Commit 2a2f467b authored by hhakim's avatar hhakim
Fix matfaust doctest loop (exit on first test).
parent 1988c340
...@@ -186,7 +186,7 @@ doctest_nightly_matfaust: ...@@ -186,7 +186,7 @@ doctest_nightly_matfaust:
- rm -Rf build - rm -Rf build
# all is set to doctest matfaust # all is set to doctest matfaust
# no -nojvm because it's needed for Faust.imagesc doctest # no -nojvm because it's needed for Faust.imagesc doctest
- 'for S in Faust proj.sp proj.splin proj.spcol proj.splincol proj.const proj.supp proj.normlin proj.normcol proj.blockdiag proj.anticirc proj.circ proj.hankel proj.skperm proj.sptriu proj.sptril proj.spsymm proj.toeplitz proj.proj_id poly.poly poly.expm_multiply poly.next poly.basis poly.expm_inv_multiply factparams.ParamsHierarchicalWHTNoResCons factparams.ParamsHierarchicalRectMatNoResCons factparams.ParamsHierarchicalNoResCons factparams.ParamsHierarchicalRectMat fact.butterfly fact.check_fact_mat fact.eigtj fact.fact fact.fgft_palm fact.hierarchical_constends fact.hierarchical fact.hierarchical_mhtp fact.palm4msa_constends fact.palm4msa fact.palm4msa_mhtp fact.pinvtj fact.svdtj tools.omp demo.runall; do if matlab -nodisplay -r "addpath /usr/share/octave/packages/doctest-0.7.0/; setup_FAUST; doctest matfaust.$S; exit;" | tee /tmp/matlab_doctest_$S | grep FAIL; then exit 1; else exit 0; fi; done' - 'for S in Faust proj.sp proj.splin proj.spcol proj.splincol proj.const proj.supp proj.normlin proj.normcol proj.blockdiag proj.anticirc proj.circ proj.hankel proj.skperm proj.sptriu proj.sptril proj.spsymm proj.toeplitz proj.proj_id poly.poly poly.expm_multiply poly.next poly.basis poly.expm_inv_multiply factparams.ParamsHierarchicalWHTNoResCons factparams.ParamsHierarchicalRectMatNoResCons factparams.ParamsHierarchicalNoResCons factparams.ParamsHierarchicalRectMat fact.butterfly fact.check_fact_mat fact.eigtj fact.fact fact.fgft_palm fact.hierarchical_constends fact.hierarchical fact.hierarchical_mhtp fact.palm4msa_constends fact.palm4msa fact.palm4msa_mhtp fact.pinvtj fact.svdtj tools.omp demo.runall; do if matlab -nodisplay -r "addpath /usr/share/octave/packages/doctest-0.7.0/; setup_FAUST; doctest matfaust.$S; exit;" | tee /tmp/matlab_doctest_$S | grep FAIL; then exit 1; fi; done'
after_script: after_script:
- if [ $(rpm -qa faust | wc -l) -gt 0 ]; then sudo rpm -e faust;fi - if [ $(rpm -qa faust | wc -l) -gt 0 ]; then sudo rpm -e faust;fi
only: only:
