Commit 13fbe2b9 authored by hhakim's avatar hhakim
Ease use of faust data downloader script by creating the output directory if it doesn't exist.
parent 638ab14c
...@@ -56,7 +56,11 @@ def download_uncompress(uncompress_dir=None, base_url=BASE_URL, ...@@ -56,7 +56,11 @@ def download_uncompress(uncompress_dir=None, base_url=BASE_URL,
if __name__ == '__main__': if __name__ == '__main__':
from os import mkdir
from os.path import dirname, join
uncompress_dir=None uncompress_dir=None
if len(argv) > 1 and isdir(argv[1]): if len(argv) > 1 and isdir(dirname(argv[1])):
uncompress_dir=argv[1] uncompress_dir = argv[1]
if not exists(uncompress_dir):
mkdir(uncompress_dir)
download_uncompress(uncompress_dir) download_uncompress(uncompress_dir)
