Commit 2fb2b58d authored by hhakim's avatar hhakim
Update py wrapper doc.
parent 304d04d7
......@@ -154,6 +154,9 @@ class Faust:
def transpose(F):
Transposes the current Faust.
Examples:
>>> F.transpose()
F_trans = Faust(core_obj=F.m_faust.transpose())
return F_trans
......@@ -161,6 +164,9 @@ class Faust:
def conj(F):
Returns the conjugate of the current Faust.
Examples:
>>> Fc = F.conj()
F_conj = Faust(core_obj=F.m_faust.conj())
return F_conj
......@@ -185,8 +191,8 @@ class Faust:
This method overloads the Python operator *.
Args:
M: 2D numpy ndarray of double scalar, must be Fortran contiguous
(i.e. Column-major order; `order' argument passed to
M: is a 2D numpy ndarray of double scalar (or complex if the Faust is complex also).
N.B.: M must be Fortran contiguous (i.e. Column-major order; `order' argument passed to
np.ndararray() must be equal 'F').
Returns:
......@@ -207,6 +213,8 @@ class Faust:
Converts the current Faust into a numpy matrix.
WARNING: this function costs F.get_nb_factors()-1 matrix multiplications.
Returns:
A numpy matrix.
......@@ -216,12 +224,12 @@ class Faust:
def __getitem__(F, indices):
Returns a coefficient of the Faust by its indices.
Returns a coefficient or a slice of the Faust based on indices.
This function is a Python built-in overload.
Args:
indices: array of length 2, its elements must be of kind: slice, integer or
indices: array of length 2, its elements must be slice, integer or
Ellipsis (...).
Returns:
