Commit 35960f49 authored by hhakim's avatar hhakim
Update pyfaust.poly doc, fix a minor bug in pyfaust.poly.basis (occurring when...
Update pyfaust.poly doc, fix a minor bug in pyfaust.poly.basis (occurring when basis is a str) and verify that L is square.
parent 225dcc81
# experimental block start # experimental block start
# @PYFAUST_LICENSE_HEADER@ # @PYFAUST_LICENSE_HEADER@
## @package pyfaust.poly @brief This module provides polynomials as Faust objects. ## @package pyfaust.poly @brief The pyfaust module for polynomial basis as Faust objects.
import _FaustCorePy import _FaustCorePy
import scipy.sparse as sp import scipy.sparse as sp
...@@ -19,7 +19,7 @@ def Chebyshev(L, K, ret_gen=False, dev='cpu', T0=None, impl="native"): ...@@ -19,7 +19,7 @@ def Chebyshev(L, K, ret_gen=False, dev='cpu', T0=None, impl="native"):
Builds the Faust of the Chebyshev polynomial basis defined on the sparse matrix L. Builds the Faust of the Chebyshev polynomial basis defined on the sparse matrix L.
Args: Args:
L: the sparse scipy matrix in CSR format (scipy.sparse.csr_matrix). L: the sparse scipy square matrix in CSR format (scipy.sparse.csr_matrix).
L can aslo be a Faust if impl is "py". L can aslo be a Faust if impl is "py".
K: the degree of the last polynomial, i.e. the K+1 first polynomials are built. K: the degree of the last polynomial, i.e. the K+1 first polynomials are built.
dev: the device to instantiate the returned Faust ('cpu' or 'gpu'). dev: the device to instantiate the returned Faust ('cpu' or 'gpu').
...@@ -71,9 +71,11 @@ def Chebyshev(L, K, ret_gen=False, dev='cpu', T0=None, impl="native"): ...@@ -71,9 +71,11 @@ def Chebyshev(L, K, ret_gen=False, dev='cpu', T0=None, impl="native"):
The factors 0 to 3 of G are views of the same factors of F. The factors 0 to 3 of G are views of the same factors of F.
They are not duplicated in memory They are not duplicated in memory
if not isinstance(L, csr_matrix) and not isFaust(L):
L = csr_matrix(L)
if L.shape[0] != L.shape[1]:
raise ValueError('L must be a square matrix.')
if impl == "py": if impl == "py":
L = csr_matrix(L)
twoL = 2*L twoL = 2*L
d = L.shape[0] d = L.shape[0]
# Id = sp.eye(d, format="csr") # Id = sp.eye(d, format="csr")
...@@ -109,7 +111,7 @@ def basis(L, K, basis_name, ret_gen=False, dev='cpu', T0=None, impl="native"): ...@@ -109,7 +111,7 @@ def basis(L, K, basis_name, ret_gen=False, dev='cpu', T0=None, impl="native"):
Builds the Faust of the polynomial basis defined on the sparse matrix L. Builds the Faust of the polynomial basis defined on the sparse matrix L.
Args: Args:
basis_name: 'chebyshev', and others yet to come. basis_name: 'chebyshev', and others yet to come.
...@@ -177,7 +179,8 @@ def poly(coeffs, basis='chebyshev', L=None, dev='cpu', impl='native'): ...@@ -177,7 +179,8 @@ def poly(coeffs, basis='chebyshev', L=None, dev='cpu', impl='native'):
basis: either the name of the polynomial basis to build on L or the basis: either the name of the polynomial basis to build on L or the
basis if already built externally (as a FaustPoly or an equivalent basis if already built externally (as a FaustPoly or an equivalent
np.ndarray). np.ndarray).
(scipy.sparse.csr_matrix) on which the polynomial basis is built if basis is not already a Faust or a numpy.ndarray.
L can aslo be a Faust if impl is "py". It can't be None if basis is not a FaustPoly or a numpy.ndarray. L can aslo be a Faust if impl is "py". It can't be None if basis is not a FaustPoly or a numpy.ndarray.
'gpu' is not available yet for impl='native'. 'gpu' is not available yet for impl='native'.
...@@ -190,9 +193,21 @@ def poly(coeffs, basis='chebyshev', L=None, dev='cpu', impl='native'): ...@@ -190,9 +193,21 @@ def poly(coeffs, basis='chebyshev', L=None, dev='cpu', impl='native'):
>>> import numpy as np >>> import numpy as np
>>> from pyfaust.poly import basis, poly >>> from pyfaust.poly import basis, poly
>>> from scipy.sparse import random >>> from scipy.sparse import random
>>> K = 3
>>> L = random(50, 50, .02, format='csr') >>> L = random(50, 50, .02, format='csr')
>>> L = L@L.T >>> L = L@L.T
>>> coeffs = np.array([.5, 1, 2, 3])
>>> G = poly(coeffs, 'chebyshev', L)
>>> G
Faust size 50x50, density 0.3608, nnz_sum 902, 5 factor(s):
- FACTOR 0 (real) SPARSE, size 50x200, density 0.02, nnz 200
- FACTOR 1 (real) SPARSE, size 200x150, density 0.00946667, nnz 284
- FACTOR 2 (real) SPARSE, size 150x100, density 0.0156, nnz 234
- FACTOR 3 (real) SPARSE, size 100x50, density 0.0268, nnz 134
- FACTOR 4 (real) SPARSE, size 50x50, density 0.02, nnz 50
Which is equivalent to do as below (in two times):
>>> K = 3
>>> F = basis(L, K, 'chebyshev') >>> F = basis(L, K, 'chebyshev')
>>> coeffs = np.array([.5, 1, 2, 3]) >>> coeffs = np.array([.5, 1, 2, 3])
>>> G = poly(coeffs, F) >>> G = poly(coeffs, F)
...@@ -221,7 +236,9 @@ def poly(coeffs, basis='chebyshev', L=None, dev='cpu', impl='native'): ...@@ -221,7 +236,9 @@ def poly(coeffs, basis='chebyshev', L=None, dev='cpu', impl='native'):
if L is None: if L is None:
raise ValueError('The L matrix must be set to build the' raise ValueError('The L matrix must be set to build the'
' polynomials.') ' polynomials.')
F = basis(L, K, basis, dev=dev, impl=impl) from pyfaust.poly import basis as _basis
basis = F = _basis(L, K, basis, dev=dev, impl=impl)
if isFaust(basis): if isFaust(basis):
F = basis F = basis
elif not isinstance(basis, np.ndarray): elif not isinstance(basis, np.ndarray):
