GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.3.
Show more breadcrumbs
faust group
faust
383b0c9a
383b0c9a
2 years ago
hhakim
Downloads
Patches
Run ci job pkg tests on complex in addition to double scalars.
ac32b2cd
main
.gitlab-ci.yml
+6
6 additions, 0 deletions
.gitlab-ci.yml
6 additions
.gitlab-ci.yml
6
383b0c9a
@@ -600,6 +600,7 @@ test_macos_pkg_release:
matlab -nojvm -nodisplay -r "disp(matfaust.version());disp(full(matfaust.rand(5,5))); exit;" | tee /tmp/faust && grep $CI_COMMIT_TAG /tmp/faust
python$MACOS_PY_VER -c "import pyfaust; print(pyfaust.version()); print(pyfaust.rand(5,5).toarray());"
python$MACOS_PY_VER -c "import pyfaust.tests; pyfaust.tests.run_tests('cpu', 'real')"
python$MACOS_PY_VER -c "import pyfaust.tests; pyfaust.tests.run_tests('cpu', 'complex')"
only
only
tags
tags
tags
tags
@@ -618,11 +619,13 @@ test_linux_pkg_release:
python$NUX_PY_VER -c "import pyfaust; print(pyfaust.version()); print(pyfaust.rand(5,5).toarray());"
python$NUX_PY_VER -c "import pyfaust.tests; pyfaust.tests.run_tests('cpu', 'real')"
python$NUX_PY_VER -c "import pyfaust.tests; pyfaust.tests.run_tests('cpu', 'complex')"
sudo rpm -e faust
sudo rpm -e faust
sudo rpm -i --nodeps build/faust-$CI_COMMIT_TAG-static-x86_64.rpm
sudo rpm -e faust
sudo rpm -e faust
only
only
tags
tags
@@ -648,6 +651,7 @@ test_linux_pkg_release:
#- python -c "from os.path import exists;from time import sleep; sleep(15); exit(0);if(exists('F.mat')) else exit(1)"
python -c "import pyfaust; print(pyfaust.version()); print(pyfaust.rand(5,5).toarray());"
python -c "import pyfaust.tests; pyfaust.tests.run_tests('cpu', 'real')"
python -c "import pyfaust.tests; pyfaust.tests.run_tests('cpu', 'complex')"
cd "C:\Program Files\Faust"
#- call 'uninstall.exe' /S
python -c "import os; os.system('uninstall.exe /S')"
@@ -672,6 +676,7 @@ test_linux_pkg_release:
$JOB_PYTHON -c "import pyfaust; print(pyfaust.version()); print(pyfaust.rand(5,5).toarray());"
$JOB_PYTHON -c "import pyfaust.tests; pyfaust.tests.run_tests('cpu', 'double')"
$JOB_PYTHON -c "import pyfaust.tests; pyfaust.tests.run_tests('cpu', 'float32')"
$JOB_PYTHON -c "import pyfaust.tests; pyfaust.tests.run_tests('cpu', 'complex')"
only
only
tags
tags
@@ -735,6 +740,7 @@ test_win_purepy_pkg:
python -c "import pyfaust.tests; pyfaust.tests.run_tests(\"cpu\", \"double\")"
python -c "import pyfaust.tests; pyfaust.tests.run_tests(\"cpu\", \"float32\")"
python -c "import pyfaust.tests; pyfaust.tests.run_tests(\"cpu\", \"complex\")"
needs
needs
job
pkg_win_purepy_release
job
artifacts
true
artifacts
true
This diff is collapsed.
Loading
Save comment
