Commit 11551f37 authored by hhakim's avatar hhakim
Set python3.9 for default version of revision/release whl packages and 3.10 for extra version.
CBP doesn't support python3.10 yet.
parent 3de9589c
......@@ -4,7 +4,7 @@ variables:
# Warning: DURL is the base url without the filename
DURL: "https://gitlab.inria.fr/faustgrp/gforge_files/-/raw/master/"
DFILE: "faust_data-3.5.2.zip"
JOB_PYTHON: "python3" # if set again in job, it hides this one (precedence: https://docs.gitlab.com/13.6/ee/ci/variables/#priority-of-environment-variables)
JOB_PYTHON: "python3.9" # if set again in job, it hides this one (precedence: https://docs.gitlab.com/13.6/ee/ci/variables/#priority-of-environment-variables)
WIN_PY_VER: '3.10' # default python version used to build python wrapper on windows (for both whl package and nsis .exe)
NIX_PY_VER: '3.10' # default python version used to build python wrapper for "unix" system packages (pkg/macos, rpm/deb/linux)
GEN_EGG: 'OFF'
......@@ -494,7 +494,7 @@ pkg_linux_purepy_rev:
pkg_macos_purepy_release:
extends: .pkg_purepy_release
variables: {MATIO_STATIC_LIB_PATH: "/usr/local/lib/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/lib/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/lib/libhdf5.a", BUILD_MULTITHREAD: "ON", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", NOPY2: "ON", CMAKE_CXX_COMPILER: "/opt/local/bin/clang++-mp-8.0", PYTHON_PATH: '/opt/local/bin/python3.10', JOB_PYTHON: 'python3.10'}
variables: {MATIO_STATIC_LIB_PATH: "/usr/local/lib/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/lib/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/lib/libhdf5.a", BUILD_MULTITHREAD: "ON", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", NOPY2: "ON", CMAKE_CXX_COMPILER: "/opt/local/bin/clang++-mp-8.0", PYTHON_PATH: '/opt/local/bin/python3.9', JOB_PYTHON: 'python3.9'}
before_script:
- VERSION=$CI_COMMIT_TAG
- if [[ ! -d 'build' ]]; then mkdir build;fi; cd build
......@@ -505,7 +505,7 @@ pkg_macos_purepy_release:
pkg_macos_purepy_release_extra_pyver:
extends: pkg_macos_purepy_release
variables: {MATIO_STATIC_LIB_PATH: "/usr/local/lib/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/lib/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/lib/libhdf5.a", BUILD_MULTITHREAD: "ON", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", NOPY2: "ON", PYTHON_PATH: '/opt/local/bin/python3.9', JOB_PYTHON: 'python3.9', CMAKE_CXX_COMPILER: "/opt/local/bin/clang++-mp-8.0"}
variables: {MATIO_STATIC_LIB_PATH: "/usr/local/lib/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/lib/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/lib/libhdf5.a", BUILD_MULTITHREAD: "ON", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", NOPY2: "ON", PYTHON_PATH: '/opt/local/bin/python3.10', JOB_PYTHON: 'python3.10', CMAKE_CXX_COMPILER: "/opt/local/bin/clang++-mp-8.0"}
tags:
- macos
......@@ -520,14 +520,14 @@ pkg_macos_purepy_release_torch_linked:
pkg_linux_purepy_release:
variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: "/opt/local/matio-1.5.7/src/.libs/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/zlib-1.2.11/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/hdf5-1.8.18/src/.libs/libhdf5.a", BUILD_MULTITHREAD: "ON", NOPY2: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "../gpu_mod", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", CMAKE_CXX_COMPILER: "clang++"}
variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: "/opt/local/matio-1.5.7/src/.libs/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/zlib-1.2.11/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/hdf5-1.8.18/src/.libs/libhdf5.a", BUILD_MULTITHREAD: "ON", NOPY2: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "../gpu_mod", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", CMAKE_CXX_COMPILER: "clang++", PYTHON_PATH: '/usr/local/bin/python3.9', JOB_PYTHON: 'python3.9'}
tags:
- linux
- tux_packager
pkg_linux_purepy_release_extra_pyver:
variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: "/opt/local/matio-1.5.7/src/.libs/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/zlib-1.2.11/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/hdf5-1.8.18/src/.libs/libhdf5.a", BUILD_MULTITHREAD: "ON", NOPY2: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "../gpu_mod", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", PYTHON_PATH: '/usr/local/bin/python3.9', JOB_PYTHON: 'python3.9', CMAKE_CXX_COMPILER: "clang++"}
variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: "/opt/local/matio-1.5.7/src/.libs/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/zlib-1.2.11/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/hdf5-1.8.18/src/.libs/libhdf5.a", BUILD_MULTITHREAD: "ON", NOPY2: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "../gpu_mod", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", PYTHON_PATH: '/usr/local/bin/python3.10', JOB_PYTHON: 'python3.10', CMAKE_CXX_COMPILER: "clang++"}
tags:
- linux
- tux_packager
......@@ -541,7 +541,7 @@ pkg_linux_purepy_release_extra_pyver:
pkg_linux_purepy_release_openblaso:
variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: "/opt/local/matio-1.5.7/src/.libs/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/zlib-1.2.11/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/hdf5-1.8.18/src/.libs/libhdf5.a", BUILD_MULTITHREAD: "ON", NOPY2: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "../gpu_mod", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", CMAKE_CXX_COMPILER: "clang++", USE_OPENBLASO: "ON"}
variables: {GIT_SUBMODULE_STRATEGY: recursive, MATIO_STATIC_LIB_PATH: "/opt/local/matio-1.5.7/src/.libs/libmatio.a", Z_STATIC_LIB_PATH: "/opt/local/zlib-1.2.11/libz.a", HDF5_STATIC_LIB_PATH: "/opt/local/hdf5-1.8.18/src/.libs/libhdf5.a", BUILD_MULTITHREAD: "ON", NOPY2: "ON", USE_GPU_MOD: "ON", CMAKE_PREFIX_PATH: "../gpu_mod", FAUST_TORCH: "OFF", EXPERIMENTAL_PKG: "OFF", CMAKE_CXX_COMPILER: "clang++", USE_OPENBLASO: "ON", PYTHON_PATH: '/usr/local/bin/python3.9', JOB_PYTHON: 'python3.9'}
tags:
- linux
- tux_packager
......@@ -631,7 +631,7 @@ pkg_win_purepy_rev:
pkg_win_purepy_release:
extends: .pkg_win_purepy
variables: {BUILD_CONFIG: "Release", GIT_SUBMODULE_STRATEGY: recursive, EXPERIMENTAL_PKG: "OFF"}
variables: {BUILD_CONFIG: "Release", GIT_SUBMODULE_STRATEGY: recursive, EXPERIMENTAL_PKG: "OFF", WIN_PY_VER: '3.9'}
before_script:
- 'set VERSION=%CI_COMMIT_TAG%'
artifacts:
......@@ -641,7 +641,7 @@ pkg_win_purepy_release:
pkg_win_purepy_release_extra_pyver:
variables: {BUILD_CONFIG: "Release", GIT_SUBMODULE_STRATEGY: recursive, EXPERIMENTAL_PKG: "OFF", WIN_PY_VER: '3.10'}
before_script:
artifacts:
......@@ -730,7 +730,7 @@ test_linux_pkg_release:
- tags
test_macos_purepy_release: # take care to keep this variable consistent with the version used in pkg_macos_purepy_release
variables: {JOB_PYTHON: 'python3.10'}
variables: {JOB_PYTHON: 'python3.9'}
extends: .test_unix_purepy_pkg
needs:
- job: pkg_macos_purepy_release
......@@ -740,7 +740,7 @@ test_macos_purepy_release: # take care to keep this variable consistent with the
- macos_pkg_tester
test_macos_purepy_release_extra_pyver:
variables: {JOB_PYTHON: 'python3.9'} # take care to keep this variable consistent with the version used in pkg_macos_purepy_release_extra_pyver
variables: {JOB_PYTHON: 'python3.10'} # take care to keep this variable consistent with the version used in pkg_macos_purepy_release_extra_pyver
needs:
- job: pkg_macos_purepy_release_extra_pyver
......@@ -750,7 +750,7 @@ test_macos_purepy_release_extra_pyver:
- macos_pkg_tester
test_nux_purepy_release:
variables: {JOB_PYTHON: 'python3'}
needs:
- job: pkg_linux_purepy_release
......@@ -759,7 +759,7 @@ test_nux_purepy_release:
- linux
test_nux_purepy_release_extra_pyver:
needs:
- job: pkg_linux_purepy_release_extra_pyver
......@@ -768,7 +768,7 @@ test_nux_purepy_release_extra_pyver:
- linux
test_nux_openblaso_purepy_release:
variables: {JOB_PYTHON: 'python3', PYFAUST_PKG_NAME: 'pyfaust_openblaso'}
variables: {JOB_PYTHON: 'python3.9', PYFAUST_PKG_NAME: 'pyfaust_openblaso'}
needs:
- job: pkg_linux_purepy_release_openblaso
......@@ -777,7 +777,7 @@ test_nux_openblaso_purepy_release:
- linux
test_win_purepy_pkg:
variables: {JOB_PYTHON: 'py'}
variables: {JOB_PYTHON: 'py', WIN_PY_VER: '3.9'}
stage: pkg_test
script:
- 'cd build\wrapper\python\dist'
......@@ -799,7 +799,7 @@ test_win_purepy_pkg:
test_win_purepy_pkg_extra_pyver:
extends: test_win_purepy_pkg
variables: {JOB_PYTHON: 'py', WIN_PY_VER: '3.10'}
needs:
- job: pkg_win_purepy_release_extra_pyver
artifacts: true
