this)
disp('testSize()')
[num_rows, num_cols] = size(this.test_faust)
num_facs = this.num_factors
size_first_fac = size(this.factors{1})
size_last_fac = size(this.factors{num_facs})
this.verifyEqual(num_rows, size_first_fac(1))
this.verifyEqual(num_cols, size_last_fac(2))
function testGetFactorAndConstructor(this)
disp('testGetFactorAndConstructor()')
for i = 1:this.num_factors
this.verifyEqual(get_fact(this.test_faust, i), full(this.factors{i}))
function testGetNumFactors(this)
disp('testGetNumFactors()')
this.verifyEqual(get_nb_factor(this.test_faust), this.num_factors)
function testNorm2(this)
disp('testNorm2()')
ref_F = this.mulFactors()
this.verifyEqual(norm(ref_F,2), norm(this.test_faust, 2), 'RelTol',0.05)
function testnnz(this)
disp('testnnz()')
this.verifyEqual(nnz(this.test_faust), nnzero_count(this.factors))
function testDensity(this)
disp('testDensity()')
ref_nlines = size(this.factors{1},1)
ref_ncols = size(this.factors{this.num_factors},2)
this.verifyEqual(nnzero_count(this.factors)/ref_nlines/ref_ncols, density(this.test_faust), 'AbsTol', 0.01)
function testrcg(this)
disp('testrcg()')
this.verifyEqual(ref_nlines*ref_ncols/nnzero_count(this.factors), RCG(this.test_faust), 'RelTol', 0.01)
function testend(this)
disp('testend()')
prod_F = this.mulFactors()
for i=1:size(this.factors{1},1)
this.verifyEqual(prod_F(i,end), this.test_faust(i,end),'RelTol', 0.01)
for j=1:size(this.factors{this.num_factors},2)
this.verifyEqual(prod_F(end,j), this.test_faust(end,j), 'RelTol', 0.01)
function testsubsref(this)
disp('testsubsref()')
% test whole faust
ref_F = this.mulFactors();
test_F = this.test_faust(1:end,1:end);
this.verifyEqual(ref_F(1:end,1:end), test_F, 'RelTol', 0.01)
% test a random row
row_i = randi(1,size(this.test_faust,1));
test_F = this.test_faust(row_i,:);
this.verifyEqual(test_F, ref_F(row_i,:), 'RelTol', 0.01)
% test a random col
col_i = randi(1,size(this.test_faust,2));
test_F = this.test_faust(:,col_i);
this.verifyEqual(test_F, ref_F(:,col_i), 'RelTol', 0.01)
function testFull(this)
disp('Test Faust.full()')
ref_faust = this.mulFactors();
test_faust = full(this.test_faust);
this.verifyEqual(test_faust, ref_faust, 'RelTol', 10^-3)
function testTranspose(this)
disp('Test Faust.transpose()')
% test full matrix to avoid longer time for comparisons (element by
% element)
transp_faust = full(transpose(this.test_faust));
this.verifyEqual(test_faust,transpose(transp_faust), 'RelTol', 10^-3)
function testCtranspose(this)
disp('Test Faust.ctranspose()')
%TODO (when the function will be implemeted)
function testConj(this)
disp('Test Faust.conj()')
%TODO (when the funciton will be implemented)
end end
methods methods
...@@ -85,7 +189,16 @@ classdef FaustTest < matlab.unittest.TestCase ...@@ -85,7 +189,16 @@ classdef FaustTest < matlab.unittest.TestCase
faust_test.faust_paths = varargin faust_test.faust_paths = varargin
run(faust_test) run(faust_test)
end end
function prod_F = mulFactors(this)
first_fac_size = size(this.factors{1})
prod_F = eye(first_fac_size(1));
for i=1:this.num_factors
prod_F = prod_F*this.factors{i};
end end
