Commit 19f794f9 authored by hhakim's avatar hhakim
Add lazilinop.zeros + doc.
parent f5dd789a
...@@ -1508,3 +1508,41 @@ def block_diag(*lops, mt=False): ...@@ -1508,3 +1508,41 @@ def block_diag(*lops, mt=False):
return LazyLinearOperator((coffsets[-1], roffsets[-1]), matmat=lambda x: return LazyLinearOperator((coffsets[-1], roffsets[-1]), matmat=lambda x:
matmat(x, lAx, roffsets), matmat(x, lAx, roffsets),
rmatmat=lambda x: matmat(x, lAHx, coffsets)) rmatmat=lambda x: matmat(x, lAHx, coffsets))
def zeros(shape):
Returns a zeros LazyLinearOp.
Args:
shape: the shape of the operator.
Example:
>>> from pyfaust.lazylinop import zeros
>>> import numpy as np
>>> Lz = zeros((10, 12))
>>> x = np.random.rand(12)
>>> Lz @ x
array([0., 0., 0., 0., 0., 0., 0., 0., 0., 0.])
def _matmat(op, shape):
if not hasattr(op, 'shape') or not hasattr(op, 'ndim'):
raise TypeError('Zero LazyLinearOp can\'t be multiplied by'
' something without a shape or a ndim')
if op.shape[0] != shape[1]:
raise ValueError('Dimensions must agree')
if LazyLinearOp.isLazyLinearOp(op):
return zeros((shape[0], op.shape[1]))
# TODO: another output type than numpy array?
elif op.ndim == 2:
return np.zeros((shape[0], op.shape[1]), dtype=op.dtype)
elif op.ndim > 2:
return np.zeros((*op.shape[:-2], shape[0], op.shape[-1]),
dtype=op.dtype)
else:
# op.ndim == 1
return np.zeros((shape[0],))
return LazyLinearOperator(shape, matmat=lambda x:
_matmat(x, shape),
rmatmat=lambda x: _matmat(x, (shape[1],
shape[0])))
