GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.6.
Show more breadcrumbs
faust group
faust
3639952e
3639952e
8 years ago
testcdash Nicolas Bellot
Committed by
hhakim
2 years ago
Downloads
Patches
ctest windows 4 cdash
10f7bed1
misc/test/CMakeLists.txt
+35
-21
35 additions, 21 deletions
35 additions
21 deletions
35
21
3639952e
@@ -29,29 +29,43 @@ set(TIMEOUT_COMP 100)
# MATLAB TEST
# MATLAB TEST
if
BUILD_MATLAB_MEX_FILES
if
add_test
NAME MATLAB_FACT_HIER_MEX COMMAND matlab -nojvm -r
"try;testpass=0;addpath('
FAUST_BIN_TEST_BIN_DIR
FAUST_BIN_TEST_TOOLS_DIR
');set_path;hier_fact_test('config_compared_hierarchical_fact',9402,1,'MEX'); catch ME ;testpass=-1;disp(getReport(ME)); end ; exit(testpass)"
add_test
NAME MATLAB_FACT_HIER_MATLAB COMMAND matlab -nojvm -r
');set_path;hier_fact_test('config_compared_hierarchical_fact',9402,1,'MATLAB'); catch ME ;testpass=-1;disp(getReport(ME)); end ; exit(testpass)"
add_test
NAME MATLAB_FACT_MEG_MEX COMMAND matlab -nojvm -r
');set_path;hier_fact_test('config_MEG',22480,1,'MEX');catch ME ;testpass=-1;disp(getReport(ME)); end ; exit(testpass)"
add_test
NAME MATLAB_FACT_MEG_MATLAB COMMAND matlab -nojvm -r
');set_path;hier_fact_test('config_MEG',22480,1,'MATLAB');catch ME ;testpass=-1;disp(getReport(ME)); end ; exit(testpass)"
add_test
NAME MATLAB_FACT_HADAMARD_MEX COMMAND matlab -nojvm -r
');set_path;hier_fact_test('config_HADAMARD',5941,30,'MEX');catch ME ;testpass=-1;disp(getReport(ME)); end ; exit(testpass)"
add_test
NAME MATLAB_FACT_HADAMARD_MATLAB COMMAND matlab -nojvm -r
');set_path;hier_fact_test('config_HADAMARD',5941,30,'MATLAB');catch ME ;testpass=-1;disp(getReport(ME)); end ; exit(testpass)"
add_test
NAME MATLAB_DEMO_INSTALL COMMAND matlab -nodesktop -r
CMAKE_INSTALL_MATLAB_PREFIX
');setup_FAUST;run_all_demo;catch ME ;testpass=-1;disp(getReport(ME)); end ; exit(testpass)"
add_test
NAME MATLAB_DEMO_BUILD COMMAND matlab -nodesktop -r
FAUST_MATLAB_BIN_DIR
add_test
NAME MATLAB_FAUST_1 COMMAND matlab -nojvm -r
');set_path;test_matlab_faust;catch ME ;testpass=-1;disp(getReport(ME)); end ; exit(testpass)"
# test the matlab Faust class methods with incorrect parameter
add_test
NAME MATLAB_FAUST_2 COMMAND matlab -nojvm -r
');set_path;test_matlab_faust2;catch ME ;testpass=-1;disp(getReport(ME)); end ; exit(testpass)"
add_test
NAME MATLAB_FAUST_SPEED COMMAND matlab -nojvm -r
');set_path;test_matlab_faust_time;catch ME ;testpass=-1;disp(getReport(ME)); end ; exit(testpass)"
if
WIN32 AND NOT UNIX
add_test
"delete MATLAB_FACT_HIER_MEX.txt;diary MATLAB_FACT_HIER_MEX.txt;try;testpass=0;addpath('
');set_path;hier_fact_test('config_compared_hierarchical_fact',9402,1,'MEX'); catch ME ;testpass=-1;disp(getReport(ME)); end ; disp (testpass); diary OFF; exit(testpass)"
# && type MATLAB_FACT_HIER_MEX.txt)
add_test
"delete MATLAB_FACT_HIER_MATLAB.txt;diary MATLAB_FACT_HIER_MATLAB.txt;try;testpass=0;addpath('
');set_path;hier_fact_test('config_compared_hierarchical_fact',9402,1,'MATLAB'); catch ME ;testpass=-1;disp(getReport(ME)); end ; disp (testpass); diary OFF; exit(testpass)"
# && type MATLAB_FACT_HIER_MATLAB.txt)
add_test
"delete MATLAB_FACT_MEG_MEX.txt;diary MATLAB_FACT_MEG_MEX.txt;try;testpass=0;addpath('
');set_path;hier_fact_test('config_MEG',22480,1,'MEX');catch ME ;testpass=-1;disp(getReport(ME)); end ; disp (testpass); diary OFF; exit(testpass)"
# && type MATLAB_FACT_MEG_MEX.txt)
add_test
"delete MATLAB_FACT_MEG_MATLAB.txt;diary MATLAB_FACT_MEG_MATLAB.txt;try;testpass=0;addpath('
');set_path;hier_fact_test('config_MEG',22480,1,'MATLAB');catch ME ;testpass=-1;disp(getReport(ME)); end ; disp (testpass); diary OFF; exit(testpass)"
# && type MATLAB_FACT_MEG_MATLAB.txt)
add_test
"delete MATLAB_FACT_HADAMARD_MEX.txt;diary MATLAB_FACT_HADAMARD_MEX.txt;try;testpass=0;addpath('
');set_path;hier_fact_test('config_HADAMARD',5941,30,'MEX');catch ME ;testpass=-1;disp(getReport(ME)); end ; disp (testpass); diary OFF; exit(testpass)"
#&& type MATLAB_FACT_HADAMARD_MEX.txt)
add_test
"delete MATLAB_FACT_HADAMARD_MATLAB.txt;diary MATLAB_FACT_HADAMARD_MATLAB.txt;try;testpass=0;addpath('
');set_path;hier_fact_test('config_HADAMARD',5941,30,'MATLAB');catch ME ;testpass=-1;disp(getReport(ME)); end ; disp (testpass); diary OFF; exit(testpass)"
# && type MATLAB_FACT_HADAMARD_MATLAB.txt)
add_test
"delete MATLAB_DEMO_INSTALL.txt;diary MATLAB_DEMO_INSTALL.txt;try;testpass=0;addpath('
');setup_FAUST;run_all_demo;catch ME ;testpass=-1;disp(getReport(ME)); end ; disp (testpass); diary OFF; exit(testpass)"
# && type MATLAB_DEMO_INSTALL.txt)
add_test
"delete MATLAB_DEMO_BUILD.txt;diary MATLAB_DEMO_BUILD.txt;try;testpass=0;addpath('
#&& type MATLAB_DEMO_BUILD.txt)
add_test
"delete MATLAB_FAUST_1.txt;diary MATLAB_FAUST_1.txt;try;testpass=0;addpath('
');set_path;test_matlab_faust;catch ME ;testpass=-1;disp(getReport(ME)); end ; disp (testpass); diary OFF; exit(testpass)"
#&& type MATLAB_FAUST_1.txt)
## test the matlab Faust class methods with incorrect parameter
add_test
"delete MATLAB_FAUST_2.txt;diary MATLAB_FAUST_2.txt;try;testpass=0;addpath('
');set_path;test_matlab_faust2;catch ME ;testpass=-1;disp(getReport(ME)); end ; disp (testpass); diary OFF; exit(testpass)"
# && type MATLAB_FAUST_2.txt)
add_test
"delete MATLAB_FAUST_SPEED.txt;diary MATLAB_FAUST_SPEED.txt;try;testpass=0;addpath('
');set_path;test_matlab_faust_time;catch ME ;testpass=-1;disp(getReport(ME)); end ; disp (testpass); diary OFF; exit(testpass)"
# && type MATLAB_FAUST_SPEED.txt)
else
WIN32 AND NOT UNIX
add_test
add_test
add_test
add_test
add_test
add_test
add_test
add_test
add_test
add_test
add_test
endif
WIN32 AND NOT UNIX
# limit the time of the process in case of bug...
#CTEST_FULL_OUTPUT
#CTEST_FULL_OUTPUT
#set_tests_properties(MATLAB_FACT_HIER_MEX MATLAB_FACT_HIER_MATLAB PROPERTIES TIMEOUT 100)
#set_tests_properties(MATLAB_DEMO_INSTALL MATLAB_DEMO_BUILD PROPERTIES TIMEOUT 6000)
#set_tests_properties(MATLAB_FAUST_1 MATLAB_FAUST_2 PROPERTIES TIMEOUT 30)
#set_tests_properties(MATLAB_FACT_MEG_MATLAB MATLAB_FACT_MEG_MEX PROPERTIES TIMEOUT ${TIMEOUT_MEG})
TIMEOUT_MEG
endif
endif
This diff is collapsed.
Loading
Save comment
