Commit 374e1a1c authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
modif AL
parent 6ac0ab00
...@@ -22,11 +22,11 @@ export PATH=$PATH:usr/local/include ...@@ -22,11 +22,11 @@ export PATH=$PATH:usr/local/include
# Directory of the local path of the nightly project # Directory of the local path of the nightly project
export PATH_DIR_RUN_NIGHTLY='/Users/ci/CTest_nightly' export PATH_DIR_RUN_NIGHTLY='/Users/ci/CTest_nightly'
export OPENBLASDIR='/Users/ci/local/OPENBLAS-v0.2.15' #export OPENBLASDIR='/Users/ci/local/OPENBLAS-v0.2.15'
export EIGENDIR='/Users/ci/local/eigen-3.2.8' #export EIGENDIR='/Users/ci/local/eigen-3.2.8'
export HDF5_ROOT_DIR='/Users/ci/local/hdf5-1.8.17/lib' #export HDF5_ROOT_DIR='/Users/ci/local/hdf5-1.8.17/lib'
export MATIODIR='/Users/ci/local/matio-1.5.2' #export MATIODIR='/Users/ci/local/matio-1.5.2'
#export CUDADIR=/usr/local/cuda-6.5 #export CUDADIR=/usr/local/cuda-6.5
...@@ -55,12 +55,13 @@ export CTEST_CONFIGURE_OPTIONS=" ...@@ -55,12 +55,13 @@ export CTEST_CONFIGURE_OPTIONS="
-DFAUST_USE_GPU:BOOL=OFF;\ -DFAUST_USE_GPU:BOOL=OFF;\
-DFAUST_USE_PROFILING=OFF;\ -DFAUST_USE_PROFILING=OFF;\
-DFAUST_ISVERBOSE=OFF;\ -DFAUST_ISVERBOSE=OFF;\
-DFAUST_GEN_DOC:BOOL=OFF;\ -DFAUST_GEN_DOC:BOOL=OFF;"
-DFAUST_USE_OPENMP=OFF;\
-DDASH_TESTING:BOOL=ON;\ #-DFAUST_USE_OPENMP=OFF;\
-DBUILD_DEBUG:BOOL=OFF;\ #-DDASH_TESTING:BOOL=ON;\
-DBUILD_COVERAGE:BOOL=ON;" #-DBUILD_DEBUG:BOOL=OFF;\
#-DBUILD_COVERAGE:BOOL=ON;
cd $PATH_DIR_RUN_NIGHTLY cd $PATH_DIR_RUN_NIGHTLY
