Commit 195fe71d authored by hhakim's avatar hhakim
Replace py3.9 by py3.10 in package generations.
parent 004b23f8
Pipeline #836373 passed
...@@ -5,7 +5,7 @@ variables: ...@@ -5,7 +5,7 @@ variables:
# DURL: "https://gitlab.inria.fr/faustgrp/gforge_files/-/raw/master/" # DURL: "https://gitlab.inria.fr/faustgrp/gforge_files/-/raw/master/"
DURL: "https://faustgrp.gitlabpages.inria.fr/faust/last-doc/html/" DURL: "https://faustgrp.gitlabpages.inria.fr/faust/last-doc/html/"
DFILE: "faust_data.zip" DFILE: "faust_data.zip"
JOB_PYTHON: "python3.9" # if set again in job, it hides this one (precedence: https://docs.gitlab.com/13.6/ee/ci/variables/#priority-of-environment-variables) JOB_PYTHON: "python3.10" # if set again in job, it hides this one (precedence: https://docs.gitlab.com/13.6/ee/ci/variables/#priority-of-environment-variables)
WIN_PY_VER: '3.11' # default python version used to build python wrapper on windows (for both whl package and nsis .exe) WIN_PY_VER: '3.11' # default python version used to build python wrapper on windows (for both whl package and nsis .exe)
NUX_PY_VER: '3.11' # default python version used for linux system packages (.rpm and .deb) NUX_PY_VER: '3.11' # default python version used for linux system packages (.rpm and .deb)
MACOS_PY_VER: '3.11' # default python version used for macOS system packages (.pkg) MACOS_PY_VER: '3.11' # default python version used for macOS system packages (.pkg)
...@@ -229,9 +229,9 @@ pyfaust_test_code_coverage: ...@@ -229,9 +229,9 @@ pyfaust_test_code_coverage:
# use conda rather than venv because python built on VM has not been # use conda rather than venv because python built on VM has not been
# built with --enable-loadable-sqlite-extensions (and sqlite-devel) # built with --enable-loadable-sqlite-extensions (and sqlite-devel)
# but it is a need of coverave python package # but it is a need of coverave python package
# so we use py3.9 from conda # so we use py3.10 from conda
- cmake -P misc/download_unzip_faust_misc_data.cmake # tests need data - cmake -P misc/download_unzip_faust_misc_data.cmake # tests need data
- conda create -n test_coverage_pyfaust python==3.9 - conda create -n test_coverage_pyfaust python==3.10
- conda activate test_coverage_pyfaust - conda activate test_coverage_pyfaust
# install pyfaust with pip # install pyfaust with pip
- pip install $(find ./ -name "*pyfaust*whl") - pip install $(find ./ -name "*pyfaust*whl")
...@@ -556,7 +556,7 @@ pkg_macos_purepy_rev: ...@@ -556,7 +556,7 @@ pkg_macos_purepy_rev:
pkg_linux_purepy_rev: pkg_linux_purepy_rev:
extends: .pkg_purepy_rev extends: .pkg_purepy_rev
variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: $LINUX_MATIO_SLIB_PATH, Z_STATIC_LIB_PATH: $LINUX_ZLIB_SLIB_PATH, HDF5_STATIC_LIB_PATH: $LINUX_HDF5_SLIB_PATH, BUILD_MULTITHREAD: "ON", NOPY2: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "../gpu_mod", EXPERIMENTAL_PKG: "ON", CMAKE_CXX_COMPILER: "clang++"} #, PYTHON_PATH: '/usr/local/bin/python3.9', JOB_PYTHON: 'python3.9'} variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: $LINUX_MATIO_SLIB_PATH, Z_STATIC_LIB_PATH: $LINUX_ZLIB_SLIB_PATH, HDF5_STATIC_LIB_PATH: $LINUX_HDF5_SLIB_PATH, BUILD_MULTITHREAD: "ON", NOPY2: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "../gpu_mod", EXPERIMENTAL_PKG: "ON", CMAKE_CXX_COMPILER: "clang++"} #, PYTHON_PATH: '/usr/local/bin/python3.10', JOB_PYTHON: 'python3.10'}
tags: tags:
- linux - linux
- tux_packager - tux_packager
...@@ -588,7 +588,7 @@ pkg_linux_purepy_rev: ...@@ -588,7 +588,7 @@ pkg_linux_purepy_rev:
pkg_macos_purepy_release: pkg_macos_purepy_release:
extends: .pkg_purepy_release extends: .pkg_purepy_release
variables: {MATIO_STATIC_LIB_PATH: $MACOS_MATIO_SLIB_PATH, Z_STATIC_LIB_PATH: $MACOS_ZLIB_SLIB_PATH, HDF5_STATIC_LIB_PATH: $MACOS_HDF5_SLIB_PATH, SZIP_STATIC_LIB_PATH: $MACOS_SZIP_SLIB_PATH, BUILD_MULTITHREAD: "ON", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", NOPY2: "ON", CMAKE_CXX_COMPILER: "/opt/local/bin/clang++-mp-9.0", PYTHON_PATH: '/opt/local/bin/python3.9', JOB_PYTHON: 'python3.9'} variables: {MATIO_STATIC_LIB_PATH: $MACOS_MATIO_SLIB_PATH, Z_STATIC_LIB_PATH: $MACOS_ZLIB_SLIB_PATH, HDF5_STATIC_LIB_PATH: $MACOS_HDF5_SLIB_PATH, SZIP_STATIC_LIB_PATH: $MACOS_SZIP_SLIB_PATH, BUILD_MULTITHREAD: "ON", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", NOPY2: "ON", CMAKE_CXX_COMPILER: "/opt/local/bin/clang++-mp-9.0", PYTHON_PATH: '/opt/local/bin/python3.10', JOB_PYTHON: 'python3.10'}
before_script: before_script:
- VERSION=$CI_COMMIT_TAG - VERSION=$CI_COMMIT_TAG
- if [[ ! -d 'build' ]]; then mkdir build;fi; cd build - if [[ ! -d 'build' ]]; then mkdir build;fi; cd build
...@@ -614,7 +614,7 @@ pkg_macos_purepy_release_torch_linked: ...@@ -614,7 +614,7 @@ pkg_macos_purepy_release_torch_linked:
pkg_linux_purepy_release: pkg_linux_purepy_release:
variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: $LINUX_MATIO_SLIB_PATH, Z_STATIC_LIB_PATH: $LINUX_ZLIB_SLIB_PATH, HDF5_STATIC_LIB_PATH: $LINUX_HDF5_SLIB_PATH, BUILD_MULTITHREAD: "ON", NOPY2: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "../gpu_mod", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", CMAKE_CXX_COMPILER: "clang++", PYTHON_PATH: '/usr/local/bin/python3.9', JOB_PYTHON: 'python3.9'} variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: $LINUX_MATIO_SLIB_PATH, Z_STATIC_LIB_PATH: $LINUX_ZLIB_SLIB_PATH, HDF5_STATIC_LIB_PATH: $LINUX_HDF5_SLIB_PATH, BUILD_MULTITHREAD: "ON", NOPY2: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "../gpu_mod", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", CMAKE_CXX_COMPILER: "clang++", PYTHON_PATH: '/usr/local/bin/python3.10', JOB_PYTHON: 'python3.10'}
after_script: after_script:
# verify the pyfaust root with doctest (no go on failure) # verify the pyfaust root with doctest (no go on failure)
- if [[ ! $(basename $PWD) = 'build' ]]; then cd build;fi - if [[ ! $(basename $PWD) = 'build' ]]; then cd build;fi
...@@ -641,7 +641,7 @@ pkg_linux_purepy_release_extra_pyver: ...@@ -641,7 +641,7 @@ pkg_linux_purepy_release_extra_pyver:
pkg_linux_purepy_release_openblaso: pkg_linux_purepy_release_openblaso:
variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: $LINUX_MATIO_SLIB_PATH, Z_STATIC_LIB_PATH: $LINUX_ZLIB_SLIB_PATH, HDF5_STATIC_LIB_PATH: $LINUX_HDF5_SLIB_PATH, BUILD_MULTITHREAD: "ON", NOPY2: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "../gpu_mod", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", CMAKE_CXX_COMPILER: "clang++", USE_OPENBLASO: "ON", PYTHON_PATH: '/usr/local/bin/python3.9', JOB_PYTHON: 'python3.9'} variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: $LINUX_MATIO_SLIB_PATH, Z_STATIC_LIB_PATH: $LINUX_ZLIB_SLIB_PATH, HDF5_STATIC_LIB_PATH: $LINUX_HDF5_SLIB_PATH, BUILD_MULTITHREAD: "ON", NOPY2: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "../gpu_mod", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", CMAKE_CXX_COMPILER: "clang++", USE_OPENBLASO: "ON", PYTHON_PATH: '/usr/local/bin/python3.10', JOB_PYTHON: 'python3.10'}
tags: tags:
- linux - linux
...@@ -710,7 +710,7 @@ pkg_win_purepy_rev: ...@@ -710,7 +710,7 @@ pkg_win_purepy_rev:
pkg_win_purepy_release: pkg_win_purepy_release:
extends: .pkg_win_purepy extends: .pkg_win_purepy
variables: {BUILD_CONFIG: "Release", GIT_SUBMODULE_STRATEGY: recursive, EXPERIMENTAL_PKG: "OFF", WIN_PY_VER: '3.9'} variables: {BUILD_CONFIG: "Release", GIT_SUBMODULE_STRATEGY: recursive, EXPERIMENTAL_PKG: "OFF", WIN_PY_VER: '3.10'}
- 'set VERSION=%CI_COMMIT_TAG%' - 'set VERSION=%CI_COMMIT_TAG%'
artifacts: artifacts:
...@@ -810,7 +810,7 @@ test_linux_pkg_release: ...@@ -810,7 +810,7 @@ test_linux_pkg_release:
- PYVER=$($JOB_PYTHON --version | awk '{print $2}' | sed -e 's/\.//;s/\(.*\)\..*/\1/') - PYVER=$($JOB_PYTHON --version | awk '{print $2}' | sed -e 's/\.//;s/\(.*\)\..*/\1/')
- $JOB_PYTHON -m pip install --upgrade pip - $JOB_PYTHON -m pip install --upgrade pip
- SYS=$(if uname -a | grep -q Darwin; then echo macosx; else echo linux; fi) - SYS=$(if uname -a | grep -q Darwin; then echo macosx; else echo linux; fi)
# avoid to build from sources scipy==1.10 and matplolib==3.6.3, either with py3.9 or 3.11 # avoid to build from sources scipy==1.10 and matplolib==3.6.3, either with py3.10 or 3.11
- if [ "$SYS" = macosx -a "$PYVER" = "39" ]; then pip install scipy==1.9 matplotlib==3.5.3; fi - if [ "$SYS" = macosx -a "$PYVER" = "39" ]; then pip install scipy==1.9 matplotlib==3.5.3; fi
- if [ "$SYS" = macosx -a "$PYVER" = "311" ]; then wget https://files.pythonhosted.org/packages/7a/23/13579b64ab458782a43e11e1ad095488458b8df099063ae07773666adada/scipy-1.10.0-cp311-cp311-macosx_10_15_x86_64.whl; mv scipy-1.10.0-cp311-cp311-macosx_10_15_x86_64.whl scipy-1.10.0-cp311-cp311-macosx_10_9_x86_64.whl; pip install scipy-1.10.0-cp311-cp311-macosx_10_9_x86_64.whl; fi - if [ "$SYS" = macosx -a "$PYVER" = "311" ]; then wget https://files.pythonhosted.org/packages/7a/23/13579b64ab458782a43e11e1ad095488458b8df099063ae07773666adada/scipy-1.10.0-cp311-cp311-macosx_10_15_x86_64.whl; mv scipy-1.10.0-cp311-cp311-macosx_10_15_x86_64.whl scipy-1.10.0-cp311-cp311-macosx_10_9_x86_64.whl; pip install scipy-1.10.0-cp311-cp311-macosx_10_9_x86_64.whl; fi
- if [ "$SYS" = macosx -a "$JOB_PYTHON" = "python3.11" ]; then wget https://files.pythonhosted.org/packages/09/ac/f3c841a09bb7479832832472ef9ec49c2069f437d0266c1168d586eee601/matplotlib-3.6.3-cp311-cp311-macosx_10_12_x86_64.whl;mv matplotlib-3.6.3-cp311-cp311-macosx_10_12_x86_64.whl matplotlib-3.6.3-cp311-cp311-macosx_10_9_x86_64.whl;pip install matplotlib-3.6.3-cp311-cp311-macosx_10_9_x86_64.whl; fi - if [ "$SYS" = macosx -a "$JOB_PYTHON" = "python3.11" ]; then wget https://files.pythonhosted.org/packages/09/ac/f3c841a09bb7479832832472ef9ec49c2069f437d0266c1168d586eee601/matplotlib-3.6.3-cp311-cp311-macosx_10_12_x86_64.whl;mv matplotlib-3.6.3-cp311-cp311-macosx_10_12_x86_64.whl matplotlib-3.6.3-cp311-cp311-macosx_10_9_x86_64.whl;pip install matplotlib-3.6.3-cp311-cp311-macosx_10_9_x86_64.whl; fi
...@@ -823,7 +823,7 @@ test_linux_pkg_release: ...@@ -823,7 +823,7 @@ test_linux_pkg_release:
- tags - tags
test_macos_purepy_release: # take care to keep this variable consistent with the version used in pkg_macos_purepy_release test_macos_purepy_release: # take care to keep this variable consistent with the version used in pkg_macos_purepy_release
variables: {JOB_PYTHON: 'python3.9'} variables: {JOB_PYTHON: 'python3.10'}
extends: .test_unix_purepy_pkg extends: .test_unix_purepy_pkg
needs: needs:
- job: pkg_macos_purepy_release - job: pkg_macos_purepy_release
...@@ -841,7 +841,7 @@ test_macos_purepy_release_extra_pyver: ...@@ -841,7 +841,7 @@ test_macos_purepy_release_extra_pyver:
- macos_pip_pkg_tester - macos_pip_pkg_tester
test_nux_purepy_release: test_nux_purepy_release:
needs: needs:
- job: pkg_linux_purepy_release - job: pkg_linux_purepy_release
...@@ -859,7 +859,7 @@ test_nux_purepy_release_extra_pyver: ...@@ -859,7 +859,7 @@ test_nux_purepy_release_extra_pyver:
- linux - linux
test_nux_openblaso_purepy_release: test_nux_openblaso_purepy_release:
variables: {JOB_PYTHON: 'python3.9', PYFAUST_PKG_NAME: 'pyfaust_openblaso'} variables: {JOB_PYTHON: 'python3.10', PYFAUST_PKG_NAME: 'pyfaust_openblaso'}
needs: needs:
- job: pkg_linux_purepy_release_openblaso - job: pkg_linux_purepy_release_openblaso
...@@ -868,7 +868,7 @@ test_nux_openblaso_purepy_release: ...@@ -868,7 +868,7 @@ test_nux_openblaso_purepy_release:
- linux - linux
test_win_purepy_pkg: test_win_purepy_pkg:
variables: {JOB_PYTHON: 'py', WIN_PY_VER: '3.9'} variables: {JOB_PYTHON: 'py', WIN_PY_VER: '3.10'}
stage: pkg_test stage: pkg_test
script: script:
- 'cd build\wrapper\python\dist' - 'cd build\wrapper\python\dist'
...@@ -959,7 +959,7 @@ pypi_pub: ...@@ -959,7 +959,7 @@ pypi_pub:
conda_linux_pub: conda_linux_pub:
stage: conda_pkgs stage: conda_pkgs
script: script:
- misc/continuous_integration/conda_pkg/conda_build_upload_pyfaust.sh linux 3.9 misc/continuous_integration/conda_pkg/meta.yaml.in - misc/continuous_integration/conda_pkg/conda_build_upload_pyfaust.sh linux 3.10 misc/continuous_integration/conda_pkg/meta.yaml.in
- conda env remove -n build_upload_pyfaust_venv_39 - conda env remove -n build_upload_pyfaust_venv_39
- misc/continuous_integration/conda_pkg/conda_build_upload_pyfaust.sh linux 3.11 misc/continuous_integration/conda_pkg/meta.yaml.in - misc/continuous_integration/conda_pkg/conda_build_upload_pyfaust.sh linux 3.11 misc/continuous_integration/conda_pkg/meta.yaml.in
- conda env remove -n build_upload_pyfaust_venv_311 - conda env remove -n build_upload_pyfaust_venv_311
...@@ -974,7 +974,7 @@ conda_linux_pub: ...@@ -974,7 +974,7 @@ conda_linux_pub:
.conda_win_pub: .conda_win_pub:
script: script:
- start /wait git-bash -c "misc/continuous_integration/conda_pkg/conda_build_upload_pyfaust.sh win 3.9 misc/continuous_integration/conda_pkg/meta.yaml.in" - start /wait git-bash -c "misc/continuous_integration/conda_pkg/conda_build_upload_pyfaust.sh win 3.10 misc/continuous_integration/conda_pkg/meta.yaml.in"
- start /wait git-bash -c "misc/continuous_integration/conda_pkg/conda_build_upload_pyfaust.sh win 3.11 misc/continuous_integration/conda_pkg/meta.yaml.in" - start /wait git-bash -c "misc/continuous_integration/conda_pkg/conda_build_upload_pyfaust.sh win 3.11 misc/continuous_integration/conda_pkg/meta.yaml.in"
only: only:
- tags - tags
...@@ -987,7 +987,7 @@ conda_linux_pub: ...@@ -987,7 +987,7 @@ conda_linux_pub:
conda_macosx_pub: conda_macosx_pub:
script: script:
- misc/continuous_integration/conda_pkg/conda_build_upload_pyfaust.sh macosx 3.9 misc/continuous_integration/conda_pkg/meta.yaml.in - misc/continuous_integration/conda_pkg/conda_build_upload_pyfaust.sh macosx 3.10 misc/continuous_integration/conda_pkg/meta.yaml.in
- misc/continuous_integration/conda_pkg/conda_build_upload_pyfaust.sh macosx 3.11 misc/continuous_integration/conda_pkg/meta.yaml.in - misc/continuous_integration/conda_pkg/conda_build_upload_pyfaust.sh macosx 3.11 misc/continuous_integration/conda_pkg/meta.yaml.in
...@@ -48,19 +48,19 @@ ln -sf /opt/local/bin/clang++-mp-9.0 /usr/bin/clang++ ...@@ -48,19 +48,19 @@ ln -sf /opt/local/bin/clang++-mp-9.0 /usr/bin/clang++
# ciosx:~ ci$ /opt/local/libexec/llvm-8.0/bin/clang --version # ciosx:~ ci$ /opt/local/libexec/llvm-8.0/bin/clang --version
# dyld: cannot load 'clang' (load command 0x80000034 is unknown) # dyld: cannot load 'clang' (load command 0x80000034 is unknown)
# Trace/BPT trap: 5 # Trace/BPT trap: 5
#mv /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++_ # don't do this or port won't be able to detect clang version and make any install #mv /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ backup
#udo ln -sf /opt/local/bin/clang++-mp-9.0 /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ #udo ln -sf /opt/local/bin/clang++-mp-9.0 /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++
### 5. Install Python packages and dependencies ### 5. Install Python packages and dependencies
yes | port install graphviz doxygen yes | port install graphviz doxygen
sudo ln -sf /opt/local/bin/dot /usr/bin/ sudo ln -sf /opt/local/bin/dot /usr/bin/
yes | port install python39 py39-pip yes | port install python310 py310-pip
yes | port install jpeg # pillow (indirect denpendency of pyfaust needs this to build) yes | port install jpeg # pillow (indirect dependency of pyfaust needs this to build)
port select --set python python39 port select --set python python310
port select --set pip pip39 port select --set pip pip310
ln -sf /opt/local/bin/python3.9 /opt/local/bin/python3 ln -sf /opt/local/bin/python3.10 /opt/local/bin/python3
yes | port install py39-cython yes | port install py310-cython
yes | port select --set cython cython39 yes | port select --set cython cython310
yes | python3.9 -m pip install doxypypy chardet wheel pygsp numpy setuptools==49.1.3 # above this version commit sha256 as version fails yes | python3.10 -m pip install doxypypy chardet wheel pygsp numpy setuptools==49.1.3 # above this version commit sha256 as version fails
# get dest dir before downloading because otherwise it would be the current path # get dest dir before downloading because otherwise it would be the current path
DOXYPYPY_DIR=$(dirname $(python3 -c "import doxypypy; print(doxypypy.__file__)")) DOXYPYPY_DIR=$(dirname $(python3 -c "import doxypypy; print(doxypypy.__file__)"))
wget https://raw.githubusercontent.com/Feneric/doxypypy/master/doxypypy/doxypypy.py wget https://raw.githubusercontent.com/Feneric/doxypypy/master/doxypypy/doxypypy.py
