GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
faust group
faust
35155f60
35155f60
9 years ago
Adrien Leman
Committed by
hhakim
2 years ago
Downloads
Patches
modif for CTest
5d0954a3
misc/test/CMakeLists.txt
+2
-1
2 additions, 1 deletion
2 additions
1 deletion
2
35155f60
@@ -124,8 +124,9 @@ endif(FAUST_USE_XML)
if
FAUST_USE_MEX
if
FAUST_USE_MEX
#add_test(NAME FAUST_HIER_MEX COMMAND matlab -nojvm -nodisplay -r ${FAUST_TEST_BIN_DIR}/hier_fact.m;exit)
# on ajoute les path bin et tools qui sont utilisés pour le script matlab.
add_test
NAME FAUST_HIER_MEX COMMAND matlab -nojvm -r
"try;addpath('
FAUST_TEST_BIN_DIR
FAUST_TESTTOOLS_BIN_DIR
');hier_fact;end;exit"
add_test
"try;addpath('
FAUST_TEST_BIN_DIR
');hier_fact
(9400,10)
;end;exit"
add_test
NAME FAUST_MEG_MEX COMMAND matlab -nojvm -r
"try;addpath('
FAUST_TEST_BIN_DIR
');MEG_fact;end;exit"
add_test
"try;addpath('
FAUST_TEST_BIN_DIR
# limit the time of the process in case of bug...
#CTEST_FULL_OUTPUT
#CTEST_FULL_OUTPUT
This diff is collapsed.
Loading
Save comment
