- Downloads
Fix svdtj tests for complex<float> on macOS.
The faster heuristic doesn't work so well for complex<float>. See macOS test errors: https://cdash-ci.inria.fr/test/2751663 Extract: ==================== test 2: rel. error svdtj input conf: J1: 0 J2: 0 t1: -1 t2: -1 tol: 0.1 relErr: 1 order: -1 enable_large_Faust: 0 matrix norm: 7.59428 err_period: 100 U factor : 99, relative err.: 9.60274e-07 V factor : 99, relative err.: 6.40183e-07 SVDTJ iteration: 100, singular values approximate square norm error: 8.92282e-06 U factor : 199, relative err.: 1.49376e-06 V factor : 199, relative err.: 1.17367e-06 Warning: U approximate accuracy is not increasing anymore, stopped eigtj tunning for U. U current error: 1.49376e-06, previous error: 9.60274e-07 Warning: V approximate accuracy is not increasing anymore, stopped eigtj tunning for V. V current error: 1.17367e-06, previous error: 6.40183e-07 U, V number of factors: 100, 100 U, V RCGs: 0.930909 0.46556 [...] svdtj norm err: -6.2789e-08 svdtj square norm err: -7.62939e-06 Assertion failed: (norm_err <= tol), function auto_tests, file /Users/ci/builds/sonxyZB3/0/faustgrp/faust/build_FaustMacOSPythonMatlab/run_test/src/test_svdtj_complexfloat.cpp, line 146.
