/** \brief Time Measurement between a given matrix and its Faust factorization
* A dense matrix is loaded from "@FAUST_DATA_MAT_DIR@
* \param MatrixFilename : a dense ma trix is loaded from this file
* \param configFilename : a .mat (MATLAB file) configuration file which contains the parameter of the hierarchical algorithm (default launch with a predefined configuration called hierFact)
* \param transposedMatrix : -value 'N' (default value), the matrix stored in MatrixFilename is factorized
* \param expectedLambda (optionnal) : compared the expected scalar of the factorisation with the computed one in the precision defined with epsilon
-value 'T' , the transposed matrix is factorized *\param FaustFilename : a .mat (MATLAB file) where a Faust representing the dense matrix (or its transposed cf transposeMatrix)
*\param epsilon : precision for the test of equality (default value 0.0001)
(you can passed as many FaustFilename as you want
example : faust_multiplication_@TEST_FPP@ matrix.mat N faust1.mat faust2.mat
typedef @TEST_FPP@ FPP;
@@ -75,9 +77,10 @@ int main(int argc, char* argv[])
cout<<"floating point precision == float"<<endl;
if (argc <= 1)
if (argc <= 2)
cerr << "At least one input file (extension \".mat\") storing a dense matrix must be given" << endl;
cerr << "At least 2 input must be given " << endl;
cerr << "a .mat file storing a matrix and a parameter (value N or T) " << endl;
exit(EXIT_FAILURE);
exit(EXIT_FAILURE);
@@ -86,19 +89,38 @@ int main(int argc, char* argv[])
