Commit 25149d10 authored by hhakim's avatar hhakim
Exclude Matlab wrapper functions mtimes_trans and subsasgn from doxygen doc.
[skip ci]
parent 39d662ae
...@@ -517,6 +517,8 @@ EXCLUDE_SYMLINKS = NO ...@@ -517,6 +517,8 @@ EXCLUDE_SYMLINKS = NO
EXCLUDE_PATTERNS = *faust_MatDense_gpu.h *faust_MatSparse_gpu.h EXCLUDE_PATTERNS = *faust_MatDense_gpu.h *faust_MatSparse_gpu.h
EXCLUDE_SYMBOLS = mtimes_trans subsasgn
# The EXAMPLE_PATH tag can be used to specify one or more files or # The EXAMPLE_PATH tag can be used to specify one or more files or
# directories that contain example code fragments that are included (see # directories that contain example code fragments that are included (see
# the \include command). # the \include command).
