Commit 28a9b481 authored by Adrien Leman's avatar Adrien Leman Committed by hhakim
doc doxygen
parent ebf58863
......@@ -10,117 +10,13 @@ FAµST is developped at <a href="http://www.inria.fr/en/centre/rennes"> Rennes I
For more information on the FAµST Project, please visit the <a href="http://faust.gforge.inria.fr"> website</a>. <br>
<HR>
\section install_sec Installation
\subsection step1 Step 1: Download FAµST
FAµST Project is available on subversion repository.
- svn co ./FAUST <br>
\subsection step2 Step 2: Dependency
- library OpenBLAS http://www.openblas.net/
- library HDF5 https://www.hdfgroup.org/HDF5/release/obtainsrc.html#conf
- library MATIO is an C library for reading and writing MATLAB MAT files. https://sourceforge.net/projects/matio/ <br>
matio must be build with hdf5 : Support for MAT file version 7.3 requires the HDF5 library <br>
./configure --enable-extended-sparse=yes --with-matlab=matlab --with-hdf5=/home/library/hdf5-1.8.16/src/.libs <br>
make <br>
make check <br>
- MATLAB Version 2014b <br>
- GCC 4.7 Comptatible with GCC matlab for mex tools <br>
\subsection step3 Step 3: Configure
- ./cmake ../.. <br>
[option] : <br>
-G "CodeBlocks - Unix Makefiles" --> indicates that create both makefile and codeBlock projets. <br>
-DCMAKE_BUILD_TYPE="Debug" --> indicates that compilation is in debug mode. <br>
\subsection step4 Step 4: Make
- make -j4 --> build with 4 threads <br>
- build from codeBlock --> In debug mode for example <br>
\subsection step5 Step 5: Make install
- make install --> copy binary, libraries and documentation in the default output path.
<HR>
\section Example_sec Target & Example
Here is some examples of algorithm of the project FAUST. <br>
\subsection Target1 Target 1 : hierarchicalFactorization_FPP
./build/demo/run_test/src/hierarchicalFactorization_FPP.cpp <br>
Run the hierarchical factorization from a dense matrix contained in a file (can be MEG, Hierfact_compare or HADAMARD or other matrix; cf. directory ./misc/data/mat/ for data example). <br>
The precision FPP (Floating Point Precision) can be double or float. <br>
target name : build/demo/run_test/bin/hierarchicalFactorization_FPP <br>
\subsection Target2 Target 2 : hierarchicalFactorization_gpu_FPP
build/demo/run_test/src/hierarchicalFactorization_gpu_FPP.cpp <br>
Run the hierarchical factorization from a dense matrix contained in a file (can be MEG or other matrix). <br>
target name : build/demo/run_test/bin/hierarchicalFactorization_gpu_FPP <br>
# - Compute the multiplication between an faust-matrix and a vector. <br>
# - Evaluation of the time difference using faust-matrix and classical matrix (apply on MEG experiment or dictionnary learning). <br>
#target name : testing/bin/faust_test <br>
\subsection Target3 Target 3 : test_palm4MSA_FPP
./build/demo/run_test/src/test_palm4MSA_FPP.cpp <br>
Run a test of palm4MSA <br>
target name : build/demo/run_test/bin/test_palm4MSA_FPP <br>
or ./build/FAUST_OUTPUT/bin/test_palm4MSA_FPP<br>
\subsection Target4 Target 4 : multiply_compare_time_FPP
palm4MSA_test.cpp <br>
Use this script to make runtime comparison between Faust-vector product and Dense matrix-vector product , this script takes two arguments : <br>
- inputfile Faust_example.mat where all the Fausts with different Density, Dimensions and number of factor are stored.<br>
This input file is generated by test/gen_artificial_faust.m (default input file /home/aleman/WORK/FAUST/faust_v1.10/misc/data/mat/Faust_example.mat)<br>
- parameter NB_run the number multiplication made per given configuration (dimension, number of factor, RCG) (default value 100)<br>
<br>
The different computed times are stored in a single mat file :
- \output matfile /home/aleman/WORK/FAUST/faust_v1.10/build/demo/run_test/output/multiply_compare_time.mat
all the different computed times are stored in this single mat file into several variables
tdense : 4D array where all the dense time multiplication are stored
tfaust : 4D array where all the faust time multiplication are stored
DIMS : vector listing all the different dimension that are stored
RCGS : vector listing all the different (Ratio Complexity Gain (theoritical speed-up for faust multiplication))
NB_FACTS : vector listing all the different number of factor for a each configuration of faust
NB_RUN : number, the number of multiplication per configuration
\subsection Target5 Target 5 : launch_hierarchical_fact
configuration file : cmd_line/cmdline_function/launch_hierarchical_fact.cpp <br>
wrapper/cmd_line/src/launch_hierarchical_fact.cpp <br>
Compute the hierarchical factorization of a given data matrix A in cmdline mode. <br>
target name : wrapper/cmd_line/bin/launch_hierarchical_fact <br>
\subsection Target6 Target 6 : launch_palm4MSA
configuration file : cmd_line/cmdline_function/launch_palm4MSA.cpp <br>
wrapper/cmd_line/src/launch_palm4MSA.cpp <br>
Launch_palm4MSA command-line factorizes an input matrix corresponding to an operator of interest into J sparse factors and converges to a stationary point. <br>
target name : wrapper/cmd_line/bin/launch_palm4MSA <br>
<HR>
\section Demo Demonstration
\subsection Demo1 Demo 1 : Source localization in the context of functional brain imaging :
Faust was used in a experience of source localization in brain image.<br>
Different FAUST approximation of a Magnetoencephalography (MEG) gain matrix "Mi" was computed using hierarchical_fact.<br>
A SparseCoding algorithm was used to solve this source localization problem using the MEG gain matrix or its FAUST approximation.<br>
The following pictures illustrate the different trade-offs between speed-up and error of localization using MEG matrix or FAUST matrix.<br>
\image html MEG_computed_time.jpg "computing time" width=2cm
\image html MEG_distance.jpg "distance between estimated sources and true ones" width=2cm
in progress...<br>
\subsection Demo2 Demo 2 : Image denoising :
The goal of this demo is to enhancement a noisy image.<br>
in progress...<br>
See document Faust.pdf to install the toolbox FAµST.
<HR>
\authors Adrien Leman, Nicolas Bellot, Thomas Gautrais
\date 03/2016
<HR>
