Commit 27aa848e authored by hhakim's avatar hhakim
Add a new lazy linear op impl.: LazyLinearOp2.
parent 89421c48
......@@ -516,7 +516,7 @@ class LazyLinearOp(LinearOperator):
# self[i] is a row
return (1, self.shape[1])
elif isinstance(indices, slice):
#self[i:j] a group of contiguous lines
#self[i:j] a group of contiguous rows
start, stop, step = indices.start, indices.stop, indices.step
if stop is None:
stop = self.shape[0]
......@@ -654,8 +654,6 @@ class LazyLinearOp(LinearOperator):
elif str(ufunc) == "<ufunc 'subtract'>" and len(inputs) >= 2 and \
isLazyLinearOp(inputs[1]):
return inputs[1].__rsub__(inputs[0])
N = None
fausts = []
elif method == 'reduce':
# # not necessary numpy calls Faust.sum
# if ufunc == "<ufunc 'add'>":
......@@ -899,3 +897,830 @@ class LazyLinearOpKron(LazyLinearOp):
if not isinstance(B, np.ndarray):
B = B.toarray()
return np.kron(A, B)
class LazyLinearOp2(LinearOperator):
This class implements a lazy linear operator. A LazyLinearOp is a
specialization of a <a
href="https://docs.scipy.org/doc/scipy/reference/generated/scipy.sparse.linalg.LinearOperator.html">scipy.linalg.LinearOperator</a>.
The evaluation of any defined operation is delayed until a multiplication
by a dense matrix/vector, a call of LazyLinearOp.toarray or an explicit
evaluation through LazyLinearOp.eval.
To instantiate a LazyLinearOp look at pyfaust.lazylinop.asLazyLinearOp.
Warning: This code is in a beta status.
def __init__(self, lambdas, shape, root_obj):
Constructor. Not meant to be used directly.
Args:
init_lambda: starting operation.
shape: the initial shape of the operator.
root_obj: the initial object the operator is based on.
<b>See also:</b> LazyLinearOp.create, pyfaust.lazylinop.asLazyLinearOp.
if root_obj is not None:
if not hasattr(root_obj, 'ndim'):
raise TypeError('The starting object to initialize a'
' LazyLinearOperator must possess a ndim'
' attribute.')
if root_obj.ndim != 2:
raise ValueError('The starting object to initialize a LazyLinearOp '
'must have two dimensions, not: '+str(root_obj.ndim))
self.lambdas = lambdas
self._check_lambdas()
self.shape = shape
self._root_obj = root_obj #TODO: delete because it can't always be
# defined (create_from_funcs and hybrid operations)
self.dtype = None
super(LazyLinearOp2, self).__init__(self.dtype, self.shape)
def _check_lambdas(self):
if not isinstance(self.lambdas, dict):
raise TypeError('lambdas must be a dict')
keys = self.lambdas.keys()
for k in ['@', 'H', 'T', 'slice']:
if k not in keys:
raise ValueError(k+' is a mandatory lambda, it must be set in'
' self.lambdas')
@staticmethod
def create_from_op(obj):
Alias of pyfaust.lazylinop.asLazyLinearOp.
Args:
obj: cf. pyfaust.lazylinop.asLazyLinearOp.
Returns:
Example:
>>> from pyfaust.lazylinop import LazyLinearOp
>>> import numpy as np
>>> M = np.random.rand(10, 12)
>>> lM = LazyLinearOp.create(M)
>>> twolM = lM + lM
>>> twolM
<pyfaust.lazylinop.LazyLinearOp at 0x7fcd7d7750f0>
>>> import pyfaust as pf
>>> F = pf.rand(10, 12)
>>> lF = LazyLinearOp.create(F)
>>> twolF = lF + lF
>>> twolF
<pyfaust.lazylinop.LazyLinearOp at 0x7fcd7d774730>
<b>See also:</b> pyfaust.rand.
lambdas = {'@': lambda op: obj @ op}
lambdasT = {'@': lambda op: obj.T @ op}
lambdasH = {'@': lambda op: obj.T.conj() @ op}
lambdasC = {'@': lambda op: obj.conj() @ op}
# set lambdas temporarily to None (to satisfy the ctor)
# they'll be initialized later
for l in [lambdas, lambdasT, lambdasH, lambdasC]:
l['T'] = None
l['H'] = None
l['slice'] = None
lop = LazyLinearOp2(lambdas, obj.shape, obj)
lopT = LazyLinearOp2(lambdasT, (obj.shape[1], obj.shape[0]), obj)
lopH = LazyLinearOp2(lambdasH, (obj.shape[1], obj.shape[0]), obj)
lopC = LazyLinearOp2(lambdasC, (obj.shape[0], obj.shape[1]), obj)
# TODO: refactor with create_from_funcs (in ctor)
lambdas['T'] = lambda: lopT
lambdas['H'] = lambda: lopH
lambdas['slice'] = lambda indices: LazyLinearOp2._slice_lambda(lop,
indices)()
lambdasT['T'] = lambda: lop
lambdasT['H'] = lambda: lopC
lambdasT['slice'] = lambda indices: LazyLinearOp2._slice_lambda(lopT,
indices)()
lambdasH['T'] = lambda: lopC
lambdasH['H'] = lambda: lop
lambdasH['slice'] = lambda indices: LazyLinearOp2._slice_lambda(lopH,
indices)()
return lop
@staticmethod
def create_from_scalar(s, shape=None):
if shape is None:
shape = (1, 1)
a = np.ones(shape) * s
return create_from_op(a)
@staticmethod
def create_from_funcs(matmat, rmatmat, shape):
from scipy.sparse import eye as seye
#MX = lambda X: matmat(np.eye(shape[1])) @ X
MX = lambda X: matmat(X)
MTX = lambda X: rmatmat(X.T).T
MHX = lambda X: rmatmat(X)
lambdas = {'@': MX}
lambdasT = {'@': lambda op: rmatmat(op.real).conj() -
rmatmat(1j * op.imag).conj()}
lambdasH = {'@': MHX}
lambdasC = {'@': lambda op: matmat(op.real).conj() -
matmat(1j * op.imag)}
l['T'] = None
l['H'] = None
l['slice'] = None
lop = LazyLinearOp2(lambdas, shape, None)
lopT = LazyLinearOp2(lambdasT, (shape[1], shape[0]), None)
lopH = LazyLinearOp2(lambdasH, (shape[1], shape[0]), None)
lopC = LazyLinearOp2(lambdasC, shape, None)
indices)()
indices)()
indices)()
return lop
def _checkattr(self, attr):
if self._root_obj is not None and not hasattr(self._root_obj, attr):
raise TypeError(attr+' is not supported by the root object of this'
' LazyLinearOp')
def _slice_lambda(lop, indices):
#TODO: handle indices[0] or indices[1] == ':' ?
s = lambda: \
LazyLinearOp2.create_from_op(seye(lop.shape[0],
format='csr')[indices[0]]) \
@ lop @ LazyLinearOp2.create_from_op(seye(lop.shape[1], format='csr')[:, indices[1]])
return s
@property
def ndim(self):
Returns the number of dimensions of the LazyLinearOp (it always 2).
return 2
def transpose(self):
Returns the LazyLinearOp transpose.
self._checkattr('transpose')
return self.lambdas['T']()
@property
def T(self):
return self.transpose()
def conj(self):
Returns the LazyLinearOp conjugate.
self._checkattr('conj')
return self.T.H
def conjugate(self):
return self.conj()
def getH(self):
Returns the LazyLinearOp adjoint/transconjugate.
#self._checkattr('getH')
return self.lambdas['H']()
@property
def H(self):
The LazyLinearOp adjoint/transconjugate.
return self.getH()
def _adjoint(self):
return self.H
def _slice(self, indices):
return self.lambdas['slice'](indices)
def __add__(self, op):
Returns the LazyLinearOp for self + op.
Args:
op: an object compatible with self for this binary operation.
self._checkattr('__add__')
if not LazyLinearOp2.isLazyLinearOp(op):
op = LazyLinearOp2.create_from_op(op)
lambdas = {'@': lambda o: self @ o + op @ o,
'H': lambda: self.H + op.H,
'T': lambda: self.T + op.T,
'slice': lambda indices: self._slice(indices) + op._slice(indices)
new_op = LazyLinearOp2(lambdas=lambdas,
shape=tuple(self.shape),
root_obj=None)
return new_op
def __radd__(self, op):
Returns the LazyLinearOp for op + self.
Args:
return self.__add__(op)
def __iadd__(self, op):
Not Implemented self += op.
raise NotImplementedError(LazyLinearOp.__name__+".__iadd__")
# can't do as follows, it recurses indefinitely because of self.eval
# self._checkattr('__iadd__')
# self = LazyLinearOp2(init_lambda=lambda:
# (self.eval()).\
# __iadd__(LazyLinearOp._eval_if_lazy(op)),
# shape=(tuple(self.shape)),
# root_obj=self._root_obj)
# return self
def __sub__(self, op):
Returns the LazyLinearOp for self - op.
Args:
self._checkattr('__sub__')
lambdas = {'@': lambda o: self @ o - op @ o,
'H': lambda: self.H - op.H,
'T': lambda: self.T - op.T,
'slice': lambda indices: self._slice(indices) - op._slice(indices)
root_obj=None)
return new_op
def __rsub__(self, op):
Returns the LazyLinearOp for op - self.
Args:
self._checkattr('__rsub__')
lambdas = {'@': lambda o: op @ o - self @ o,
'H': lambda: op.H - self.H,
'T': lambda: op.T - self.T,
'slice': lambda indices: op._slice(indices) - self._slice(indices)
shape=self.shape,
root_obj=None)
return new_op
def __isub__(self, op):
Not implemented self -= op.
raise NotImplementedError(LazyLinearOp.__name__+".__isub__")
# self._checkattr('__isub__')
# (self.eval()).\
# __isub__(LazyLinearOp._eval_if_lazy(op)),
# return self
def __truediv__(self, s):
Returns the LazyLinearOp for self / s.
Args:
s: a scalar.
new_op = self * 1/s
return new_op
def __itruediv__(self, op):
Not implemented self /= op.
raise NotImplementedError(LazyLinearOp.__name__+".__itruediv__")
# self._checkattr('__itruediv__')
# (self.eval()).\
# __itruediv__(LazyLinearOp._eval_if_lazy(op)),
# return self
def _sanitize_matmul(self, op, swap=False):
self._checkattr('__matmul__')
if not hasattr(op, 'shape'):
raise TypeError('op must have a shape attribute')
if swap and op.shape[1] != self.shape[0] or not swap and self.shape[1] != op.shape[0]:
raise ValueError('dimensions must agree')
def __matmul__(self, op):
Returns self @ op as a sparse matrix / dense array or as a LazyLinearOp.
Args:
Returns:
If op is an numpy array or a scipy matrix the function returns (self @
op) as a numpy array or a scipy matrix. Otherwise it returns the
LazyLinearOp for the multiplication self @ op.
from scipy.sparse import issparse
self._sanitize_matmul(op)
if isinstance(op, np.ndarray) or issparse(op):
if op.ndim == 1 and self._root_obj is not None:
res = self.lambdas['@'](op.reshape(op.size, 1)).ravel()
else:
res = self.lambdas['@'](op)
else:
lambdas = {'@': lambda o: self @ (op @ o),
'H': lambda: op.H @ self.H,
'T': lambda: op.T @ self.T,
'slice': lambda indices: self._slice((indices[0],
slice(0,
self.shape[1])))\
@ op._slice((slice(0, op.shape[0]), indices[1]))
res = LazyLinearOp2(lambdas=lambdas,
shape=(self.shape[0], op.shape[1]),
root_obj=None)
# res = LazyLinearOp2.create_from_op(super(LazyLinearOp2,
# self).__matmul__(op))
return res
def dot(self, op):
Alias of LazyLinearOp.__matmul__.
return self.__matmul__(op)
def matvec(self, op):
Returns the LazyLinearOp for the multiplication self.matvec(op) or the np.ndarray
resulting of the evaluation of self.matvec(op) if op is a np.ndarray.
Args:
op: must be a vector (row or column).
<b>See also</b>: LazyLinearOp.__matmul__,<a
href="https://docs.scipy.org/doc/scipy/reference/generated/scipy.sparse.linalg.LinearOperator.matvec.html#scipy.sparse.linalg.LinearOperator.matvec">
scipy.linalg.LinearOperator.matvec</a>
if not hasattr(op, 'shape') or not hasattr(op, 'ndim'):
raise TypeError('op must have shape and ndim attributes')
if op.ndim > 2 or op.ndim == 0:
raise ValueError('op.ndim must be 1 or 2')
if op.ndim != 1 and op.shape[0] != 1 and op.shape[1] != 1:
raise ValueError('op must be a vector -- attribute ndim to 1 or'
' shape[0] or shape[1] to 1')
def _rmatvec(self, op):
Returns the LazyLinearOp for self^H @ v, where self^H is the conjugate transpose of A.
# LinearOperator need.
return self.T.conj() @ op
def _matmat(self, op):
def _rmatmat(self, op):
def __imatmul__(self, op):
Not implemented self @= op.
raise NotImplementedError(LazyLinearOp.__name__+".__imatmul__")
def __rmatmul__(self, op):
Returns the LazyLinearOp for op @ self.
Args:
self._checkattr('__rmatmul__')
self._sanitize_matmul(op, swap=True)
res = op @ self.toarray()
else:
lambdas = {'@': lambda o: (op @ self) @ o,
'H': lambda: self.H @ op.H,
'T': lambda: self.T @ op.T,
'slice': lambda indices: (op @ self)._slice(indices)
shape=(op.shape[0], self.shape[1]),
root_obj=None)
return res
def __mul__(self, other):
Returns the LazyLinearOp for self * other.
Args:
other: a scalar or a vector.
self._checkattr('__mul__')
from scipy.sparse import eye, diags
if np.isscalar(other):
S = eye(self.shape[1], format='csr') * other
lop = LazyLinearOp2.create_from_op(S)
elif hasattr(other, 'ndim') and other.ndim == 1 or other.ndim == 2 and other.shape[0] == 1:
if other.size == 1:
return self * self.item()
else:
D = diags(other.squeeze())
lop = LazyLinearOp2.create_from_op(D)
else:
raise TypeError('Unsupported type for other')
new_op = self @ lop
return new_op
def __rmul__(self, s):
Returns the LazyLinearOp for op * self.
Args:
s: a scalar.
# because s is a scalar, it is commutative
# for vector broadcasting too
return self * s
def __imul__(self, op):
Not implemented self *= op.
raise NotImplementedError(LazyLinearOp.__name__+".__imul__")
def toarray(self):
Returns the numpy array resulting from self evaluation.
#from scipy.sparse import eye
#return self @ eye(self.shape[1], self.shape[1], format='csr')
# don't use csr because of function based LazyLinearOp2
# (e.g. scipy fft receives only numpy array)
return self @ np.eye(self.shape[1])
def __getitem__(self, indices):
Returns the LazyLinearOp for slicing/indexing.
Args:
indices: array of length 1 or 2 which elements must be slice, integer or
Ellipsis (...). Note that using Ellipsis for more than two indices is forbidden.
self._checkattr('__getitem__')
if isinstance(indices, tuple) and len(indices) == 2 and isinstance(indices[0], int) and isinstance(indices[1], int):
return self.toarray().__getitem__(indices)
elif isinstance(indices, slice) or isinstance(indices[0], slice) and \
isinstance(indices[0], slice):
return self._slice(indices)
else:
raise Exception('Other __getitem__ call than slicing and item'
' access is not yet supported')
def _newshape_getitem(self, indices):
empty_lop_except = Exception("Cannot create an empty LazyLinearOp.")
if isinstance(indices, (np.ndarray, list)):
return (len(indices), self.shape[1])
elif indices == Ellipsis:
return self.shape
elif isinstance(indices,int):
# self[i] is a row
if stop is None:
if start is None:
start = 0
if step is None:
step = 1
return ((stop - start) // step, self.shape[1])
elif isinstance(indices, tuple):
if len(indices) == 1:
return self._newshape_getitem(indices[0])
elif len(indices) == 2:
if(isinstance(indices[0], int) and isinstance(indices[1],int)):
# item
return (1, 1)
else:
raise IndexError('Too many indices.')
if indices[0] == Ellipsis:
if indices[1] == Ellipsis:
raise IndexError('an index can only have a single ellipsis '
else:
# all rows
new_shape = self.shape
elif isinstance(indices[0], int):
# line F[i]
new_shape = (1, self.shape[1])
elif isinstance(indices[0], slice):
start, stop, step = indices[0].start, indices[0].stop, indices[0].step
if stop is None:
if start is None:
start = 0
if step is None:
step = 1
new_shape = ((stop - start) // step, self.shape[1])
elif isinstance(indices[0], (list, np.ndarray)):
if len(indices[0]) == 0: raise empty_lop_except
new_shape = (len(indices[0]), self.shape[1])
else:
raise idx_error_exception
# all columns
elif isinstance(indices[1], int):
# col F[:, i]
new_shape = (new_shape[0], 1)
elif isinstance(indices[1], slice):
start, stop, step = indices[1].start, indices[1].stop, indices[1].step
if stop is None:
stop = self.shape[1]
if start is None:
start = 0
if step is None:
step = 1
new_shape = (new_shape[0], (stop - start) // step)
elif isinstance(indices[1], (list, np.ndarray)):
if len(indices[1]) == 0: raise empty_lop_except
new_shape = (new_shape[0], len(indices[1]))
else:
return new_shape
def concatenate(self, *ops, axis=0):
Returns the LazyLinearOp for the concatenation of self and op.
Args:
axis: axis of concatenation (0 for rows, 1 for columns).
from pyfaust import concatenate as cat
nrows = self.shape[0]
ncols = self.shape[1]
out = self
for op in ops:
if axis == 0:
out = out.vstack(op)
elif axis == 1:
out = out.hstack(op)
else:
raise ValueError('axis must be 0 or 1')
return out
def _vstack_slice(self, op, indices):
rslice = indices[0]
if rslice.step is not None:
raise ValueError('Can\'t handle non-contiguous slice -- step > 1')
if rslice.stop > self.shape[0] + op.shape[0]:
raise ValueError('Slice overflows the row dimension')
if rslice.start >= 0 and rslice.stop <= self.shape[0]:
# the slice is completly in self
return lambda: self._slice(indices)
elif rslice.start >= self.shape[0]:
# the slice is completly in op
return lambda: op._slice((slice(rslice.start - self.shape[0],
rslice.stop - self.shape[0]) ,indices[1]))
else:
# the slice is overlapping self and op
self_slice = self._slice((slice(rslice.start, self.shape[0]), indices[1]))
op_slice = self._slice((slice(0, rslice.end - self.shape[0]), indices[1]))
return lambda: self_slice.vstack(op_slice)
def _vstack_mul_lambda(self, op, o):
mul_mat = lambda : np.vstack((self @ o, op @ o))
mul_vec = lambda : mul_mat().ravel()
mul_mat_vec = lambda : mul_vec() if o.ndim == 1 else mul_mat()
mul = lambda: mul_mat_vec() if isinstance(o, np.ndarray) \
or issparse(o) else self.vstack(op) @ o
return mul
def vstack(self, op):
if self.shape[1] != op.shape[1]:
raise ValueError('The number of columns of self and op are not the'
' same')
lambdas = {'@': lambda o: self._vstack_mul_lambda(op, o)(),
'H': lambda: self.H.hstack(op.H),
'T': lambda: self.T.hstack(op.T),
'slice': lambda indices: self._vstack_slice(op, indices)()
shape=(self.shape[0] + op.shape[0], self.shape[1]),
root_obj=None)
return new_op
def _hstack_slice(self, op, indices):
cslice = indices[1]
if cslice.step is not None:
if cslice.stop > self.shape[1] + op.shape[1]:
if cslice.start >= 0 and cslice.stop <= self.shape[1]:
elif cslice.start >= self.shape[1]:
return lambda: op._slice((indices[0], slice(cslice.start - self.shape[1],
cslice.stop - self.shape[1])))
else:
self_slice = self._slice((indices[0], slice(cslice.start, self.shape[1])))
op_slice = self._slice((indices[0], slice(0, cslice.end - self.shape[1])))
def _hstack_mul_lambda(self, op, o):
if isinstance(o, np.ndarray) or issparse(o):
if o.ndim == 1:
return lambda: self @ o[:self.shape[1]] + op @ o[self.shape[1]:]
else:
return lambda: self @ o[:self.shape[1],:] + op @ o[self.shape[1]:, :]
else:
return lambda: \
self @ o._slice((slice(0, self.shape[1]), slice(0,
o.shape[1]))) \
+ op @ o._slice((slice(self.shape[1], o.shape[0]), slice(0, o.shape[1])))
def hstack(self, op):
if self.shape[0] != op.shape[0]:
' same')
lambdas = {'@': lambda o: self._hstack_mul_lambda(op, o)(),
'H': lambda: self.H.vstack(op.H),
'T': lambda: self.T.vstack(op.T),
'slice': lambda indices: self._hstack_slice(op, indices)()
shape=(self.shape[0], self.shape[1]
+ op.shape[1]),
root_obj=None)
return new_op
@property
def real(self):
Returns the LazyLinearOp for real.
lambdas = {'@': lambda o: (self @ o.real).real + \
(self @ o.imag * 1j).real if isinstance(o, np.ndarray) \
or issparse(o) else real(self @ o),
'H': lambda: self.T.real,
'T': lambda: self.T.real,
'slice': lambda indices: self._slice(indices).real
root_obj=None)
return new_op
@property
def imag(self):
Returns the LazyLinearOp for imag.
lambdas = {'@': lambda o: (self @ o.real).imag + \
1j * (self @ o.imag).imag if isinstance(o, np.ndarray) \
'H': lambda: self.T.imag,
'T': lambda: self.T.imag,
'slice': lambda indices: self._slice(indices).imag
root_obj=None)
return new_op
@staticmethod
def isLazyLinearOp(obj):
Returns True if obj is a LazyLinearOp, False otherwise.
return isinstance(obj, LazyLinearOp2)
def __array_ufunc__(self, ufunc, method, *inputs, **kwargs):
if method == '__call__':
if str(ufunc) == "<ufunc 'matmul'>" and len(inputs) >= 2 and \
LazyLinearOp2.isLazyLinearOp(inputs[1]):
return inputs[1].__rmatmul__(inputs[0])
elif str(ufunc) == "<ufunc 'multiply'>" and len(inputs) >= 2 and \
return inputs[1].__rmul__(inputs[0])
elif str(ufunc) == "<ufunc 'add'>" and len(inputs) >= 2 and \
return inputs[1].__radd__(inputs[0])
# if len(inputs) == 1 and pyfaust.isLazyLinearOp(inputs[0]):
# #return inputs[0].sum(*inputs[1:], **kwargs)
# else:
return NotImplemented
def __array__(self, *args, **kwargs):
return self
def __array_function__(self, func, types, args, kwargs):
if func not in HANDLED_FUNCTIONS:
# Note: this allows subclasses that don't override
# __array_function__ to handle Faust objects
if not all(issubclass(t, LazyLinearOp) for t in types):
return HANDLED_FUNCTIONS[func](*args, **kwargs)
