GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
faust group
faust
183b2574
183b2574
9 years ago
testcdash Nicolas Bellot
Committed by
hhakim
2 years ago
Downloads
Patches
mac cdash test script
b4f927f0
misc/CTest_nightly/run_nightly_OS-X.sh
+5
-4
5 additions, 4 deletions
5 additions
4 deletions
5
4
183b2574
@@ -17,11 +17,11 @@
@@ -17,11 +17,11 @@
# Directory of the library used in the FAUST PROJECT
export
PATH
$PATH
usr/local
/MATLAB
R2014b/bin
export
PATH
$PATH
Applications
/MATLAB
_
R2014b
.app
/bin
export
PATH
$PATH
:usr/local/include
export PATH=$PATH:usr/local/include
# Directory of the local path of the nightly project
export
PATH_DIR_RUN_NIGHTLY
'/Users/ci/
fau
st_nightly'
export
'/Users/ci/
CTe
st_nightly'
export
OPENBLASDIR
'/Users/ci/local/OPENBLAS-v0.2.15'
export
OPENBLASDIR
export
HDF5_ROOT_DIR
'/Users/ci/local/hdf5-1.8.17/lib'
export
HDF5_ROOT_DIR
export
EIGENDIR
'/Users/ci/local/eigen-3.2.8'
export
EIGENDIR
@@ -52,7 +52,8 @@ export CTEST_CONFIGURE_OPTIONS="-DBUILD_DEBUG:BOOL=OFF;\
-DFAUST_USE_OPENBLAS=ON;
-DFAUST_USE_MATIO=ON;
-DFAUST_USE_XML=ON;
-DFAUST_USE_XML=ON;
-DFAUST_USE_MEX=OFF;
-DFAUST_USE_MEX=ON;
-DFAUST_USE_OPENMP=OFF;
-DFAUST_USE_GPU:BOOL=OFF;
-DFAUST_USE_PROFILING=OFF;
-DFAUST_ISVERBOSE=OFF;
This diff is collapsed.
Loading
Save comment
