Commit 1e7ee422 authored by testcdash Nicolas Bellot's avatar testcdash Nicolas Bellot Committed by hhakim
find matlab bat
parent 99f623f2
@echo off
set "find_exe=matlab.exe"
(where matlab.exe) > logPath.txt
(where /R "C:\\Program Files\\MATLAB" matlab.exe) >> logPath.txt
(where /R "C:\\Program Files (x86)\\MATLAB" matlab.exe) >> logPath.txt
set MATLAB_EXE_DIR_TMP=
set /p MATLAB_EXE_DIR_TMP=<logPath.txt
REM for /f "delims=" %%i in ('type logPath.txt') do (set MATLAB_DIR_TMP=%%i && echo %%i)
echo environment variable is defined for matlab Path : %MATLAB_EXE_DIR_TMP%
